Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
REMOTE WON'T WORK WITH AIR CON UNIT
WE RECENTLY HAD A BLACKOUT AND NOW THE REMOTE WON'T WORK IN CONJUNCTION WITH OUR UNIT
WEATHERMAKER MODEL NO. ES1025H (53ESO25H)
    Guru:
  • 462 Answers
First turn off all the power inside and out then back on and change your batteries in the remote. And look on the remote for an extra switch that may have been moved during the outage and you don't ordinarily see it. If neither of these solutions work its most likely a service call. to tell you more.
Posted on Mar 10, 2009
I have a split-type aircon (brand: LG) with remote control.It has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix this?...
Lift the front cover of the air con, on the right hand side there is a button or a hole which has a button inside which you can press which is for manual starting of the air con. If this works, then you will know the remote is faulty, if it still doesn't work, check that the isolator switch for the air con hasn't been turned off. There will be 9Or should be) a switch outside next to the air con outdoor unit to switch power on / off to the air con. If not, there should be switch inside the meter box at the front of the house. Make sure they are switched on.
Apr 06, 2016 | LG LSC121PMA Split System Air Conditioner
I have an celestial air con unit model KFR-70GW/K it is blowing air refresh out but will not turn on to air con with the remote... help
Check temp setting minimum -3 degree than your room temp and also in cool mode. If while settings there any beep sound? If not transmission problem between remote and PCB. Replace batteries and check once again. If beep sound comes and no start, check compressor is working and also with proper gas pressure. Thanks.
Jan 22, 2011 | Heating & Cooling
CS /CU-903KR.. had a series of power blackouts and the air con was on. In the morning turned it off but the exterior box was still running (without us knowing) and both the interior and exterior froze......
Power straight a way to out door unit through jammed /struck contactor . When you start power on,power not going to out door by transmission of indoor thermostat calling.
Replace out door contactor.
Jan 05, 2011 | Panasonic Heating & Cooling
Air con not working. Operation and timer lights flashing, then operation light flashes and then lights go off. Air con is blowing air but the outside unit is not blowing any air.
First check your timer on and off. If you want to reset, remove batteries from remote and power off to unit. Reset it. Now run the unit. Set temp mode once again in your remote and wait for 3 minutes. If still out door unit not working, check power line to out door unit.
Dec 31, 2010 | Fujitsu Heating & Cooling
Hi i have recently purchased an amcor sPLIT UNIT AND CAN NOT GET THE HEAT TO WORK AND DO YOU HAVER ANY SUGGESTIONS AND PRESUME IT IS A SETTING i AM NOT CORRECTLY PRESSING ? rEGARDS cRAIG
dear sir
please first make turn on your electrical supply for air con
and then use remote controller and find out there heat mode and select it then make your air con on heat mode ..
i hope it will work on heat mode
hope answer the question
thank you
please vote!
Sep 25, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Hello I have Sharp Air con/Heating AY-XPM9FR with a floor/wall unit and a higher wall unit that are supposed to work in conjunction with each other. I have never had any problems until we had a power cut...
Hi Helen, i want to know the age of your Sharp Air con/Heating system. If its more than 1 year and you using it regular basic , then i suggest you change the battery or the remote control first then try . If the same thing happens then follow the instruction as per below image.
If there is also ok & look good then ,please call a service man and check the air cooling/ heating gas. Because you mentioned "I have the manual and have tried to reset the timers using the remote control but still no good. " Another chance you can take before call the service person, just reset the full system by remote control not only the timer. Thanks & waiting for your feedback.
Feb 18, 2010 | Heating & Cooling
Electra remote wont work with electra air con.
hi.you should have a sticker under the indoor unit head unit or on the side.
Jun 10, 2009 | Heating & Cooling
Unable to turn on aircon with remote control and no manaul on button on the air con unit
I recommend putting new batteries in the remote. If that alone solves your problem great. If not, get back and let me know
May 25, 2009 | Heating & Cooling
Hi I have a Weathermaker ducted air con model WMHO 0487 and it is flashing HP or LO I have no manual to guide me
this means either its got gas leak or outside unit fan not working.try off and on circuit breaker and if it shows ho or lo again then definitely there is a problem.when after resetting power see outside unit if fan is running if yes and if it stop again then it's gas leak
May 09, 2009 | Heating & Cooling
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
307 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
