Question about Dell 1720dn Laser Printer
Popping noise when i print
The papers print but there is a popping noise
    Problem Solver:
  • 7 Answers
If there is a clicking noise, check the paper tray. either the tray is overloaded or the paper guide is not set properly.
it's common for the blue paper tab in the paper tray to slide back. the tab has a little square cut out. make sure that it says "LTR" if you use regular letter size paper (8 & 1/2 x 11 inch).
Posted on Feb 17, 2009
  • ecbutler66 Jun 08, 2011
    thats not a good fix. it has something to do with a solenoid that engages the feed drive. ive seen it but cant find a part number for it.
  • Keith Miller Jul 25, 2012
    can you post a picture of what this solenoid looks like
Epson 4880 incorrect paper source setting
you have to chose sheet paper before sendding the print command.
Apr 02, 2013 | Epson Stylus Pro 9800 InkJet Printer
Tip
Noise while printing - Diagnosis Pt 1
<p>Unexpected noise (such as clicking, thumping, or grinding) from an branded device are heard during printer operation.<br /> <br /> <span><b>NOTE: </b></span><br /> Noises can be caused by a number of things, some of which may not be addressed in this document. This document deals strictly with the isolation and potential resolution of known noises through troubleshooting.<br /> <p>The following table describes some of the noises to be expected in a printer functioning normally:<br /> <span>Noise occurs:</span> <br /> <span>Additional information:</span> <br /> During power-up<br /> When the printer periodically makes humming and buzzing sounds as the carriage assembly moves around on the right/left side of the printer, the printer is actually cleaning the ink cartridges. This is a normal operation for the printer. This sequence may happen in the following conditions:<br /><br /><br /> <ul> <li> <p>Before and/or after printing<br /> <li> <p>During power on <br /> <li> <p>After the printer has been on standby/idle for some time<br /> <li> <p>After replacing a cartridge<br /> <li> <p>In the middle of a long print job (such as printing many photos)<br /></li></ul> During printing*<br /> <ul> <li> <p>Paper pickup: There will be some noise during paper pickup due to the movement of rollers and gears.<br /> <li> <p>While printing: The unit has printed a few lines or the paper has been fed into the printing area. There will be some noise during printing due to the movement of rollers, gears, carriage and paper (paper feed and ejection).<br /></li></ul> During paper ejection*<br /> At the end of the print job, there is a louder clicking noise as the paper is being "pushed off" to the output tray.<br /> During copying/scanning<br /> The scanner may make pulsing and dragging noises as it scans portions of the document or it may make a long rolling sound if it is doing a continuous scan. After scanning, it will make a long dragging noise as the scanner is brought back to the home position (could be on the left or right side).<br /> Post-printing with no additional jobs in the queue<br /> Post-completion of a print job and without another job in queue: At the end of a print job, there will be a noise on the left/right side of the printer as the pens are being capped. The printer may try to do this a couple of times, which is normal.<br /> Between print jobs<br /> The printer may make humming and buzzing sounds as the carriage assembly moves around on the right/ left side of the printer during the cleaning of the ink cartridges.<br /> In the accessories<br /> There may be some noise associated with accessories (ADF, duplexer, etc.) during the initial positioning and during normal operation.<br />
on Mar 10, 2011 | Office Equipment & Supplies
Paper light flashing popping noise
The problem sounds like the rear paper guide of the paper tray is too tight aginst the paper. Back the guide off about 1/16 of an inch and see if that helps. You may also want to check and make sure the tray is set for the correct paper size of the paper you are using. Good luck!
Oct 09, 2009 | Brother HL-5240 Laser Printer
Problems printing 4x6 with MP600
You're most welcome. Remember to check all of your paper, I had it curl a bit from sitting too long and I had a very bad paper jam from that. Good luck!
Feb 25, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Can hardly read print after putting on new ribbon
You have to make a platen adjustment (on the left side move it back).
Jan 23, 2009 | IBM 4247 A00 Matrix Printer
Printing
Does it feed a length of paper? if so, you may have either the wrong paper, or the paper loaded incorrectly. It needs to be thermal paper, and it will only print on one side, so if you are sure its thermal paper then try turning the paper over and loading it that way.
If it doesnt feed any paper and just makes noise then the problem is probably a broken gear inside the printer. For this you would need to find a place that can repair these terminals.
Nov 06, 2008 | VeriFone (M19755014US1) Magnetic Card...
C4380 HP Printer
Does it make noise when it first feeds paper or when the print module sweeps across? It's possible that there is some obstruction in the paper path or in the way of the print module. Is the noise constant or only when a certain action occurs? Let me know.
Oct 29, 2008 | Office Equipment & Supplies
GRINDING NOISE or PAPER JAM
If you are not a technical person best thing to do is to show it to an expert. grinding noise means some part in the machine is running with the friction. and might brake something or scratch something. Find out persons who work on photocopiers in your area either samsung or Xerox. as this model comes with both the companies and Xerox people are generly better than samsung people.
Apr 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Printing Dillema
Flashing resume light also can mean:
1. cartridge is missing or an incorrect print cartridge is installed
2. cartridge is out of ink
3. dirty cartridge contacts
4. paper jammed
Check are cartridges firmly snapped into place and not empty. Use water to wash copper on cartridges if contacts are dirty.
Oct 30, 2006 | HP DeskJet 690c plus InkJet Printer
Dell 1720dn Laser Printer Logo
686 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
