Question about Refrigerators
Warm fridge freezer is working but frigde is warm My fridge is warm whilst the freezer works fine, compressor is running but the fridge will not go below +9 degrees, any ideas?
  • philgilday Dec 12, 2008
    This was really useful advice thanks very much, the problem is not fixed yet but Benimur was quite right the fan is not working so I know what to do, thanks again
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, this normally would point to the fan not spinning. The function of the fan is to draw the cold air from the freezer and force it through the vents to the refrigerator area. Even having said this, the fan is activated by the logic controller based on the the thermostat setting of the refrigerator and condition of the door (it must be closed).
To check:
  • fan - open the door, locate the door switch, press on it, light should go off, fan should kick in within 60 seconds. If not, faulty fan, fan relay, or controller. Alternately, you can measure the continuity of the motor's coil and or if there is voltage going to the terminals of the motor;
  • thermostat refrigerator side, you would need to use a continuity tester or have an electronics shop perform this. At room temperature the reading should be low, and should go high when the probe end is submerged in a glass of cold water.
Alternately, it may be the vents, flaps or vanes that are stuck, clogged, blocked and hence no air flow from the freezer to the fridge side.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 12, 2008
Fan in Freezer portion not running, compressor works
The door switch, some fridges run the fan on door closed only.
Jul 10, 2013 | Frigidaire FRT17G4B Top Freezer...
I have a inglis fridge which is only 4 years old. It has a freezer compartment as weel as the main. Seems like the freezer has stopped working. water is now dripping from top part of frigde. Was wondering...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 07, 2010 | Refrigerators
Have been waiting over 2 months for parts . frige
it is not the solinoid, your fridge probably had a leak and you let run until all the refrigerant gone out, this will force your compressor to pump nothing and eventually your compressor will give up. you should ask your technician to check the system first.
have it charge with refrigerant and make run again, lets hope that your compressor will work fine, if not then you'll need to replace a new compressor
Nov 05, 2009 | Samsung Refrigerators
SIde by Side Kenmore -- Freezer is fine Fridge Is Warm
the freezer needs defrosting or the evaporator fan has failed and is not blowing air into the refrigerator side.
Aug 12, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE Model # GSS20IEPA WW Fridge warm...freezer is fine
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know.
thanks,
Mar 28, 2009 | GE GSS20IEP Side by Side Refrigerator
Tempratue problem
air from the freezer fan, means the sensor- temperature control circuit is working right, it is trying to cool
there has likely been a leak from the system and there is not enough coolant left for the compressor to compress anything.
a GOOD repair guy
will have a pressure pump/gauge and test for leaks through the fill nozzle, repair them and regas the fridge (provided it is a non-CFC r12 fridge) without removing it from the home,
a not-so-good repair guy
will not
Sep 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
THE FRIGDE IS TOO WARM.
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 29, 2008 | KitchenAid KSRA22ILSS Side by Side...
Warm fridge
Need additional information as to make and model number. Check for frost build-up in the freezer, is the fan operating in the freezer?
Frost build-up in the freezer compartment will stop air circulation and the freezer will appear to be working but will not be at its design temperature. If this is your problem then it is in the defrost circuit.
May 01, 2008 | Refrigerators
Refrigerators Logo
180 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
