Question about Lands Phones
Setting Answer Phone on my Panasonic KX-T7668
I am trying to change the Answer Phone message on my phone but to no avail. I unfortunately dont have instruction manual for this machine. I would appreciate your help. Many Thanks.
  • 2 more comments
  • Jontani Dec 12, 2008
    Because we dont have a manual with the phone I unfortunately dont know what to dial.
  • Carl Navarro
    Carl Navarro May 11, 2010
    If someone calls in from outside and leaves you a message, does it light your message waiting light?
  • Carl Navarro
    what do you dial to get your messages?
  • Carl Navarro
    Let me rephrase that. When you get a message waiting light, PRESS the message light and look at the display. What does it say?
4 Suggested Answers
SOURCE: panasonic kx-tg6051b instruction manual
It is my understanding that the "b" on the model name only stands for black. I searched for your model with out it and found this link for the manual as a PDF. Hope this helps. Daryl
http://www.circuitcity.com/image/product_documentation/manuals/pan/PAN.KXTG6054B.MAN.pdf
Posted on Sep 17, 2008
SOURCE: Panasonic KX-T7668 Name Display
I just managed to do this on my own phone.
Press programme button, enter programme number (**1234), using the up down arrows move to number 004 which should be xtension name. Press clear, to delete any information, then enter new name using keypad. When complete press enter in the middle of the up down keys, pick up and reset handset and it should be stored.
Posted on Nov 20, 2008
  • 14 Answers
SOURCE: Panasonic KX-T7668 Change name displayed on extension??
This facility of changing name is in admin program. when you call up some body their name will bw displayed on your screen. It's fine .tell us that what name other person get.
Posted on Jul 14, 2009
cnavarro
  • 2460 Answers
SOURCE: Time Change
It can be changed from any phone that lets you into programming. We usually give everybody access to make changes like this, but by default, the phone designated as the Manager or Operator is usually given that access. Try ext 101.
When you get there, press PROGRAM **1234. If your display reads SYS-PGM No?, then it will work. Dial 000 and STORE. You will see the Date. Press SP PHONE! Now you will see the time. Dial the new time and press STORE. Press HOLD and PROGRAM to exit or just pick up the handset and drop it back down.
If for some odd reason you can't get into programming from ext 101, then you might have to search for the manager's phone, or call your installer to make one or all of the phones have access to programming.
They can allow you access to other programs, or even give you the installer password to get into all the programming.
Carl
Posted on Oct 29, 2009
Testimonial: "Thanks, great help"
Problem with dead phone kx-T7668 and telephone center TD816CE
The 7668 is designed for the kxtda range and wont work on a kxtd 816you need a Kxtd7431 or similar phoneRegards Steve
Feb 23, 2012 | Lands Phones
Cant operate new panasonic KX- T7668
u dont have voise mail on phone do u
Jan 22, 2008 | Lands Phones
I have kx-t7668 panasonic phone and i can not change the time...Does any one knows how to do it?
When you press PROGRAM ** if you get a busy, you are trying to change the time from the wrong phone. Find the one you can and dial **1234 then 000. It will guide you through a time set.
Carl
Nov 03, 2010 | Lands Phones
Changing Panasonic KX- T7630 Business Phone Answering Message
You don't "lose" the manual, it comes on a CD. The Panasonic system probably has a TVA voice mail system and it requires you to change the Auto Attendant greeting from the message manager's mailbox. If you don't have the passwords for mailbox 998 and 999, you need to contact someone who has them and a layout of the system.
Your Panasonic technician can guide you through the process.
Carl
Apr 23, 2010 | Panasonic KX-T7630 Corded Phone
How to change answering message on my panasonic kx-tg1033 cordless phone
http://www.retrevo.com/support/Panasonic-KX-TG1033S-Telephones-manual/id/2878dj083/t/2/
If you got to the above this is your manual.
Go to page 26 and this will help in changing your answer phone message.
Hope it helps!
Dec 30, 2009 | Panasonic KX-TG5632 Phone
How do I clear the message waiting light on a Panasonic KX-T7668 telephone when there is no message and the light is staying on
Not true, there has to be a message or it wouldn't be lit. Try *700 and your extension on the intercom. It clears *all* messages from everybody to that phone.
In the family of 76xx phones, you can also press the MESSAGE button and look at the display. It will tell you who the message is from. On the phones with soft keys, one of the buttons will be the CLEAR feature.
Carl
Sep 01, 2009 | Panasonic KX-T7730 Corded Phone
Time is wrong
The time is set from the master phone (usually 101) by the 000 command. Your system installer should have given you the access sequence to get there.
Carl
Jul 31, 2009 | Panasonic KX-T7433B Corded Phone
Can I change the on-hold music ??
The on hold music comes from something plugged into the TDA cabinet in the back room. Sure you can change it, but you have to find it first.
Such sources can be an On Hold device from Intellinet, A Premier box, or maybe a Nel Tech box or simply just a radio or CD player.
Once you identify what you have, post back here and someone can talk you through sources to change the message.
Carl
Sep 02, 2008 | Panasonic KX-T7630 Corded Phone
Jun 03, 2008 | Lands Phones
Panasonic phone
That depends on the system you are using with the phone.
Are you trying to change the greeting on your personal voice mail? Do that from within your mailbox under "Manage your Mailbox." Just follow the prompts.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Dec 18, 2007 | Panasonic KX-T7633 Corded Phone
Lands Phones Logo
639 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
