Dismantling a flat screen
I am packing and trying to put my flat screen monitor into its original box. But I fail to remove the foot (or base?) of the screen. Thanks for the help.
  • rinasolofo Dec 12, 2008
    Thanks a lot. I got it fixed.
  • Anonymous Jan 11, 2009
    I cannot remove the part that connects the monitor to the base, it is just staying there. I know there is a symbol of a lock on the back with a hole that looks like a screwdriver can go in there, but thats showing no results.
  • 38 Answers
Depending on the model the base would be removed by the clips on the underside, push them in and lift the base off,
if the whole stand comes off there will be a catch on the back of the monitor under neath/behind where the hinge connects to the screen, you may have to pull hard but don't apply too much force or it may snap
Hope that helps you
Posted on Dec 12, 2008
  • Smoking_gnu
    Smoking_gnu Dec 12, 2008
    No problem,
    glad i could help!
How to remove base from gateway hx2000 monitor
You need to find the original instructions for putting the monitor together, or you could accidentally break the base from the monitor if you attempt to remove it the wrong way. Try Google.
Jul 11, 2014 | Gateway HX2000 20" Monitor
I need to remove the viewsonic VX2433wm stand.
mine has 4 silver screws running perpendicular to the stand shafts, remove the 2 pairs and the stand should slide out the bottom.
Mar 17, 2013 | ViewSonic VX2433WM 24 inch LCD Monitor
LCD screen totally white when turn on
The HP is a flat screen monitor used with many desktop computers. When the LCD on your HP monitor goes white, it is an indication that your monitor's inverter board has gone bad. The inverter board is a small circuit board that transfers power from the monitor's main circuit board to the LCD screen. Replacing the inverter board means dismantling the HP monitor.
1. Power down your computer and unplug the HP monitor cable from the back of your desktop. Disconnect the power cable from the back of the monitor. Relocate the monitor to a flat work surface. Place the monitor with the screen facing downward.
2. Remove the Phillips-head screws from the monitor's base stand and from the back cover. Lift the base stand off of the monitor and remove the back cover. Peel away the foil from inside the monitor around the internal circuit board.
3. Locate the inverter board near the bottom of the monitor's casing. Unplug the power cables from either side of the inverter. Loosen the Phillips-head screws from the inverter board. Lift the old inverter out of the monitor's casing and set it aside.
4. Place the new inverter inside the monitor. Replace the Phillips-head screws and fasten it in place. Reconnect the power cables to the connectors on each side of the new inverter. Replace the foil around the outside of the main circuit board.
5. Replace the back panel and base stand, and their retaining Phillips-head screws
I hope you find it very helpful.
Thank you for choosing fixya.com
Aug 11, 2011 | HP Computers & Internet
How do i take the stand off a toshiba 32AV635D to wall mount ?
On my 32AV635D there are 4 Allen bolts in recessed holes on the back cover. Remove these (but no others!) and the stand just slides out. Under the base of the stand there are two more Allen bolts which fix the metal brackets to the stand. Removing these will enable you to pack the whole thing into its original box (which you kept) so you can put it on Ebay when you get a bigger model :-)
Sep 16, 2010 | Toshiba Televison & Video
Need to pack up flat screen monitor into original packaging. Do not know how to take off the stand or how to fold. Suggestions?
On the ack of the Monitor there should be some screws holding the stand in place. With a screw driver simply undo the screws and pull th monitor away from the stand. This should allow you to place all the pieces back in the box properly.
Sep 19, 2009 | Acer AL15110 15" Flat Screen LCD Monitor
Fit in box
If it is into the original box and you still have all the packing then first step would usually be removal of the monitor base.
With CRT monitors the base usually pushes to the back and it is best done with the monitor upside down so that you can check for any locking tabs that may need to be pushed open.
Once the base is off you will find it easier to see on the packaging how it should fit..
Drop the base packing into the box first and then the monitor followed by the top packing.
there is usually a space for the base on the top packing.
Sep 15, 2009 | LG Computers & Internet
Can't fit LG monitor back in box
Usually there is either a panel that covers the screw attachments on the back or the panel covers the bottom of the base or foot and the attachment screws are there, but most monitors have panels that cover the screw attachments.
Sep 15, 2009 | LG Flatron F700P 17" CRT Monitor
How to detach the screen from the base.
Here is what I did on my last 2 moves with a 22" LCD.
Just wrap it in soft blanket like velour or a comforter and put it in a box so it doesn't move around. You could take off hte base but usually at risk. Most of those bases clip on and aren't really easy to slide out or meant to take back apart. You risk more damage taking it out apart then just wrapping it securely and putting it in a box.
May 29, 2009 | ViewSonic VE170m (Beige) 17" LCD Monitor
How to remove back panel
there might be screws behind the foot. remove the foot base first...then look to see. alot of these screens are pressure tab case fasteners.they use screws to lock in the cover. after that a smakk flat screwdriver along the lower sides will reveal is the cover is tab fixed .\
good luck
May 18, 2009 | ViewSonic VX922 19" Monitor Flat Panel
Acer 1717 monitor- removal of base
At the base you want to remove - in order to pack the monitor - if you se at the rear left and right there are a tiny opening about 3 cm long,put inside a screw driver and it will open very easly the plastic cover.Then inside there are four screws,two on each side,remove them and the arm of the screen will be dis-attached.
Dec 21, 2008 | Acer Al2416WD LCD Monitor
Computers & Internet Logo
1,189 people viewed this question
David Payne
David Payne
