Question about Umax Astra 2000U Flatbed Scanner
Edit saved image
How to edit saved image
    Sergeant:
    Novelist:
  • 183 Answers
Wow! The answer is as lengthy (very much more actually) as the question is brief. There are literally hundreds, if not thousands of image viewing, converting, editing and management software packages in the etherworld to choose from. They range from very easy to complex, limited to exhaustively comprehensive, freeware to share/trialware, and from $0.00 to upwards of $1,000.00. Thankfully, the vast majority of the vast majority's needs are amply met with quite powerful and easy to use FREEWARE's.
There's always Microsoft "Paint". Available to every Windows user and found in your "Accessories" folder via the Start button. It can perform very rudimentary format (file-type .JPG, .BMP, etc.) convertions and editing.
But you'll quickly discover just doesn't come close to cutting the mustard. So, of all the freeware image related software's I've used and evaluated lo' these many years, there's one that I believe stands out. FastStone Image Viewer. It has and can do everything the vast majority of users need from an image software. It's easily quality enough to be sold, and be every bit worth it. But again, it's FREEware.
http://www.faststone.org/FSViewerDetail.htm
If you have a bit to spend, my equally enthusiastic for-purchase software I recommend is ACDSee Photo Manager (or Pro). It's my personal work-horse that I've heavily used for many years now. In my opinion, it beats all of its top competitors that even cost much more ... and I've used and/or have them all.
http://www.acdsee.com/
The above will get you steered in the right direction. Have fun exploring and playing.
TIP: Always make sure to have a backup copy of the original image you're about to edit (change), then save. Very often you'll discover that you wish you had it to go back to.
"Today's the best day of my life...and NOW you're part of it!"
Posted on Dec 12, 2008
    Scholar:
  • 149 Answers
You'll need to use an image editing program like paint shop pro or photoshop...look through the software that came with the scanner or you can download shareware/freeware image editors from places like www.download.com or www.jumbo.com
on actually editing the image ach program will do things in slightly different ways so you would really need to follow the help section in the program itself
Adobe Photoshop Elements 5.0
When you zoom in most any photo editing program, all you do is change the appearance of the picture on your screen; nothing happens to the file, merely the size of the image you are viewing. To change the size for the file, here are detailed instructions:
  • Step 1. Select the command Resize - Image Size from the menu Image of Adobe Photoshop Elements. change-print-size-adobe.gif
  • Step 2. Activate the check-box Constrain Proportions to keep the image proportions.
  • Step 3. Activate the check-box Resample Image, if you want to keep the image resolution.
  • Step 4. Select the interpolation method: Nearest Neighbour, Bilinear or Bicubic. We recommend the Bicubic method of interpolation.
  • Step 5. In the group Document Size select units and enter new values in the fields Width and Height. If the check-box Resample Image is not activated, the resolution will change.
  • Step 6. Select OK
Dec 24, 2007 | Adobe Photoshop 7.0 for PC
I can't find the digital camera image files I saved on my PC.
Use the procedure below to search for digital camera image files saved on a PC. 1. In the "Start" menu on the desktop, open "Find" -> "Files or Folders". 2. In the "Names & Locations" window, enter the image file name in the "Named" field. Enter "DSCF" as the file name if you have not renamed the file. If you changed the file name, enter the new file name. 3. In "Look in" select the hard disk and then click the [Find Now] button to begin the search. The files found are listed in the search result. Check the results for the desired files. 4. If the desired files are not in the search results, the image files were not saved. --Saving Image Files-- - Downloading images from FinePixViewer or Exif Viewer: 1. Connect the digital camera to the PC. The "Viewer" window opens and the images are displayed as thumbnails. 2. Click "Select All" in the "Edit" menu. 3. All the images are selected (indicated by a pink frame). With the left-hand mouse button held down, move (drag) the images to the folder in which you want to save them and then release the button (drop). - Saving images from a removable disk: Connect the digital camera to the PC. When the Viewer automatically starts up, click the Close ([X]) button to close the Viewer window. Then open the "My Computer" -> "Removable disk" -> "DCIM" -> "100_FUJI" folder and select "Select All" in the "Edit" menu. Then select "Copy" in the "Edit" menu; open the folder in which you want to save the images, and select "Paste" in the "Edit" menu. All the selected images are copied and saved in the folder. You can also copy the images by selecting the entire "100_FUJI" folder.
Aug 30, 2005 | Fuji FinePix 2600 Zoom Digital Camera
Aug 30, 2005 | Fuji FinePix 2400 Zoom Digital Camera
Aug 30, 2005 | Fuji FinePix 2300 Digital Camera
Aug 30, 2005 | Fuji FinePix 1400 Zoom Digital Camera
Aug 29, 2005 | Fuji FinePix 1300 Digital Camera
Aug 29, 2005 | Fuji FinePix 3800 Digital Camera
Aug 29, 2005 | Fuji FinePix 2600 Zoom Digital Camera
Umax Astra 2000U Flatbed Scanner Logo
Top Umax Office Equipment & Supplies Experts
Tony
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
