Question about Smeg SUK91MFX5 Dual Fuel (Electric and Gas) Kitchen Range
My smeg oven,(bottom fan oven) keeps getting hotter and hotter till it cuts out or the fuse blows when i switch it on no matter what temp i put it on,iam assuming its the thermostat,were is it and how yo fit it.Regards Gaz.
  • 417 Answers
The thermostat is obviously not working and you will need to replace it.
The thermostat is located behind the temperature selector switch on the control panel. The oven thermostat usually has a capilliary tube attached which goes in to the oven internally and is fixed on to the oven wall you will need to disconnect this also and remove it with the thermostat. Fitting the stat is the reverse of removal.
Make sure the electrical supply to the oven is switched off before starting work Hope this will FixYa.
Please remember to rate this solution.
Posted on Dec 12, 2008
The house I've just bought has a Smeg 60 cm wall oven installed. Possibly 4-5 yrs old. I can't get it to work. An orange light comes on on the door panel when the temp control is turned on. Light goes...
Most of these ovens have two fans. A fan forced fan in the oven and a cavity extractor fan inside the cavity of the unit between the outer skin and the oven wall. The cavity fan blows hot cavity air out the front of the unit so it remains cool. If the orange indicator light is coming on this would normally be the oven element thermostat. Leave it on and see if it gets hot. If the light goes off when you select the function switch it means you are turning it off the oven function. Your interior oven light may be blown.
Hope this helps.
Feb 07, 2011 | Smeg SE399X/5 Stainless Steel Electric...
My oven gets too hot. flame doesn't shut down
The problem is the temperature probe has failed. This is inexpensive usually and easy to replace. This link should help
http://appliancehelponline.com/oventempprobe.html
Jul 08, 2010 | Premiere Ranges SCK34 Gas Kitchen Range
Switch oven on within 3 mintues the fuses blow main fuse box
I suspect the fan oven element has failed, this is located at the rear of the inner oven compartment behind a removeable cover
It is probably breaking down as the element gets hotter.
Feb 28, 2010 | Neff B1421 Electric Single Oven
NEFF U1271 Oven overheating
Hi it could well be the thermosat has stopped working
Jan 24, 2010 | Neff U1721 Double circotherm Electric Oven
The fan on my bmw e46 runs for about 5 minutes then goes off then about 5 minutes comes back on.
the fan on a car is not ment to come on till the motor gets to a set temprature
so as the motor is getting cooler it turns off then when it gets to the point where itsd hitting the hotter temp it cuts in to cool the motor back down
hope this helps
if your motor is not over heating thats all it is
if the car is overheating then the thermostat may need replacing
its like a electric oven it keeps one tempriture
Jul 04, 2009 | BMW M3 Cars & Trucks
Smeg oven not working. only clock and thermostat light working
It sounds like you have either one of the following things that need attention. First, turn off both breakers to the oven and then back on. Next check the wiring from the receptacle to the back of the oven. Next, check your internal fuses. Most ovens have them. Last, check the wiring to the elements and control switches. Somewhere you have a wire burned off the terminals or control switch. That smell you referred to is probably one of the wires that may be burned.
Feb 11, 2009 | Smeg SE399X/5 Stainless Steel Electric...
SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Dec 15, 2008 | Smeg Ovens
Suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Feb 17, 2008 | Smeg SUK92MFX5 Dual Fuel (Electric and...
Smeg oven suk92mfx5
ring element has burnt out.
Feb 16, 2008 | Ovens
Electric oven fan
This problem is caused by one of two components, depending on the model, there is a thermal cut in thermostat that keeps the fan running until the unit has cooled down and on some models there is a four wire timing device that keeps the fan running for a specific time after the temperature drops, the fault can only be casued by one of these components. Smeg Service Engineer
Aug 21, 2006 | Smeg A1A.1 Gas Kitchen Range
Smeg SUK91MFX5 Dual Fuel (Electric and Gas) Kitchen Range Logo
959 people viewed this question
Top Smeg Kitchen Ranges Experts
ashburton
Mike Carew
Joseph Mueller
Joseph Mueller
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
