Question about Lexmark E330 Laser Printer
Lexmark E330 Paper does not feed, but jam light comes on. Appears to be some kind of mechanical problem related to feeding the paper into the transport mechanism, or perhaps an issue with sensing mechanisms determining operation status.
I had a similar problem, On inspection I found out the rubber wheels in the paper tray section were missing ( Some kinda manufacturing fault) (or somebody played a very absurd joke on me) anyways I put rubber bands on those plastic rollers and Viola its perfect...
Procedure:
1. Remove paper tray
2. turn your printer upside down
3. u will see two wheels connected with a lever
4. check if they have rubbers on them
5. if not , role a rubber band on them .
hope that helps...
Posted on Apr 08, 2009
It wont feed the paper it keeps say paper jam but the paper is not even going in
Lexmark Impact S301 Printer won't take the paper -
printersquestions.com/lexmark-impact-s301-printer-wont-take-the-paper....
Dec 19, 2013 - Feeding paper is the first step of printing materials. However, what will you do when the Lexmark Impact S301 Printer won't take the paper ...
Paper Jam Troubleshooting on 2009 Printers - Lexmark
support.lexmark.com/index?pmv=print&page...en...
LexmarkLexmark Impact S301, Lexmark Impact S302, Lexmark Impact S305 ... When troubleshooting paper jams on Lemark's 2009 printer models, make sure you also ...
[PDF]Solving paper feed problems - Lexmark
www.lexmark.com/publications/pdfs/w820/eng/prfedprb.pdf
LexmarkUse the following table to find solutions to paper feed problems you are ... For detailed instructions on clearing paper jams, see Clearing print media jams.Missing: impact ‎s301
How To: Clear a Paper Jam on a Top Feeding Lexmark ...
? 2:30
https://www.youtube.com/watch?v=H1-J1xDbDsY
Jan 14, 2016 | Lexmark Impact S301 Wireless All-in-one...
Paper will not feed
Paper feeding problems can be related to the media (paper) condition,paper jams or paper quality or the printer.
1.Remove any jammed paper from the your printer.
2.Lift any covers and lids, and wipe the rollers with a soft, damp cloth. A light colored cloth will help you identify dirt that comes off the rollers.
3.Use fresh paper for your printer. Use dry, flat paper. Don't overfill the tray. Discard any paper that curls or is wrinkled.
Aug 29, 2012 | Lexmark P6250 All-In-One InkJet Photo...
My Lexmark E330 printer is showing a paper jam, but no paper is jammed.
When you removed the jambed paper, did the paper come out in one piece, if not did all the pieces that was removed make up the entire sheet of paper?
Otherwise there may be still a small piece/s of paper still in the printer which is causing this error message.
May 04, 2011 | Lexmark E330 Laser Printer
Hello the paper feed roller is not pulling the paper down evenly. It appears that the bar on the left paper feed wheel is out of line. how can i access the rollers to rectify this
This article in the Lexmark website on How to Remove and/or Avoid a Paper Jam in your Lexmark X5300 & X5400 & X5600 Series All-In-One might help resolve the problem. However, if the paper feed roller is visibly "out of line" causing it to mechanically fail, I would strongly suggest you contact Lexmark technical support for assistance.
Apr 18, 2011 | Lexmark X5470 All-In-One InkJet Printer
Erre lights on Lexmark E330 what is second one from bottom?
error light on out of paper also toner light is flashing but its a new toner kit and there is no paper jam
Sep 30, 2009 | Lexmark E330 Laser Printer
Canon Stylus C64 paper jam
try this link below. Although the printer is lexmark but it can used the idea to solve the problem regarding paper jam issue.
http://www.lexmark.com/publications/pdfs/lexmarkt522/eng/paprjams.pdf
Thanks
Jul 31, 2009 | Epson Stylus C64 InkJet Printer
Paper jam error, but no jam present
mabey its the wrong paper youre putting in it:O?
Jan 03, 2009 | Office Equipment & Supplies
Lexmark E330. Progressive paper feed problems. Typically jiggling the paper in the tray, and fiddling with the back spring loaded light blue paper guide in the back of the tray fixes the problem, which...
I would consider two solutions:That there is something blocking the paper path now, and that the pickup rollers are dirty.
First, clean the pickup rollers, and anything that looks like it helps with feeding paper. Use some rubbing alcohol and a clean cloth. Getting it clean and 'grippy' (like rubber should be), should solve the pickup and feeding problem, unless there is blockage. The E330 isn't too hard to take apart, and searching online for a Parts Guide isn't too difficult.
Also, make sure that the paper guides in the tray are snug with the paper.
Dec 12, 2008 | Lexmark E330 Laser Printer
PAPER JAM
The problem sounds like your rollers have lost their grip. Remove the paper tray and tip the printer up. Push the red lever on the left of the printer down and you will see the feed mechanism with two wheels. Remove the rubbers on the wheels and turn them inside out. Replace them on the wheels with the worn side now inside and the 'sticky" side out. You should get at least another couple of years worth of use before you need to replace them.
Aug 22, 2008 | Lexmark E232 Laser Printer
My printer jams frequently
More info is needed where does it jam ie. going to print from paper tray or coming out of the fuser in back before it comes out on top?
Feb 26, 2008 | Lexmark E330 Laser Printer
Lexmark E330 Laser Printer Logo
441 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
