The start up switch is not working on my hp604x
  • 449 Answers
Hello, for your start up switch to work you will need to take your system to a repairer becaus eyou cant fix it yourself.
Posted on Dec 12, 2008
The buzzer wont stop when the cycle is done, it runs with the door open, and runs without pushing the start button.
"Tested start switch and it appears to be working normally". You need to be absolutely sure if the start switch is working and isn't sticking, which it sounds like. Isolate the start switch completely and then check it again with your DVOM. Make sure the switch moves easily without sticking.
Dec 08, 2014 | Whirlpool Dryers
Start stop switch
1. Can you open up the drill?
2. If you can open up, check the area around the switch. Make sure nothing is obstructing the operation of the switch.
3. If things are normal, you need to check if the switch is working or not. You need a multimeter to check. If it is not working, you need to replace it.
Jul 06, 2014 | Drills
Suzuki intruder problems
You need to bridge the start button, If things work i.e. decompression relay and start relay pulls in then its the button fault. If not then you'll have to work your way through the clutch micro switch, side stand switch, gear selector etc. If in gear and side stand switch doesn't make, it won't start, so try starting it with side stand up. If it starts then the fault is with the neutral switch. If you eliminate all these and no joy, repost with more detail. Hope this helps.
Nov 30, 2013 | Motorcycles
Start button wont work
check the door switch and check if the power comes to the panel. If not the switch is faulty. If the switch works but the panel does not start even after the push switch is working then it is possible that the processor is not working. check the working of the touch pad switch, this is also seen as a regular failure as this is the most used switch.
Sep 26, 2012 | Washing Machines
I have no working headlights and the starter won't work
Hi and welcome to FixYa,
On a VT1100, primary suspect would be the START button switch (not the ignition/key switch). The start button switch is actually made up of 2 switches:
  • in normal condition it switches power to the headlight dimmer switch;
  • when starting, power is switch OFF to the headlights to ensure that the starter gets all the power from the battery.
Good luck and thank you for asking FixYa.
Oct 05, 2009 | 1999 Honda VT 1100 C3 Shadow Aero
Kenmore Dryer (Model #11073952101) starts, but WON'T stay ON
your motor maybe going out. theres a switch on the motor that starts it . on most models the start switch is built into the motor. however some models the switch can be replaced by itself.
Aug 30, 2009 | Kenmore 73952 Gas Dryer
I think rotary start switch just went out
Either your start switch is out or the motor's out. Check the continuity on the switch first. Hope this helps!
Aug 14, 2009 | Dryers
GE dryer starts but..... stops
The motor switch is not working properly. You can try removing lint from motor area around the end where the wires attach. This may free switch. If it still won't work you need a motor.
Nov 14, 2007 | Dryers
Computers & Internet Logo
David Payne
David Payne
