Question about Intel Motherboard
How install new bios
Dear sir,
when i update new bios sea a message "attention parameter change''
yet i countinue & update complete.when i restart pc then system cant boot.please help me how to start pc & install or write new bios.
  • 449 Answers
New bios is very difficult to change and it cant be updated easily. i suggest you purchase new updated mother board for your system.
Posted on Dec 12, 2008
    President:
  • 1,073 Answers
After updated your bios, did you check the boot sequence?
it might have been changed. Go in to the bios again and check so the boot setting is pointed that your pc starts from your HDD.
If you trying to reinstall the OS you should change tye boot to start from you cd-drive.
Good luck to you
If you find my answer helpfull, dont forget to vote
4 Suggested Answers
The Machine
  • 788 Answers
SOURCE: acpi complaint - reg
Reset you BIOS to it's default. Hit Del/F1/F2/F10 or whatever key the machine prompts you when it first boots to get into system setup. Then pole around to find a restore to defaults option.
Or you may in fact have to upgrade the BIOS, what kind of system or motherboard to you have?
Posted on Jan 17, 2008
Hanto
  • 226 Answers
SOURCE: Latest Bios For The E210882
You really should contact Emachine support. I looked for your model # 5250 among all their various model ' series ' with no luck on my end. I also thoroughly investigated the Intel website for your motherboard model # and that doesn't show up either at least not as written by you. I did find on the Japanese Intel website a model that was very similar tho. It is written as D915GAV, not GVA and the website for reference is very hard to read by most West Europeans and Americans. So my strongest recommendation is to go with the first link to Emachine support. I'm sure they can be of some help to you.
Posted on Aug 30, 2008
SOURCE: i have a toshiba L300
I solved that problem with unpluging every kind of connectors (Usb..) Shuting completly down. Unplug the powersupply and restart the whole system. After that, go to BIOS and see the SATA Option, set to compatible and not ASHC(or whatever its called). After the BIOS Update some of my BIOS settings were changed.
Posted on Feb 14, 2009
BIOS PCG 7z1l
Here is the link to the Bios you need:
http://s02.download.sony.com/US/pc/PHBSYS-14612500-US.EXE
Here are the Download and Installation Instructions:
  1. To ensure that no other program interferes with the installation, save all work and close all other programs. The Taskbar should be clear of applications before proceeding.
  2. Download the PHBSYS-14612500-US.EXE file to a temporary or download directory (please note this directory for reference).
  3. Go to the directory where the file was downloaded and double-click the PHBSYS-14612500-US.EXE file to begin the installation.
  4. At the "BIOS Update Utility" screen, click "Next".
  5. At the "License Agreement" dialog, read the agreement, then, if you agree, click "I Agree" to continue with the installation.
  6. At the "VAIO BIOS Update Tool" screen, verify the new version to be installed is R0131J9, and then click "Update".
  7. At the "WBFLASH" window, click "OK" to update the computer BIOS.
  8. At the "BIOS Update successfully completed" window, click "OK".
  9. The computer will shutdown automatically.
  10. Wait for 30 seconds then power the computer on.
After the computer restarts, the installation of the BIOS Update is complete.
Sep 06, 2012 | Sony Vaio Laptop Pcg-7z1l
Sony VAIO Pcg-7z1l update BIOS
After the computer restarts, the installation of the BIOS Update is complete..
Sony VAIO PCG 7z1l
Here is the link to the Bios you need.:
Shuttle xp, ntldr is missing
replace the cmos battery, reboot the computer go into bios reset date and time and change boot order cdrom to boot first save changes. boot from windows xp cd do a repair. form command type sfc /scannow checks all system files.if any are bad should repair them.
Apr 17, 2017 | Computers & Internet
Bios Beep
Motherboard BIOS Recovery Jumper
  • Install the bootable BIOS upgrade disk which you previously created to do the original flash upgrade into drive A: and restart the system. If the update failed because you used the wrong BIOS update you should get the correct one and repeat this step. When the computer reboots there will most likely be no video prompts, however you can monitor this procedure using the floppy drive light and the PC speaker. When the PC speaker beeps and the floppy drive light is lit it means that it is currently copying the new BIOS onto the motherboard.
  • When the floppy drive light goes off and the PC speaker beeps (twice in most cases) the recovery should be complete. During the update procedure there might be pauses that looks like your computer is doing nothing, if so be sure to wait at least a minute to make sure the update is complete. When you are sure the BIOS update is complete and there is no more activity, power off the computer.
  • Change the jumper you changed before back into the original position so the computer can operate normally.
When you turn your computer back on your BIOS will be functional and you should be able to use your computer normally again.
Apr 30, 2012 | Acer VL460-UD4500C WINDOWS VISTA BUSINESS...
My computer screen went completely white. I have a Dell flatscreen monitor
This issue occurs due to various reasons. However, in this case it might be due to corrupt BIOS settings. To resolve this issue I recommend you to visit the following website to download and install the BIOS Update:
===Installation Instructions ===
1. Download the BIOS update. (from Dell website)
2. Double-click the BIOS update icon, and then click NEXT.
3. Accept the license terms, and then click NEXT.
4. If an Overwrite Protection message appears, click YES TO ALL.
5. Click OK at the Windows Based BIOS Update window.
6. Click YES at the next Windows Based BIOS Update window, and then wait for the update to complete.
7. At the Windows Based BIOS Update window, click YES to restart your PC.
8. If you see the following message during the restart of your PC, continue with the remaining steps; otherwise you are done with the update.
Default BIOS settings have been loaded due to BIOS update or checksum issue.
Press to enter Setup. Otherwise, allow the PC to continue.
9. Press and hold F1 for a few seconds to open the BIOS Setup.
10. Press F5 for a few seconds, choose YES, and then press Enter to load the BIOS defaults. (Use the arrow keys to choose YES, if necessary.)
11. Press F10 for a few seconds, choose YES, and then press Enter to exit the BIOS Setup and save your changes. (Use the arrow keys to choose YES, if necessary.)
12. Press Enter to confirm the save.
13. If you see a System Settings Change message prompting you to restart your PC, click YES to restart the PC again.
Also use a sytem utility software RegInOut -- a System Utilities program that includes several features which allows the PC users to speedup their computer performance. It improves system performance by removing junk files and fixing registry errors. Its additional feature of
Internet Optimizer enhance users web browsing experience.
Dec 19, 2011 | Dell Computers & Internet
Thinkpad T20 2647 HDD problem
on restart enter setup or bios and set to default settings
then restart and press f7 choose option to boot from cd
then press enter should boot.
if not then this is the site i use for bios updates www.wimsbios.com
don't forget to rate me
thanx
Feb 02, 2009 | IBM ThinkPad T20 2647 Notebook
WINDOW INSTALLATION PROBLEM
u need to download and restore bios update...
Jan 09, 2009 | Computers & Internet
How install bios
you need to reboot your system with the help of mother board cd or driver. default yuou system.
Dec 12, 2008 | Intel Motherboard
Computer Trouble
Most likely an IRQ conflict error between other hardware. Double check settings first, then try to reinstall drivers. This might help: http://www.helpwithpcs.com/upgrading/change-irq-settings.htm
Apr 25, 2008 | Gateway 500 X PC Desktop
Intel Motherboard Logo
146 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
