Sata hard disk problem
I think so.. how to solve it? dont have fdd, must burn the installation through nlite and add the drivers for sata? am I right?  Intel Bonanza D875PBZ - thats my board, but cannot find the drivers for sata, can you help me please with that?
  • gudla Dec 12, 2008
    and which one exactly, pls? sorry for bothering you...
  • 87 Answers
I want to instal a windows XP SP3 on Foxconn 915 series with north bridgegrantsdale G-i915G with a IDE H.D.D (pata) and sata O.D.D,it seems that i need a floppy disk for raid driver,but i lost motherboard...
There are a couple options.
  • Check in BIOS to see if your motherboard supports IDE emulation mode. If it does turn it on and XP will install just fine.
  • Download and read about using nlite to incorporate sata drivers into an Windows XP installation disc. (You will need another working computer. Download nlite and insert the XP disc run nlite and select your CD as your windows install file location. Download generic sata drivers, intel has a bunch you can get for free. In the nlite menu to add drivers select folder option and select the folder with the drivers. Set anything else you want in nlite and burn the new XP disc. This disc will install just fine as it now has sata drivers.
Comment if you need further instruction.
Aug 18, 2011 | Foxconn 915P7AC-8KS Motherboard
Hard disk not detected in bios or in window setup
Method 1 : Go to BIOS and set anything with SATA disable (usually find under Advance Setting).
Save the setting and reboot.
Windows Xp will detect your hard drive now.
Method 2 : This days BIOS comes with only few thing to configure.if that's is the case.
Download SATA driver,here is the link
http://download.cnet.com/SATA-Driver-Intel-Ver-7-0-0-1020-zip/3000-2122_4-162224.html
you need one more software called "nlite" in order to integrate the SATA driver in Windows XP CD so that it recognize SATA drives.
Here is the link for nlite download
http://home.midmaine.com/~nlite/nlite/nLite-1.4.9.1.installer.exe
On how to intergrate SATA driver with windows XP
Go to this page :
http://www.nliteos.com/guide/part1.html
Rate this answer.
Jan 02, 2010 | Toshiba Satellite A60 Notebook
To install xp over preinstall vista in Toshiba satellit A200, some soultaion is aviable 1. to disable sata but how to disable sata in toshiba no option is aviable in in toshiba Bios. plz help me
There are case where BIOS stting doesn't contain any point of configuration for SATA.,
Step 1 : Download SATA driver
Here is the link :
http://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/12474/eng/iata621_enu.exe&agr=N&ProductID=2101&DwnldId=12474&strOSs=All&OSFullName=All%20Operating%20Systems&lang=eng
Step 2 : Download a software called "nlite"
Here is the link :
Now you need to include SATA driver with Windows XP cd so that windows XP recognize your HARD DRIVE.it can't be include diectly so
Installed the nlite software and follow the instruction by going to the link below.
Note : Microsoft dotnet framework 2.0 or later is needed to install nlite in Windows XP,but if you are making a bootable Windows XP cd with sata driver pre-install then,you don't need it.
This will 100% recognize your SATA HARD DRIVE.
Hope it will solve your problem.
Jan 02, 2010 | Toshiba Satellite A200-19501F Notebook
My Dell Latitude will not boot. it says no hard disk detected.
The first thing to do is go into the bios. To do this, power up the laptop and hit F2 at start up. Sometimes it requires hitting the F2 button numerous times. You should see message in the top right corner that says "Entering Set Up". Once in the bios screen, look through menu to see if your hard drive is recognized by the bios. If it is not recognized by the bios, it may be a defective hard drive or problem with the motherboard. You might also try removing the hard drive and checking for any problems with the connector then reinstalling the hard drive and trying to boot up again. If this does not work, I would recommend replacing the hard drive.
Dec 24, 2009 | Dell Latitude D600 Notebook
Vista Crashed does not recover (Can't install XP or 98SE either)
if you want to recover vista then download vista recovery disk here is the link
http://rapidshare.com/files/145731926/WVRD_www.warezspark.com.part1.rar
http://rapidshare.com/files/145698726/WVRD_www.warezspark.com.part2.rar
password : www.warezspark.com
burn the ISO disc and boot from cd rom and get it repair it automatically.
if you want to installed windows XP or 98;the reason why your hard disk could not be detected is your hard drive is SATA. disable any sata setting in your BIOS IDE configuration( if setting is not available then download SATA driver and Nlite ;make a bootable windows xp disc  with SATA driver pre installed .
this is solve your problem
here is the link for lastet SATA driver
here si the link for lastest nlite software
regarding how to make a bootable cd with nlite with sata driver check out this link
http://www.windowsreference.com/free-utilities/nlite-slipstream-servicepackshotfixespatches-create-bootable-windows-cd/
let me know if it's helpful to you
Dec 09, 2009 | HP Pavilion dv6000z Notebook
Error when installing XP on Vista
which service pack?? sp1 and 2 dont support sata harddrives you have to get sp3 on a disk or slipstream the drivers into the os cd for sata harddrives
Jun 05, 2009 | Acer TravelMate 5530-5207 Notebook
NO INTTALEDWIN XP IN SATA HDD
you need your windows xp disc preferably slip streamed with SP 2 or SP 3 and then you should be able to install it onto your sata hard drive.
If you are having issues then you may need to extract the sata drivers onto a memory stick or floppy disk and press F6 before windows xp loads and specify to use the sata drivers which you can download from the motherboards manufacturers website generally as a zip file which you will first need to extract into a folder.
If that does not work using the memory stick you can use nlite to slipstream the drivers with your windows xp disc :
Nlite download
if you need more help post back
Apr 11, 2009 | Mercury KVM800M Motherboard
Not able to install windows XP on sata hard disk having Intel d101 mother board. please help but not using F6 option as I don't ahve floppy disk drive on my system
You need to sliptream SATA drivers into your setup disk.
Download from here
http://driverpacks.net/DriverPacks/
driverpacks mass storage
copy windows CD to hard drive then use "Nlite" to insert them into the drivers section
then burn to a new CD.
and reboot from it should have no problem then
Dec 10, 2008 | Intel D101GGC Motherboard
Cant Dictect sata hard disk
You do not have SATA drivers on the disk
Download "driverspack" one word from here
the Driverpack massstorage one
Download "Nlite" install it
You may have to get someone to do it for you
copy your Windows CD to hard drive and insert driverpack into the driver section of it
then burn to another CD
"Nlite is easy to use just read instructions
Nov 24, 2008 | ASUS A8V-VM Motherboard
Cannot install Windows XP,Vista on Compaq Laptop(FreeDos) V3607TU.
I have two solutions for this problem. the first one is to change the bios settings. the solution is here:  http://techrena.blogspot.com/2008/10/how-to-install-your-own-wndows-xp-in-hp.html
but for some laptops this setting is not available. so you can try another solution i.e. integrate the SATA drivers in your windows XP cd. this solution is here: http://techrena.blogspot.com/2009/01/integrate-your-own-drivers-or.html
Mar 23, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
