Question about HP Photosmart 8250 InkJet Printer
Paper mismatch paper size to small choose a large size
I have done what they posted to the troubleshooting site but it still will not print my 5.75 x 8.9 envelope. Is there something else to try or can I turn that feature off? This is a hp photosmart 8250.
  • Anonymous Dec 13, 2008
    I recently have the same problem. Cannot print notecard envelopes (4.5 x 5), which I've been able to do hundreds of times with my HP Photosmart 8250....all of a sudden it gives me the error message that the paper size is too small. I do recall not too long ago I downloaded an automatic HP update and wondering if HP didn't screw it up.
    Problem Solver:
  • 6 Answers
There is a workaround for this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Deny
Posted on Jun 27, 2009
I am trying to print invitations size 5.5 by 8.5 on my HP Puotosmart C5580 printer and I am having a problem. It keeps telling me that I have the incorrect paper. Would you please advise? Thanks
Go to HP Solution Center
Click Printer Settings
Click Printer Preferrences
Go to Paper Size
Look for the size of your media or
choosee Custom
Then type the width and length of the paper
then save it
change paper type to plain paper
then got to Printers under control panel of your PC
right cick on the printer icon then choose printer properties
click printer preferences
got to features tab
Go to Paper Size
choosee Custom
then save it
then try printing again
you can also refer to the link below for additional info
'Paper Mismatch,' or 'Paper Size Mismatch' Error Message Displays When Printing in Microsoft Word
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01824353&cc=us&lc=en&dlc=en&product=3575276&tmp_track_link=ot_search
'Paper size mismatch' Message Displays on the HP Photosmart Printer
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01631553&cc=us&lc=en&dlc=en&product=3575276&tmp_track_link=ot_search
Hope I help you a bit.
You can also send me questions on my
personal email - christian4122@yahoo
Your's Truly,
Christian from HP
Mar 27, 2011 | HP Photosmart C5580 All-In-One InkJet...
When I try to line tells me that the paper size mismatch and only takes a copy of the text
Have/had the same problem: Getting "paper size mismatch" on the C4280 status screen, after we got a paper jam. Every time we hit OK and put in paper, Message about "Now printing Alignment page", it feeds through quickly, with nothing printed on the page and reverts back to Paper size mismatch. Finally got rid of the error, not sure how, but now when I try to copy anything, we only get the lower right postion of the document that I'm trying to copy. Printing from the PC seems ok.
Powered off and back on, and it is back to P"now printing alignment page, quick feed through and "paper size mismatch" error. AND
When copying directly from the glass panel,it will only print a quarter of the page -however it prints and coorectly if we print directly from the computer.
The problem is the paper size sensors. Remove the plastic access panel that is for access to the rollers in the back and has 4 rollers on it. There are two papaer sensors attached to the printer circuit board (PCB). The control arm for the sensor is a small plastic piece that extends slightly into the paper path above the PCB. The plastic can be broken when you are removing a paper jam. I stuck a small piece of a match stick in the sensor to keep it open (as though a wider piece of paper was passing throught the printer). I can't switch to smaller card stock, etc, but who cares, it works.
The copying problem is caused because the C4280 will not scan correctly until after it does the alignment phase.
Dec 16, 2010 | HP PhotoSmart C4280 Laser Printer
Paper mismatch will not go off
here is a simple way to print off that.
open printers and faxes from control panel.
right click on your printer icon and select printing preferences, on printing preferences window click on features tab.
select paper size as custom and it will open a new window to enter the size, enter the width and length of paper you want to print on and type Name as size1 and click on save, now again select more from paper size and selec size 1 (just saved) and click on Ok on printing preference and you are ready tp print,
best of luck!!!!!!
May 02, 2010 | HP PSC 2175 All-In-One InkJet Printer
How can I print envelopes on my HP C5180. I've had it over 2 years and have never been able to get it to print any size envelopes. I always get a 'paper mismatch' message. HP tech support has never...
I tried all of the suggestions on here and nothing worked. My envelopes are 5x7.3. So, I finally just put in 5x7 and lo and behold, even though there truly was a paper mismatch this time since that was NOT the size of the envelopes, they printed. I did have to move the text boxes some to make them print correctly. So, I guess the solution for my printer is to actually mismatch the size of the paper/envelope so that you will NOT get the "paper mismatch" error message. Will it work on other size envelopes? I have no clue. This is the first time I've ever been able to print an envelope at all with this printer that I've had 2 or 3 years.
Dec 05, 2009 | HP Photosmart C5180 All-In-One InkJet...
Smeared print on paper
I was getting a similar blur/blob down one side of the paper (with no discernable print anywhere,) but after removing and emptying the toner collection bottle my printing returned to normal. I am still working on the size mismatch issue, which seems to be prevalent in the 2300DL population.
Aug 25, 2009 | Office Equipment & Supplies
Paper size mismatch - c5280 hp all-in-one printer
I got around this problem by tricking the printer. The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job. What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job. Here is the tricky part... one the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11 I hope this helps.
Deny When the 8.5x11
Jun 03, 2009 | HP Photosmart C5180 All-In-One InkJet...
Mismatch paper size error
Click on Print, then Properties, then features.
About half way down there is a drop down box under sizing options.
Click on custom
Create a name, and put your width and height in.
Click Save and then OK
Completely X out of the print options.
Then Click
File, print
on the bottom of that screen there should be a scale to paper size drop down box. Scroll to the bottom and your saved name and dimensions should be there.
You will have to setup each individual sized template ones and then just scale to fit each time. Hope this helps
Mar 26, 2009 | HP Photosmart C4480 All-In-One InkJet...
The images are too big.
go to the printer perference or setting on your pc, there is option says scale to fit the page, click it , and some of printer allow you to select the paper size you are using. its simple problem its just driver setting issue.
Good luck
Mar 19, 2009 | Dell Office Equipment & Supplies
Paper Mismatch
I had this problem on the 6300 and was able to fix it by doing the following:
After selecting print, select preferences.
Select the Features tab.
Under Resizing Options, select "Custom" from the drop down menu.
Put in the custom dimensions of the paper on which you are printing.
Save it under a new name (e.g., "Invitation")
When it is time to print,
Select "More" from the drop down tab under Resizing Options.
At the bottom of the list of those options, you will see your custom sized saved.
Select it, and happy printing.
Mar 11, 2009 | HP DeskJet 5550 InkJet Printer
HP Photosmart 8250 InkJet Printer Logo
372 people viewed this question
Ben Johnson
