Question about Toshiba 32A42 32" TV
Green s Hello the tv will turne green then it will turn off on its own
  • 81 Answers
Check for bad solders on the crt socket . If it turns off again try running the tv with the crt socket off the tube but 1st try to time how it takes for the tv to turn off then disconnect the crt socket. If it does not turn off the tube may be bad, if it does not turn off check the voltages at the crt socket and see if all the voltages at the colour outputs are close to the same, if so then you have a bad tube when you connect the tube and the voltages change conciderably the tube is gone
Posted on Mar 20, 2007
Typically the power button blinks green for a few seconds before turning a solid green as the lamp lights up. Now the power button just blinks green indefinitely, without the TV ever turning on. I figured...
Hello Jeremy,
May be some IC or capacitor is damaged due to which TV is not turning on. Please contact the service center of the Sony. They will repair it properly.
Dec 26, 2011 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Hi, i have here a mitsubishi WD-57733. once the unit is switch ON, green LED light and a few seconds the status LED light then shuts off. I think light engines good since i just replaced a new lamp.
hello i've just checked the manual for here is some information
None TV is powered off. Normal operation.
Green TV is powered on. Normal operation.
Green 1. TV just plugged into AC outlet.
Wait until blinking stops before turning on (approximately 1
minute). Normal operation.
2. AC just restored after power failure.
3. TV Rebooting after System Reset was
used.
4. TV Rebooting after power fluctuation
or receiving abnormal digital signals
from digital channel, or digital device.
5. You have begun the procedure to
update software from an authorized
flash memory device.
For detailed information, see the instructions that accompany
the authorized software update. IMPORTANT: Do not
use unauthorized software at any time.
Green TV just powered off and lamp is
cooling.
Starts to blink 30 seconds after turning off TV. TV can be turned
on before blinking starts or after blinking stops, but not while the
indicator is blinking. Normal operation. hope it helps regards shaun
Green TV powered off and auto-on timer is set. Normal operation. TV can be turned on at any time.
Dec 06, 2010 | Mitsubishi Televison & Video
Our CAL232 TV will not turn on. When pressing the power button, you can see a red light and a green light, but the screen doesn't start up as normal. The TV then tries again after about 20 seconds, but...
My LOEWE CAL 232 will not power up. When the power button is pressed, the monitor turns on, with the LOEWE on the monitor, then the TV continues with the previous activity (antenna, DVD, VCR etc.). Now all that happens is
1. the red light comes on
2.after about 1 second the green light turns on for about 12 seconds
3. the the green light turns off for about 1 second
4. then the green light turns on again for about 12 seconds
and this continues until the power button is pressed to turn the TV off. During this time, the monitor does not turn on and the only sound I hear seems to eminate from the power button.
Any thoughts?
Oct 19, 2010 | Loewe CAL232 TV
Tv doesn't work
If this TV has a lamp it could be it. I need the model number to better figure it out
Mar 08, 2010 | Televison & Video
Green TV Screen
May i know what exactly the model that you have..?
Also, since when you experience this problem..?
Thanks
Jan 27, 2009 | Televison & Video
Sony TV
I think your problem is in Green CRT board.Check video Amp. on Green CRT.
Dont Forget to Rate!
Good Luck
Dals123
Oct 08, 2008 | Sony KP-57WS500 57" Rear Projection...
Green timer light turn on tv turns off
Read the info from this link to see if that applies to your TV.
Jul 23, 2008 | Mitsubishi WS-55859 55" Rear Projection...
43UWX10B problem with green
if you have a 2 IC convergence chassis they dont control the green , However if you have the 3 IC chassis the green is controlleed by the third IC these are usually STK4275 or simallar single amp ICs. Which type chassis does your hitachi have? Its possibly related to the digital convergence board if all resistor near the ICs are good. Do you have the service manual? I can post a link where you can get the full service manual if you need one
Mar 29, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Hello im having problems with my sony wega
It sounds like you have a loss of green. This could be caused by the green gun in the picture tube opening up or the drive circuit for the green gun gone bad. Stargazer
Aug 10, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Open Questions:
I own a Samsung LN40C630K1FXZA TV with no picture but has audio and backlights. I need help determining what boards to replace. I tried to watch some tutorials posted on YouTube and have the following information. The TV was starting to have an issue that while watching it the picture was seeming to get a little jerky like it wasn't refreshing fast enough. It wasn't always noticeable and I initially though it may have been a signal issue with our cable. Eventually we turned on the TV one morning, the picture came on and then disappeared after 2 or 3 seconds but we still had audio. I tried to pull up the menu screen and that was not visible. I performed the flashlight test and there are images visible with the light. I removed the back cover and took pictures of the attached boards and also saw that the backlights seemed to be working but did seem like they were not quite a constant consistantly light. They never completely extinguish but do seem to fluctuate in brightness slightly. I did not see any visible issues with any if the capacitors being swollen or blown and did not see any apparent burnt components or boards. Below are the readings I got from one board but I was not sure where to get the readings on the TCON board. Main PBA readings CN201 1. 18v. Actual 13.1v 2. Sw. Power Actual 13.1v 3. 18v. Actual 13.1v 4. 5v. Actual. Falling to -1.6mv 5. 5v actual. Falling to -1.7mv 6. 5v actual 5.15v 7. 5v. Actual 5.15v 8. ground actual 13.1v 9. Ground actual 13.1v Any help would be greatly appreciated so I can buy the right parts from you. Thanks, Chris
Jan 19, 2019 | Samsung Televison & Video
See all Toshiba 32A42 32" TV Questions
Toshiba 32A42 32" TV Logo
52 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
