Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Need to know the petrol consumption on the 1994 automatic v6 3000
And its fuel tank capacity.
  • Mitsubishi Master
  • 5,138 Answers
If this set uses gas i would like to see that!!!!!! The answer 0000000.
Posted on Dec 12, 2008
Fuel consumption on petrol engine
Check the following:
1. Element air cleaner.
2. Tyre inflation.
3. Brakes engagement all the times.
4. Fuel pump pressure.
5. Fuel system.
6. Ignition system.
7. Oxygen sensor.
Nov 28, 2013 | 1994 Toyota 4Runner
Need to know an average fuel consumption on a nissan xtrail 2010 in a petrol and diesel both are autometic
The Nissan X-Trail was distributed to Australia through Nissan Australia. The fuel consumption figures for the different engines are below.
Petrol: 9.1L/100km
Diesel: 7.4L/100km
Oct 02, 2013 | Cars & Trucks
My bike is bajaj CT-100 i have a problem with my petrol tank.It is 10L total capacity, 2Lreserve capacity but i filled tank with 3L and put my cark on and it was totally empty on ON only it does not drop...
please change the tank valve and regulator. and check the fuel indicator is working properly. Go your nearly baja service point I hope they should help you.
Aug 17, 2011 | 2006 Bajaj CT 100
Obvious things first. replace your air cleaner, fuel filter and put in a good quality fuel injection cleaner. do this for at least two fuel tank loads. Clean the injectors and make sure your engine is tuned. It will be fine after that...
Jan 18, 2011 | 2000 Daewoo Nubira
How big is the gas tank on a 1992 ford crown vic. how many miles to the gallon. my gas gauge doesnt work. so i dont know anything about the gas.
1992 Ford Crown Vic 4.6 L V8 Automatic
Fuel tank capacity is 20 gallons (US).
Your fuel consumption will be affected by many factors, such as :
- how you drive the vehicle
- the condition and tune of the motor
- driving conditions (traffic, city use, highway use etc)
- tire pressures
- type and grade of fuel used .
It is impossible for me to estimate what fuel consumption you can expect from your own particular car without a whole lot of information.
It's unwise to run the vehicle for long with no working fuel gauge.
Dec 17, 2010 | 1992 Ford Crown Victoria
Are all petrol tanks the same size or does it go on the size of ur engine .
Assuming you are asking are all Petrol tanks same size on VW Golfs... if thats the question then the answer is YES..The engine size does not affect the Petrol tank size only consumption (kilometers per litre/ or miles per gallon depending your location...assumed since you called it Petrol you are European) The different YEAR models would have different capacities and or shapes depending on configuration of the vehicle.. but the Golfs didnt go under much design change from 99-2002 so you should be safe if looking for a replacement.
Jun 05, 2010 | 2000 Volkswagen Golf
High fuel consumption
Hi There,
If you are wanting to lessen the high fuel consumption you must do the following.
1 - Over-Reving is a big no no. Keep the revs between 2 and 4 thousand rpm. (it is highly easy to over rev so lessen the throttle)
2 - You can buy a product called octane booster. The higher the octane in the fuel tank the better for your car. To use insert into fuel tank as you would a bowser nozzle and release amount of octane as per product intructions prior to filling up with petrol, then add petrol after. This ensures proper mixing of octane throughout tank.
Hope this helps
Cheers Buckaroo,
Apr 16, 2010 | 2001 Hyundai Tiburon
Fuel consumption 1998 carb. 2.6 4x4 isuzu
I would not really recommend buying a petrol engined Isuzu if you are thinking about fuel consumption.I think you will be lucky to get 8km/l and thats being generous.Rather go for a turbo diesel with around the same capacity and you should get between 12-14km/L.
Aug 24, 2009 | 1991 Isuzu Trooper
Fuel Consumption
i have a 97 1.4 civic and i get about 280 miles from a 38 litre tank.has the car been serviced?is the oil level low?jack the car up and make sure all wheels turn freely,if not then the brakes are binding and the car has to pull harder to move,using more fuel.are your tyre pressures low?do you drive it hard?
Sep 15, 2008 | 1994 Honda Civic
I don't know if this is what you're after, but I am getting my Mazda 3 today, and through my research to find one, I learnt that, according to the manufacturer, the fuel consumption on it should be 8 - 8.6 liters per 100 kms. I don't always know how accurate these are, so, I usually just fill up the tank, zero the trip, and after my next fill - km / liters to fill tank. 10 km/l is pretty average, anything above 10 is good fuel economy.
Sep 08, 2008 | 2007 Mazda 3
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
32 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
