Question about JVC RX-717V
No sound all displays and selections work but no sound
Connecting my macbook pro to digitrex tv using thunderbolt and hdmi
DisplayPort to HDMI Sound is actually set up by using the MIDI setup utility found in :
Applications > Utilities > Audio MIDI Setup.
If you purchased an iWires cable direct from Apple the instructions are in the printed booklet that comes in the packaging. Most people don't read this as it's normally the case that when you plug a cable in to anything it just works (VCR, TiVo, Xbox, video camera etc). In this instance Apple are failing to live up to their catch-phrase as final setup is NOT intuitive; "it just DOESN'T work".
The booklet instructions basically say do the following,
Video
System Preferences > Displays. There are 3 tabs in the window; Displays, Arrangement and Color. Be sure you are on the Displays tab. Bottom left of the window tick "Show displays in menu bar" and then bottom right click "Detect Displays".
Now click on the tab named Arrangement. Bottom left of the window tick "Mirror Displays".
You should now only see 2 tabs, Display and Color. Be sure you are on the Displays tab. Select the desired resolution for your TV (probably 1080i). leave all other settings at their default values.
Sound
System Preferences > Sound. There are 3 tabs in the window; Sound Effects, Output and Input. Be sure you are on the Sound Effects tab. Middle of the window select your TV where it says "Play sound effects through:".
Select the middle tab named Output.
Select your TV from the drop-down list next to HDMI, below where it says "Select a device for sound output".
Using either Finder or Launchpad go to Applications > Utilities > Audio MIDI Setup.
On the left-hand side of the window you should now see HDMI. In the middle of the window, on the Output tab, where it says "Source:" select your TV from the drop-down list.
This last action below is NOT described in the iWires notes but was required in my case, it may also be required in yours. If you CANNOT see a speaker icon next to HDMI in the list on the left, do the following:
Bottom left of the window select the wheel icon with the down-pointing triangle. Make sure that sound output is selected and that you can now see a speaker icon next to HDMI in the list of devices.
If you still cannot hear sound, log out of your account and then log back in.
You may have to do some or all of the above to get sound out of your TV from your computer using the DisplayPort to HDMI cable. On my Aug 2011 MacbookPro I had to do ALL of the above. If you take your laptop to a different TV you will have to do it all again so be warned.
Hope this helps.
Feb 24, 2014 | Apple Computers & Internet
Turn ringer on
To set the Vtech T2326 ringer:
there are only four ringer tone/volume choices plus "off" available
1. Press the PROG end of the "SELECT/PROG" rocker switch.
The display will light and show "DIRECTORY"
2. Press the right side top button "VOL +/DIR"
The display will change to "SPEED DIAL"
3. Press the right side top button "VOL +/DIR" again The display will change to "RINGER: [number] ( 1 - 4 or OFF )"
4. Press the SELECT end of the "SELECT/PROG" rocker switch.
The "RINGER: [number] ( 1 - 4 or OFF )" will blink and the ringer will sound.
5. Press the right side top button "VOL +/DIR" The display will change from "RINGER: 1" to "RINGER: 2" and the sound will change accordingly.
6. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 2" to "RINGER: 3" and the sound will change accordingly.
7. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 3" to "RINGER: 4" and the sound will change accordingly.
8. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 4" to "RINGER: OFF" and the sound will cease accordingly.
9. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: OFF" to "RINGER: 1" and the sound will change accordingly.
10. ...and so on, cycling through the four choices & OFF: when you decide to select one, press the "SELECT" end of the central "SELECT/PROG" rocker switch.
11. The display light will go out, the phone will chirp in acceptance, and it will be ready to use the chosen ringer. --
Sep 07, 2013 | Vtech T2326 Cordless Phone
Samsung SGH D900I- cannot turnoff keypad sound
The steps are outlined in the article below:
D900 FAQ – How do I disable or mute the keypad tone on my SGH-D900? admin March 6, 2009 --> Note: In order to disable the keypad tone, the Dialing Display Font Type must first be set to “Normal”
To change the dialing display font type follow the steps below:
  1. From the standby screen, press the left soft key for Menu
  2. Select Settings (9)
  3. Select Display Settings (3)
  4. Select Dialing Display (6)
  5. Select Font Type (1)
  6. Highlight either Normal or Theme, using the navigation keys
  7. Press the left soft key to Save the Dialing Display Font Type setting
To turn off the keypad tone follow the steps below:
  3. Select Sound Settings (4)
  4. Select Keypad Tone (2)
  5. Highlight Off, using the up navigation key
  6. Press the left soft key to Save the Keypad Tone setting
Aug 29, 2009 | Samsung SGH-D900 Cellular Phone
Display problem
Has the display every worked before? If so Sounds like the display setting is turned off. You will need to go into the menu settings and serch for display, then select yes or on for display mode. If that doesn't work the display may be burned out.
Aug 06, 2009 | Car Audio & Video
Multimedia audio controller for my compaq evo pentium 4(my sound is not working)
1. Right click on Mycomputer, select properties
2. Select hardware
3. Select Device manager
4. double click on the sound,volume and controller
5. if any yellow color pointed is displayed on any option then right click on the option and uninstall it
6. then select Action from the menu bar on the top and select scan for hardware changes
**** after doing this.. you can check the follwoing steps for trouble free ******
7. double click system device
8. if any yellow color pointed is displayed on any option then right click on the option and uninstall it
9. then select Action from the menu bar on the top and select scan for hardware changes
10. then it will start scanning your new hardware and ask for the installation drivers.
Jun 29, 2009 | Compaq Audio card Sound Card
I want mercury motherboard VIA P4M266 sound driver
if your computer sound was working before and now it was corrupted then you follow these steps to solve your problem.
2. Select hardware
if your system dont have sound from the beginning or from the date you buy.. then
download your drivers from the given link..... try it .. all the best...
http://www.lostmydrivers.com/mainboard-drivers-and-utilities-drivers/via/
Jun 20, 2009 | Mercury Computers & Internet
My pc sound is mout
2. Select hardware
download your drivers at
http://drivers.softpedia.com/get/SOUND-CARD/CREATIVE/index1.shtml
Jun 06, 2009 | Creative Labs Sound Blaster Live! 5.1...
When I want to install it on my laptop at that time online registration is must but when I type my activation key then reply with "Invalied key"
download from this link
***** if sound not work then follow these steps*******
2. Select hardware
May 30, 2009 | Creative Labs Sound Blaster Live! 5.1...
The selection button with arrows is not responding and not allowing user to select options displayed on screen.
On my PDV-288 EVERY button has to be pushed down FIRMLY and for several seconds....My sound is also very low...
Feb 24, 2008 | Protron PDV-288 7" LCD Portable DVD Player
No picture, sound works. Screen flickering
That problem is caused by the Y Sustainer board.
Oct 12, 2007 | Toshiba 50HP66 50 in. Plasma Television
29 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
