SAMSUNG LCD TV FAULT
My samsung LCD TV LA32R81B, was working fine during warenty of one year. but on finishing warenty start giving problem. now everything is fine except there is a bright single horizontal line on the screen along with picture. if brightness redused (MOVI MODE) line becomes black in color. it will be a gr8 favour fot trouble shouting this problem.
Ajit V.S.
  • Anonymous Feb 22, 2009
    I have a samsung 26" LCD TV, model =LE26R41BD, it has a picture fault, this is in the form of a vertical line of pixels which (sometimes) appear a different colour to the one which is appearing on the picture, this fault is intermitant, and moves (sometimes the whole line is present, other times just parts are in a different colour) is this problem fixable, if not how much would a repair cost, and which part would require replacement, many thanks, Paul
  • Anonymous Apr 15, 2009
    have line all thru screen, what junk!
Samsung lcd tv 40inch modle .LA 40c 53F1R negitve video and brightness high plz send id mirzarashidbaig126@yahoo.com
Posted on Sep 26, 2013
relectronics
  • 38 Answers
SOURCE: SAMSUNG LCD TV horizontal lines
causing of horizontal lines is leaky or defective capacitors. check big value capacitors around the board at Horizontal area. check the filter capacitor as well. good luck
Posted on Apr 20, 2008
premtech
  • 934 Answers
SOURCE: Horizontal Line through middle of TV screen
That sounds like simple ring-cracks in the vertical circuit, most likely the vertical Ic itself... On the printed circuit side of the Tv look at the vertical Ic and examine it carefully under some magnification where each pin of the Ic solders to the board. See if you can find any cracks in those solder connections.
Bill
Posted on Feb 04, 2009
SOURCE: When I turned the tv on only vertical lines appeared
I talked to a Samsung support helpline and it needs to be taken to a service center for repair.
Posted on Mar 03, 2009
  • 5 Answers
SOURCE: Samsung Plasma TV has horizontal lines of colored dots
I have the same problem, currently searching for a solution. Have you resolved your problem yet? Looking to repair myself, any tips or ideas that you have/expirenced would be greatly appreciated. Thanks, Todd
Posted on Dec 22, 2009
SOURCE: DVD hookup to LCD monitor only appears in black and white!
I have a RCA flat screen television and my dvd player when hooked up is in black and white. How would i fix this and if so plz be more specific then these other people.
Posted on Oct 29, 2010
Samsung lcd la32r81b NOT WORKING ON CABLE
Tuner fault. Contact any service technician to replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 28, 2014 | Televison & Video
Samsung LA32R81B picture is washing mode .why?
T'Con board fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 01, 2014 | Televison & Video
Samsung lcd tv model number la32r81b
what the problem with Samsung?
God bless you
Jul 25, 2013 | Samsung Televison & Video
Samsung 32'' LCD TV backlight works occasionally
Check for any loose soder points or loose connections with wiring sockets to backlight inverter board.
Apr 20, 2012 | Samsung LA32B450 32 in. TV
PC to TV HDMI poor text quality
You get best picture on any LCD monitor or TV when the PC video resolution is set to the native resolution of the monitor or TV. You need to look at your user manual to find out what the native resolution is in PC mode.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jul 10, 2010 | Samsung LA32A450 32 in. HD-Ready LCD TV
My samsung le40r7 tv dont turn on any more i bought it 3 years
Hi I am vortash .. there is a modification kit available for this tv and available from ebay priced about $50 0r £30 depending on your location . It is the start up driver circuit that needs these components on the power supply if you are competant to attempt this .However if not then I suggest that you take it to a local enginner for a free estimate he will at least be able to tell you the fault . regards Vortash
Mar 30, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Our LA32R81B Samsung shut off during thunderstorm&it wont turn on
you probably need a new motherboard or hopefully something that cost less. i had the same thing happen to me with a tv, took it to repair shop and they said needed a new motherboard. good luck
Apr 22, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Samsung 32'' LCD (LA32R81B) is as good as dead
I would venture to say it is the power supply first. Capacitors in LCD power supply's frequently go bad after a year or two. LCD displays very seldom go bad and I have not seen one kill a set completely.
Feb 14, 2009 | Samsung Televison & Video
Samsung 32" LCD (LA32R81B) is as good as dead
Hi, First, you took it to two techs who could look at it, didn't like what either had to say and now you want an opinion from someone who can't look at it? Obviously troubleshooting it long distance is out of the question, so you want a business opinion. OK - So, If I were you, here is how I would look at it. The manufacturer agreed to work with you and you have it in writing based on a diagnosis from one of their trained techs. You do not have to pay for any repair before it is done. Let them fix it and when they tell you it is ready, have them turn it on for you before you pay for it or leave the shop. You are also entitled to any parts that were replaced as you paid for them. If it is not fixed or they indicate there was another problem or more cost you can refuse and go back to Samsung for a remedy. There are laws in most countries to protect consumers from this kind of thing. Good Luck to you!
Feb 14, 2009 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
327 people viewed this question
Top Televison & Video Experts
