Question about Lexmark E330 Laser Printer
Lexmark E330. Progressive paper feed problems. Typically jiggling the paper in the tray, and fiddling with the back spring loaded light blue paper guide in the back of the tray fixes the problem, which typically is no more than feeding two or more sheets at the same time, thereby jamming the paper transport mechanism. Since several hours ago, this solution no longer works. In fact, the jam light comes on and no sheet of paper has been fed into the transport mechanism at all. I can't see very far into this part of the printer, but by hand feel, there doesn't appear to be any ripped piece of paper preventing the paper from feediing. Except now it is isn't feeding at all. This suggests that there is some kind of hardware failure which is not moving the top sheet of paper into the paper transport mechanism. I can take anything apart, but don't have the slightest idea what I should be looking for, or if any internal adjustments or replacement parts are required.
    Problem Solver:
  • 7 Answers
I would consider two solutions:That there is something blocking the paper path now, and that the pickup rollers are dirty.
First, clean the pickup rollers, and anything that looks like it helps with feeding paper. Use some rubbing alcohol and a clean cloth. Getting it clean and 'grippy' (like rubber should be), should solve the pickup and feeding problem, unless there is blockage. The E330 isn't too hard to take apart, and searching online for a Parts Guide isn't too difficult.
Also, make sure that the paper guides in the tray are snug with the paper.
Posted on Jul 16, 2009
The "add paper light" is on even though the paper
The light means that the printer is out of media, or the media did not feed properly
What you can do
-Load media into tray and press Continue button to resume printing.
-Check that the media is loaded correctly in tray
-Press Cancel button to cancel the print job.
Jun 29, 2011 | Lexmark E232 Laser Printer
Duplex paper jam . i thought i took out the paper that was jammed and i am still getting that message, PLUS now I cannot the top tray back.
The duplexer, which flips the paper to automatically print on the back side, slides into the back of your printer. Unplug the printer and slide the duplexer out to check it for jammed sheets. You might have pulled out a sheet or two in the main printer section and left one in the duplexer.
As for the top tray, the paper feed wheels ride on the end of a long lever that drops down to rest on the paper. It should be held up out of the way by a spring until the drawer is inserted, but sometimes the plastic nub that the spring pulls on breaks off. Lexmark sells a little kit of the spring and "bellcrank" to fix it. If your paper tray holds 500 sheets - a whole **** - you need part no. 56P1331 "Parts packet, bellcrank and spring, 500 sheet." For 250-sheet trays the part number is 56P1337. A web search for either part number will find you a seller.
Sep 20, 2010 | Lexmark T632 Laser Printer
Paper won't feed. It's in the back stand up area
i have had this problem with a few Lexmarks. try a lighter weight paper or lessen how much your loading into it. also make sure nothing is in the bottom of where you load the paper (example: there is a pencil in there and the paper is sitting on the pencil) If its new take it back and exchange it. when it loads the paper the bottom of the tray tilts forward. that may be faulty.
Oct 21, 2009 | Lexmark Z1320 InkJet Printer
Erre lights on Lexmark E330 what is second one from bottom?
error light on out of paper also toner light is flashing but its a new toner kit and there is no paper jam
Sep 30, 2009 | Lexmark E330 Laser Printer
I have a Brother Intellifax 4100 Fax machine. I may have pulled the paper cathrudge out to abruptly because a 3/4 spring was dislodged from somewhere - I have not identified where it belongs. As a...
best guess is it belongs under the paper lift plate in your paper tray, remove the paper tray and all the paper, there should be a metal paper lift plate in the paper tray, these are typically spring loaded to lift the paper into place. lift the plate and check the underside for the location of the spring, there is usually a retainer of some sort to hold the spring in place. once the spring is in place the tray should feed correctly.
Hope this is of some help.
Ed
May 09, 2009 | Brother IntelliFAX 4100 Laser Fax
Lexmark E330
I had a similar problem, On inspection I found out the rubber wheels in the paper tray section were missing ( Some kinda manufacturing fault) (or somebody played a very absurd joke on me) anyways I put rubber bands on those plastic rollers and Viola its perfect...
Procedure:
1. Remove paper tray
2. turn your printer upside down
3. u will see two wheels connected with a lever
4. check if they have rubbers on them
5. if not , role a rubber band on them .
hope that helps...
Dec 12, 2008 | Lexmark E330 Laser Printer
Lexmark T632 says "Load MP Feeder Letter
Hi Pqpoppa,
Check the paper size setting in the printer. Set it to the paper size you normally use such as A4 and the default tray. Check the default paper size in the printer driver in your computer and the default tray. Finally, check the paper size of the document you are printing. If all these match, it should not try to be smart and ask you to feed paper.
Rgds
S88
Nov 03, 2008 | Lexmark T632 Laser Printer
Lexmark Optra T612
The broken part is called the bell crank arm part number 56P1228 this is very common. If the printer isn't recognising your tray, remove it and check the little plastic fingers on the left side (half way down the tray) and the metal springs in the printer (left side) which the tray pushes on to.
Aug 04, 2008 | Lexmark Optra T612n Laser Printer
Paper jam
I too have this infuriating problem and the reason has already been pinpointed very well it is indeed the front rubber pinch cam not grabbing the paper well. I have approached this problem from another angle... under the front sprung loaded flap on the paper tray
there are two compression springsapprx 1/2" in dia. Gently prise apart the 2 flap pivot (on the extended arms) to gain access to the springs ,pull out the springs and either replace them with slightly stronger ones or pull the existing springs apart to retension them and pop them back (long-nosed pliers or tweezers) this will restore the spring tension lost during use with the rubber pinch cam.
Jabba0737
Mar 10, 2008 | Samsung CLP 300 Laser Printer
My printer jams frequently
More info is needed where does it jam ie. going to print from paper tray or coming out of the fuser in back before it comes out on top?
Feb 26, 2008 | Lexmark E330 Laser Printer
Lexmark E330 Laser Printer Logo
593 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
