Question about Intel Dot Station (INTC300AIO) PC Desktop
Function key my compaq presario c770 tu keyboard is not working properly. Whenever i m using alphabet keys in which there are numbers and symbols. The particular alphabet doesn't appear but the numbers and symbolsappear in the screen perhaps its function key is ON
  • 449 Answers
You will need to service the kayboard or you purchase another one from your hardware vendor
Posted on Dec 12, 2008
How do I enable a compaq laptop's keys
Compaq Presario computers provide users with a row of function keys for added keyboard functionality. Function keys can serve a dual purpose as well.
Function keys are located at the top of Compaq Presario keyboards.
By learning how function keys work on a Compaq Presario you can take advantage of time saving keyboard shortcuts.Purpose
Use function keys to access menus, save changes and create shortcut keys.
Various applications, including Microsoft Office, allow you to select a function key as a shortcut key for running specific tasks. These settings are usually found under the Tools, Settings or File menu.
Each Compaq Presario computer has twelve function keys.
The most common used keys are "F2," "F8," "F10" and "F12."
The first three are used mainly to access and use the Compaq BIOS. "F12" is used to access a set of run from options during the boot process.
How to Access
Access function keys on a Compaq Presario by pressing any of the keys on the top row of the keyboard. Access the key's dual purpose by first pressing the "Fn" key located on the bottom row of keys.
Use function keys as shortcut keys by pressing them anytime while in the desired application. Remember, you must set them as shortcut keys first.
Note that some programs may already have certain function keys set as shortcuts.
Open menus and view the shortcut keys beside each menu item before setting your own shortcuts.
Dual Uses Each function key has a dual use. Press "Fn" plus the desired function key for the key's other use.
Below each function number is a small picture within a square or rectangle.
This dictates the dual use. "F1" opens help and support. "F2" serves as a printer shortcut.
Open your homepage by pressing "F3."
If you use dual monitors, switch between monitors by using "F4." "F5" puts your computer in stand-by mode.
Quickly lock your computer by pressing "F6." "F7" and "F8" adjust the screen's contrast.
Play and pause your music in Windows Media Player or other default media player by using "F9."
Press "F10" to stop playing media. Skip ahead or rewind media by using "F11" and "F12."
Other "Fn" Keys
In addition to function keys, the "Fn" key is also provides other keys with a dual use.
Any key with a small square on the key has a dual purpose such as the "scroll," "insert" and "delete" buttons.
Since laptop keyboards have no number pads, certain keys serve as the number pad by pressing the "Fn" key.
Jan 08, 2012 | Compaq Computers & Internet
My computer keyboard is typing numbers instead of letters.. any suggestions on how to fix it
This is because most notebook keyboards have a number pad incorporated into the right-hand side of the keyboard. Numbers are being typed because the NumLock is active.
To disable this function press the NumLock key (might be marked NumLock or have a symbol that looks like a calculator on it) on the keyboard (you might need to press the Fn function key and the NumLock simultaneously).
http://www.pcdoctor-guide.com/wordpress/?p=2446
Nov 25, 2009 | Compaq Presario 700 470024-192 Notebook
Where is wifi switch on the compaq laptop?
Well, you haven't given the model number to your compaq. I will try to assist you the best I can, if this doesn't help then I ask that you provide the model number. Some of the Compaqs have a button right between the keyboard and the monitor(it looks like this: http://www.hp-pavilion.ru/Catalogimages/Compaq-Presario-C700/29945.jpg). Others will have a switch somewhere with a orange dot/light near it. If you don't see either of these then there is probably a function key for it. Incase you don't know how function keys work, functions are usually located under the F1-12 keys, you hold down the FN key and press the corosponsding Function. The Wi-Fi function key usually has the same symbol as the one in the picture above. If all else fails and your WiFi still isn't working you could have a more indepth issue.
Nov 20, 2009 | Compaq Computers & Internet
Where can I find an explanation for the symbols on my compaq presario 2100 keyboard
You can find the meaning of function keys on your compaq presario 2100 keyboard by checking the user manual. Click on the link below:
http://h10032.www1.hp.com/ctg/Manual/c00246219.pdf
Jun 24, 2009 | Compaq Keyboard
Shift key mal function
Your problem is very superior. it is hard ware problem. take this to the hardware shope. otherwise you can use external key board. this is good and simple way. thank you
Jun 17, 2009 | Computers & Internet
Compaq Presario CQ60-211DX keyboard not working
open the laptop and bring out the keyboard .
whash it with Alkohol and after 20 minuts dry it
and after 3 hours install it and test.
if dosent solved i have it .i can send u
Jun 09, 2009 | Compaq Presario CQ60-212US Notebook
I need help in understanding the keyboard functions
dear,
what does it mean. do you want to know the hotkeys of just want to speed up your typing speed.
if you mean is to speed up you typing speed. then use softwares like typing tutor etc. i used typing tutor 6. it is an old version but is simple too. now i can type very fastly.
or if you want hotkeys then visit this links:
http://users.sa.chariot.net.au/~kday/keyboardtips.html
http://www.helpwithpcs.com/tipsandtricks/keyboard_shortcuts_microsoft_word.htm
http://wiki.blender.org/index.php/Manual/Hotkeys/Hotkey_Keyboard_Map,
the last one is impressive.
regards,
salman
Jul 22, 2008 | Computers & Internet
Compaq C770
Your computer has a program on it called quick launch. It could be that the function key won't work until the program is loaded up into the memory of your computer.
Jul 16, 2008 | Compaq Presario 700 470024-192 Notebook
Scrambled keyboard
Is it giving you numbers and symbols? do this: Press and hold the function key fn while pressing the num lock key num lk . This will deactivate the integrated keyboard/numeric keypad, and the keys will respond normally.
Please remember to rate all users who assist you for free :)
Jun 30, 2008 | HP Compaq Presario V6000T Notebook
KEYBOARD
check your keyboard region setting
Apr 21, 2008 | HP Compaq Presario C500t Notebook
Intel Dot Station (INTC300AIO) PC Desktop Logo
64 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
