Question about Lexmark JetPrinter X1185 All-In-One InkJet
NOT PRINTING My printing is not printing. I have checked the things that could be causing the problem but nothing is working. Please Help!!!!!
  • Anonymous Dec 12, 2007
    NOT PRINTING THE INFORMATION ON TO THE PAPER
My hp 1210 pc will print but not from my computer. It prints pages when I push the printer button, but when I'm on the computer and go to print page, nothing happens. I have taken it to a rrepair shop two times and they say it' the printer which does not show as a device for the computer to recognize. How can I make it see the device?
Posted on Sep 16, 2007
    Sergeant:
  • 390 Answers
Need more details, not enough to help. When you say not printing, does it feed paper at all, does it print nothing or some and not all? What have you don to solve it yourself, as this helps narrow the field. Post back as i would genuinely love to see it running. I have the same printer, and it is usually fixable without too muck fuss. Mine has been excellent so far and i have had it nearly 3 years. Havew you had it long and do you do regular maintenance or none?
Posted on Sep 01, 2007
Bizhub C450 strange printing problem. Green data LED is flashing but nothing happens.
Did you try to change the IP address of MFP. Please change IP address of MFP and connect the PC you are sure not giving any problem. If its works fine then connect rest of the remaining PC's
Nov 15, 2014 | Konica Minolta bizhub C450P Laser Printer
BLACK INK NOT PRINTING
Hi Hmmg,
This is a clear indication that some thing is gone wrong in your printer's circuit. Please get it checked by an authorized service engineer.
Regards.
Nat
Jun 29, 2012 | Epson Stylus CX9300F Series
I am trying to print a document however nothing is printing. I have placed new ink cartridges within and the printer takes in the paper and the noise suggests it is printing and recognising the text within...
First thing I always check is the last thing that I did... so ..i fi t worked prior to replacing the ink cartridge/s ..and you replaced them,... did you: peel off the protective tape from the cartridge before installing them? Did you install them correctly.. meaning are they properly seating into the printer and making proper electrical contact with the printer connector? Lastly, are you sure you have the correct ink cartridges installed? After verifying all those things, try printing a test page by going to the control panel..then printers... then select that printer shown with the right mouse button ... and properties in the popup menu for that printer.. it should allow you to 'print a test page'... you may also have a loose cable ( usb or parallel connector ) not seated right between the priinter and the computer... Hopefully, one of the suggestions listed above will get you going... Good Luck..
Jan 30, 2010 | Lexmark X1150 All-In-One InkJet Printer
Prints nothing on paper. checked ink cartridges
please the your pc in add a printer and again install a printer driver
and you go control panelt and select the printer an dchous this printer
and restart your pc and try printing giveup page
Sep 14, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Someone please help me!
Hi Emma,
It sounds like your PC is printing to draft everytime, have you checked your printer settings within Control Panel, Printers? If nothing stands out to you then probably best thing to do is a reinstall of the printer driver, 99% of the time this will sort it.
If this has helped you then please rate me!
Aug 26, 2009 | Epson Stylus C84 InkJet Printer
Printer stopped working
Turn printer on and off if that doesnt work then ust restart, sometimes things get stuck in the queue.
Apr 24, 2009 | Lexmark X1150 All-In-One InkJet Printer
Epson pro 9800 wont print
Don't print out of illustrator it causes a lot of heartburn. put the art into indesign or Quark and print from the layout program. That has always solved the problem for us.
Nov 05, 2008 | Epson Stylus Pro 9800 InkJet Printer
Printer ERROR "Unable to Print 50! Unable to Print 30!" ???
WONT PRINT UNABLE TO PRINT , PAPER JAM
CLEANED PAPER JAM, CANT SEEM TO FIND ANY THING MORE TO DO TO IT
Sep 04, 2008 | Brother MultiFunction Center MFC-440CN...
My printer won't print
sir,
I think there is a pending printing jobs on your printer try to cancel all the printing jobs then restart the computer so it will reset all the printing jobs you have. repeat these steps untill its ok. and make sure there is a paper on the paper tray before you do it.
yours,
alecz
Apr 23, 2008 | HP DeskJet 3535 InkJet Printer
Paper feed problem, then error
SEPARATION ROLLER MAY NOT INGAGE CAUSING THE PAPER NOT TO FEED TO THE FEED ROLLERS THE PAPER DOES NT ADVANCETO THE REGISTION ROLLER THAT SET THE PAPER FO COPY CHECK TO SEE IF THEY ARE CLEAN OR WORN
Dec 07, 2007 | Konica Minolta magicolor 2400 Laser...
Lexmark JetPrinter X1185 All-In-One InkJet Logo
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
