Question about Acer Computers & Internet
How to install memory upgrade for acer aspire 5315-2698 ICAN NOT GET THE PANEL TO OPEN TO GET TO THE RAM SLOTS
  • Uwe Klopfer
    Uwe Klopfer May 11, 2010
    if you are sure you have removed all the required screws thenyou need to use more force...
    i am not too sure, but i think some of the brand name PCs ( ACER and i know for sure HP ) you actually remove the side panel by removed the front panel first...
    President:
  • 1,073 Answers
One othe slots for memory is under your laptop, and the other one is under you keybord. The one under you can reach by loosing the screws to the hatch. The one under your keyboard you can reach by remove your keyboard, the screws to remove the keyboard is behinde your laptop, they are on the hinge.
Be VYRY VERY carefull when you removing the keyboard, its al plastic and very very easy to break. Loose the screws on the both hinge, pull the keyboard backwards and up.
As i sayed before, do it very very carefull.
Good luck to you
If you find my answer helpfull, dont forget to vote
Posted on Dec 12, 2008
How ato install additional memory in a aspire x3910
you open the side panel and make sure the machine is unplugged, install the new memory module into one of the free slots next to the fan on the mainboard.
Feb 28, 2011 | Acer Aspire X3910-U3012 (PTSED02010) PC...
Installing ram memory
well inserting another memory in a laptop needs a techical assistance but if you're willing to do it on yourself, unscrew the bottom of the laptop then find the small rectangular bar around and you can see the empty slots beside it, that is where you should insert the memory then put everything back into place and there you go.
any queries?you can ask me again
thanks and God bless.
Jun 02, 2010 | Acer Aspire 3680 Laptop
HOW DO I install new memory in acer aspire L320
First step would be to lookup your system specs either in your manual or at the Acer website. See what RAM is compatible with your system. Once this is done purchase what you need. Open the case and you should see the RAM modules & slots. If you are replacing RAM you will need to remove the old first. If you are adding to empty slots just line it up properly and seat it in the open slots. Close the case and reboot. System should automatically recognize the new specs. Make sure you disconnect power and properly ground yourself before touching anything inside your case. Hope this helps.
Oct 16, 2009 | Acer Aspire L310 - Core 2 Duo E6300 1.86...
Install new ram in Acer aspire L320?
Sorry- I have to disagree, One screw at the back releases the lid. Inside, the dvd/hdd sub-chassis has one screw holding it to a brass post on the mobo. Undo that, then lift the chassis slightly with it's plastic strap handle, so you can detach the two connectors from the SATA drive, and the ribbon cable to the DVD (careful you don't bust the latch).
Then the whole lump simply lifts out- and you can see the 2 memory cards. The one I've just looked at appears to have 2 x 512mb simms- so you could replace these with 2 x 1024mb DDR2 SDRAM simms, to give 2GB of ram, which is what Acer say is maximum.
Cheers- AL (Luton)
Apr 03, 2009 | Acer Aspire L310 - Core 2 Duo E6300 1.86...
I FOUND 1 MEMORY SLOT
Hi there.
The memory slots are more or less on top of each other.
Good luck and thanks for using FixYa!!
Mar 16, 2009 | Acer Aspire 4315 Notebook
Removing RAM from Acer L320
look at this link:http://www.crucial.com/store/listparts.aspx?model=Aspire%20L320
or go to crucial.com and use the memory scanner,its terrific!hope it helps!
Oct 30, 2008 | Computers & Internet
Memory upgrade
There are 2 memory slots in Acer L320. You can use program called cpuz to check how many memory modules are you using, and what size are they.
If you have any module free you should be capable to upgrade memory.
May 31, 2008 | Computers & Internet
Acer L100 memory upgrade
you can open it up and see, take out the ram to see what kind it is
Dec 24, 2007 | Acer Aspire L100 PC Desktop
Computers & Internet Logo
149 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
