Question about Toshiba 32A33 32" TV
TV keeps turning its self on and off.
The clicking sound seems to come from the back left hand side of the set
This is the powers supply attempting to turn the set on.
There is an overload, maybe in the HT transformer, or some capacitors are faulty.
Its an engineer jobby
Posted on Dec 12, 2008
Samsung tv ln32d450g1 the menu does not show any option to configure network settings
That is my problem here are the menu options I have
picture mode
sound mode
antenna
plug and play
e-manua
within each option there are subtitles but nothing that refers to network
Nov 10, 2016 | Samsung Televison & Video
Connecting laptop to tv...sound but no picture
u have to go back and click start look for control panel than click on display on your left hand side click on connect to a projector and select to duplicate the image on your tv
May 08, 2014 | Dell Latitude E5400 Notebook
Dark Screen
It sounds like a back-light problem. Check all the CCFL back-lights.
May 08, 2013 | Samsung LN52a750R1FXZA
How do I connect external speakers
    Connecting Full-Size Speakers
  1. Step 1 Insert the red and white plugs on a set of RCA audio cables into the right and left audio "OUT" jacks on the back of the TV.
  2. Step 2 Connect the other ends of the cables to a free pair of audio "IN" jacks on the amplifier.
  3. Step 3 Strip 1/2 inch of insulation from the speaker wires, and connect a pair of wires to the left and right terminals on the back of each speaker using the red wire for the right audio connection and the other wire for the left.
  4. Step 4 Connect the other ends of the speaker wires to a pair of stereo speaker terminals on the back of the amplifier. The wires attach by raising spring-loaded clips on the back of the amp to reveal a hole for inserting each wire.
  5. Step 5 Set the amplifier selector to the set of audio jacks connected to the TV to enjoy stereo sound from the television.
  6. Connecting Self-Powered Speakers
  7. Step 1 Insert the RCA plugs on the Y adapter into the TV's Audio "OUT" jacks.
  8. Step 2 Connect the mini-plug on the wire attached to the right-hand self-powered speaker to the mini-plug jack on the Y adapter.
  9. Step 3 Plug in the audio cable and mini-plug from the left-hand speaker into the Audio "OUT" jack on the back of the right-hand speaker.
  10. Step 4 Connect the AC adapter to the power jack on the back of the right-hand speaker, then plug the adapter into an electrical outlet.
  11. Step 5 Switch on the external speakers and adjust the volume.
Jun 01, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
Tv keeps turning its self off
Many issues can cause this, there is no simple answer, but one common issue is the convergence circuit failing. The set will need repaired.
If you are handy with electronics you see if the convergence ic's are failing, usaly on these there is a short jumper connector from the right board to the middle board closest to you from the back, if you disconnect this connector from the back and the tv comes on it is a convergence ic problem. In this case you need to replace the ic's on the convergence board the two stk392 ic's plus check the resistor.
Sep 01, 2009 | Hitachi 53UWX10B 53" Rear Projection...
TV KEEPS CLICKING.ACTS LIKE CUTS ON AND OFF REPEATLY
Check for leaky capacitor in the switching relay area
Aug 17, 2009 | Samsung LNT5265F 52 in. LCD HDTV
Tv keep going on and off
I have done some research and found a notorious cap and diode problem with this set. The two 4700uf caps (C14113 and C14115) on the DM1 power board (the board to the left of the sat. box when you look at the set from the back) are under rated and will eventually fail. When these caps fail they tend to take out diode CR14105. This may be your problem. If it is, you can replace the caps with 4700uf 25V 105c and the same as original diode.
Mar 15, 2009 | RCA F38310 38" TV
Bush LCD TV No picture but sound
replace 2 large caps on psu panel 1000uf caps lt feed to inverter panel caps are on right hand side of psu panel
Dec 15, 2008 | Televison & Video
Clicking Noice after replacing shattered color wheel, ballast and lamp...
Not sure if this will help but I read in the manual that if you have
a clicking sound that the cable setting and the air setting are both turned on...Good Luck
Jun 04, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
LG LC55 humming/buzzing
Have you tried adjusting the contrast? , have a similar problem with a 42'' lcd and it appears to be related to the contrast setting .If is set my contrast below 90% the buzzing sound stops.
This buzzing sound seems to be a common problem with LG TV's
Nov 24, 2007 | LG 42PC5D Television
Toshiba 32A33 32" TV Logo
64 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
