Question about Home Security
Menu password for 3r max dvr 4000
Hey guys how are you i have a 3r max dvr 4000 unit it has a 160gig hard drive with 4 video imputs its a verry nice piece of equipment witch belive it or not i got it from the local tip recycling center i paid just a few dollers for it every thing works fine but when i try to access the menu it asking me for a password to access it i have a serial no. for it but no passwords is there anywhere i can obtain the password if i give the serial no. or is there a way i can unlock via networking it throu the computer. do i do that through the nine pin plug or the lan cable? i have a acer veriton 5600g .i think i should have a lan conection. do i need any softwear to do it? i recently bought some cheap cammeras of ebay and im trying to hook up a cheap system and this 3r max dvr 4000 looks like it would be mutch more suficent for what i need .is there a possibility seeing as some one has twrown it out the pass words are unobtainable??????????
if so at worst atleasd i got a 160 gig drive for my computer but like i said it a buityfull piece of electronic eguipment and would love to get it going if u know of any web sites with softwear or product imfo that would be fantastic too thankyou verry verry verry mutch your help and fantastic SPOT ON suport is allways verry apreciated thankyou very mucth shaun hammer : ]
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 14 Answers
I believe I found the software and user manual you need. You can download it at:
http://www2.cop-usa.com/ebpage.asp?page=Softwares
By default, the system login is "SYSTEM" with no password.
Posted on Dec 28, 2008
DVR keeps rebooting after a few minutes
Hard drive failure. Open the case, unplug power wire from hard drive. Power on the system. If everything works except recording, then you have fried hard drive. Replace it, format it, and you are back to normal.
Good luck.
Jul 04, 2012 | Swann Communications DVR4-2600 4 Channel...
Dvr will not record. i get the message, " hard drive full" is there a way to erase what is on the hard drive?
You can erase the contents of the drive or set the drive to overwrite when full. Erasing the drive is the equivalent of reformatting (you will not be able to recover the images easily).
To Erase/Format, enter the Menu system and select Hard Drive Setup (seventh line in the list). Press Enter, then go to HDD Format (fourth item in the list) and press Enter. Then enter your password (set up under System Setup) but the default password is 111111, if it is on. If you entered the correct password, the screen will flash HDD Formatted 3 times. Press Menu to exit the menu. (If the incorrect password was put in, Incorrect Password will flash.)
To overwrite, again go to Hard Drive Setup then select the first item, Drive Full. Press Enter to toggle Overwrite On or Off. You will be able to recover the images until they are overwritten.
I hope this helps.
Oct 13, 2010 | CSi Speco Speco Technologies DVR-4CF...
How do I know if the cable to hard drive is plugged in
You would have to open up the DVR unit to physically see it is plugged in, but the unit's menu under HD or hard drive, should tell whether the unit's hard drive is plugged in. Please let me know if you have anymore questions. Thank you for choosing Q-see.
-Rishi Sharma
Customer Service Representative
Q-see
Jul 07, 2010 | QPS Q-See Video Recorder
My pelco 16 cameras reset each one minutes
You need to do a INITIALIZATION/REINITIALIZATION PROCEDURE See below for details Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
If you are installing the DVR, follow the steps below to initialize
the unit as part of the installation instructions in the Installation/
Operation Manual. This procedure erases all data on the hard disk
drive and is necessary to ensure that there is no data that could cause
improper operation when you try to use it. With a clean hard drive, the
DVR can correctly index recorded video with the correct time and date.
Once the DVR is initialized, you should not reinitialize the DVR
again unless you are having trouble finding and playing back video,
and there is no other solution. If you have to reinitialize the DVR, make
sure the time and date are correct before beginning the procedure.
WARNING: When you initialize or reinitialize the DVR:
• The hard disk drive is erased.
• The password and all menu settings return to their default
conditions.
To initialize or reinitialize the DVR:
1. Press and hold the Function button. The Function Key List
appears. Keep holding the Function button.
2. Press and release the 0 button, and then release the Function
button. Enter the password if requested. The Setup Menu
appears.
3. Using the front panel buttons, enter 1220.
4. A screen appears and asks if you want to continue. Use the
Search (<</>>) buttons to highlight Yes or No to erase the
hard disk drive, and then press the Play/Pause button.
PASSWORD
The default password is 0000. If you change the password, and
then forget it, you can get into the system by using 2002.
Aug 25, 2009 | Pelco DX1000
Samsung SHR-1040 Digital Video Recorder
it sound like the system is locked up or your hard drive is going bad. write down all the info on the unit and reset and reprogram the unit. this may solve your problem if not you my need to send it in for repair.
•Factory Reset Hidden Key :
Mode Key + CH 2
•The Password and all setting
value will return to the initial
default value.
•Default Password is ‘4321’ .
mj
May 18, 2009 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
DVR not playing.
Try this: Press the power button and hold it for about ten seconds and let the system reboot. Try to use the dvr again. If that was unsucessful try unplugging the receiver from the wall outlet for approxiamately 30 seconds and repower the systen and try again.
If these have not worked You can press menu-6-1-3 and view the system info screen. Go to the details options and select it. Once the details screen loads arrow all the way down until you see the values of which value 9 is the last one. If value 7 is not 4 you need the unit replaced. If all the above did not work the unit will still need replacing as the hard drive has locked up.
Dish has a new receiver called a 222k which has an expansion USB port that will allow you to use an external hard drive to use as the dvr as the 222k is not a DVR unit; it is a HD dual tuner. The external hard drive offers many advantages such as being able to take your recordings on the road, ability to keep recordings if the receiver fails, etc. Another awesome device they have also is called a sling box which will allow remote viewing of your Satellite from a remote location over a laptop, PDA, or cell phone.
I hope this helps you and thanks for using Fix Ya.
Dec 05, 2008 | DISH Network DVR-625 DTV Receiver /...
PS3
The hard drive is bust m8, you should remove the drive and take it to a local computer store and ask them 2 format the drive for you. When they come back and say the drive is unreadable ask them what replacements they have, i upgraded 2 a 160gig for £40.
Nov 16, 2008 | Sony Playstation 3 (PS3) Console
Admin password DVR-X4 IP
i lost the dvr password how to watch yastaday data
Mar 11, 2008 | CSi Speco Speco DVR-T4IP 4-Channel Triplex...
Lc-42d62u 42in.
This is a common issue with HDMI. Try unplugging the TV for 2 monutes and also reset the cable box as well by inplugging.
Feb 10, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Wan't boot up
If the dvr isnt booting the harddrive, then the harddrive isnt seated properly in the removeable harddrive drawer, or the harddrive is improperly formated, or you have the wrong type of harddrive, or the master/slave settings on the harddrive are not set properly (master). what ive found is an 80gig/160gig is the most that these things will handle. and some brands work and some brands don't. and the harddrives have to be IDE/EIDE type drives. but it sounds like a harddrive interface problem. They like the older harddrive formatts/(not xp/vista)....good luck!!!!
Oct 27, 2007 | Samsung SSC DVR Digital Video Recorder...
Home Security Logo
3,352 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
