Question about Hitachi C29-R30SP 29" TV
Channel and FM display on the top right hand corner
How do I remove the green Channel/FM display from the top right hand corner of the screen of our Hitachi C29-R30SP? It is always showing and we find it instrusive. Thanks in advance. Paul
SOURCE: Hitachi 53fdx01b top-left corner is now duplicating picture
tv has double image color red and a curl line on left upper corner also sometime in middle of tv it has line
Posted on Sep 17, 2009
0 characters
1 Points
How do I fix a Sony TV that starts then screen goes blank
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 24, 2015 | Sony Standard (CRT) Televisions
My 54cm RC-A07 Logik Tv is not tuning and displays a red asterisk next to channel number in top right hand corner of screen
Hi. This might indicate that your TV is eiter in "channel " mode or in "number" mode. Channel is rhe real channel from the transmitter, (being 2-62, S channel) while the number is the one you change by your remote. There must be a way in the menu/tuning where you choose between both.
Oct 06, 2014 | Standard (CRT) Televisions
Can anyone offer any suggestions on how to delete/remove titles displaying in the upper left hand corner of my TV screen and right hand corner? For example, if I am watching a program on CITY, the title...
I believe the "Caption Vision" is selected. By pressing the "Display" button on the remote it should toggle through the choices until "Display Off" appears. That should be all.
Mar 05, 2011 | Sony KV-32S42 32" TV
How to turn off channel number displayed in TV screen
Press " i " (info) button on Sony TV Remote so on-screen display will disappear.
Jun 09, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
If you can program a Comcast remote or another universal remote that has an info key, you can get rid of it. I just succeeded in programming my comcast remote thanks to Dave Taylor:
Once the remote is programmed, hit the "info" button and watch your frustration disappear!
Dec 05, 2008 | Sanyo DS27510 27" TV
Bright green 3 in the upper right corner of my TV
press the display button on your remote.hope this could help you.u
Aug 19, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
press t.v., then info button, maybe hit the info button twice. the green channel number will disappear.
Mar 22, 2008 | Standard (CRT) Televisions
Can not remove the number of the tv channel from the screen
How to remove the green number three from the right corner of the tv screen without having the original remote as the cable company suggested.
Dec 12, 2007 | Standard (CRT) Televisions
Channel display
the option is usually in the menu or controlled by "display" button on the remote
Aug 06, 2007 | Sanyo DS27800 27" TV
Hitachi C29-R30SP 29" TV Logo
Top Hitachi Standard (CRT) Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Standard (CRT) Television Expert? Answer questions, earn points and help others
