Question about Apple iPod nano
I connected my i pod 2 the computer and it showed me a messagae saying error in usb device.and after that it got stuck i cant it switch it off and its not even getting detected by my laptop,the light keeps burning and i cant even turn it off
    Problem Solver:
  • 5 Answers
Try reseting the iPod.
To reset iPod nano:
1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold the Menu and Center buttons for at least 6 seconds, until the
Apple logo appears.
-Logan
Posted on Dec 25, 2008
When i click on my usb its show some errors like window cant find rcycler s-7-8-08-33471-35035-1358623128-032853270-7834\opqhfrwh.xe
Hi Saqibnoor_82,
The error that you're encountering when opening your USB device is caused by a virus. The easiest way to correct this error is to scan the device with an updated Anti virus. Here are some steps that you can apply on scanning your USB device.
1. Update the Anti virus that is currently installed on your computer.
2. Connect the USB device to your PC. Open your Anti virus then scan the device.
3. If after you've scanned the device and you're still experiencing the same error, you need to reformat the USB device to completely remove the virus .
Hope it helps.
Thank you for using FixYa.
Mar 20, 2011 | Computers & Internet
Wont do nothin
Try and reset the player. Reset the player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Then try this Connect the player to your computer. The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is available. Make sure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the players screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. <<<<< BUT TRY THIS ALSO >>>>> Check the Device Manager 1. Right-click My Computer, and select -- > Manage. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. *** See This Tip Posted here **** --> http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem <-- Copy this address into a new window. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. >>>> BUT TRY THIS <<<<<<< Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Verifying and changing the USB mode of the device to MSC or MTP From the Main Menu, select Settings > USB Mode.
Mar 06, 2010 | SanDisk Sansa e260 MP3 Player
Keeps turning off
Mar 05, 2010 | SanDisk Sansa Fuze MP3 Player
Fuse is completely frozen. no functions work. will not turn off, screen says "disconnected" . just charged it.
Feb 27, 2010 | SanDisk Sansa Fuse MP3 Player
It is stuck on the disconnected screen and it won't turn off or on. It had been charging and when i took it off, it is frozen. It is a new laptop with norton antivirus. So I don't understand.......
Feb 26, 2010 | SanDisk Sansa Fuze MP3 Player
My MP3 player is frozen and it dosent show up on the computer?
Reset the player:
Then try this
<<<<< BUT TRY THIS FIRST >>>>>
Solve your MP3 Player Connection Problem.
Refresh the drivers
Feb 22, 2010 | SanDisk Sansa e250 MP3 Player
My mp3 was on but now it won't come back on or charge.
Reset the player:
Then try this
- If the player does not turn on try other USB ports2_bing.gif or on another computer if one is available. Make sure you are connecting directly to the computer USB port and not to a USB hub2_bing.gif.
If you receive the error "USB Device2_bing.gif Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
MTP mode is the recommended and default method for Sansa Players when used with Windows OS2_bing.gif.
Refresh the drivers
Feb 21, 2010 | SanDisk Sansa Clip MP3 Player
Switching from MTP to USB
it does not need 2 inless you got an old PC
Jan 07, 2009 | GPX MW3837 MP3 Player
Miissing e drive
Try updating or reinstalling iTunes.
Jan 02, 2008 | Computers & Internet
Apple iPod nano Logo
81 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
