Question about Sanyo Refrigerators
Setting the temp on a Sanyo Commercial Fridge
It is a SRM-CD1210DAS Two Door Display Cabinet. It has a key pad but i don't know how to set the temp. Can anyone help??
SOURCE: cannot get the fridge to start cooling
If the panel temperature reads 0 F 0 F it is in the "DEMO" mode. This is normal if you purchase a floor model. To bring it back to normal mode press ENERGY SAVER & ADJUST FREEZER together for 3 to 5 seconds until it beeps. Then unplug the referidgerator for at least 30 seconds. Then plug it bck in. That will reset the stupid computer and get it back to normal operation.
Did you think this was helpful? Yes No
Posted on Apr 24, 2009
SOURCE: LG LRFD25850ST gives ER CO code on door
Good call Cooltech! My new LG "open box" deal from Best Buy must have been delivered once before. I hauled it home, plugged it in and Er CO was on the display. The doors must have been removed to get through tight spaces, exposing the bundle of wires and connectors under the left hinge cover. One wire had been repaired with a crimp lug, wire cut too short, and the crimp was no good. I soldered the connection and added 2" of wire so it wouldn't be stressed. Works!
Posted on Mar 17, 2010
Sea Breeze
  • 4655 Answers
SOURCE: I'm unable to set GE Profile Arctica ridge to recommended temp
OK, First let us check the compressor to see if running or trying to start. Pull away from wall and unplug from wall. Remove lower cover and feel the compressor top of the to see if too hot to hold hand there, cool or warm. look inside freezer and tell me if ice is building on rear wall. Answer that and I will be able to tell you what we need to do, Thanks, Sea Breeze
Posted on May 07, 2010
aasc
  • 1606 Answers
SOURCE: fridge broken, freezer is temp. that fridge should
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . ( If you notice your compressor is not running before unplugguing the blue plug , then jump wire1 to wire3 to see if the compressor runs . If so , then the main control board is bad . Plug the refrig back in to see if compressor starts with the jumper wire in place , ) . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10101 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature .
Posted on Jun 27, 2010
SOURCE: Fridge temp set to 38 is blinking,,reset unit
I had a similar problem, paid a technician $90 to tell me to defrost the entire unit for 15-20 hours, and now it works like new. It is supposed to self defrost, but with poor circulation in the freezer (simply caused by too much stuff in there) the unit frosts up. This caused a rising temp in the freezer leading to inconsistent temps.
Anyone reading this with a similar issue, save your money and defrost it overnight. You should see a pool of water in the bottom of the freezer after defrost if this was the problem.
Posted on Aug 12, 2010
Kic fridge not cutting out,whats the solution?
probably a thermostat not working correctly
could also be door seals not sealing properly
could be cabinet temp setting too low and the unit is struggling to get the temp down that low
fridge temp is between +3 -7 degrees c and the freezer up to -15 degrees c
check your setting on the control
Jan 21, 2016 | Refrigerators
Just got delivered a new kenmore french door fridge and temp. on freezer is zero. it doesn,t say what temp to put it on
Usually 0 is the warmest setting 1,2,3,4,5 would be increasing to coldest level with 5 as coldest
Jan 04, 2015 | Kenmore Refrigerators
Fan does not come on nor does door light. Also will run to cold temp when it cycles off cabinet warms up very quickly
have you checked the door switch for each door? the lights should still work in defrost mode but not fans or compressor.
Jan 08, 2014 | True T23F Commercial Freezer
FRIGIDAIRE SIDE BY SIDE FRIDGE SIDE TOO WARM
adjust the temp on the freezer setting where it links up with the frig'...
Feb 03, 2013 | Refrigerators
My samsung frig suddenly started clicking (the bell that lets you know the frig door is opened.) checked to make sure all doors were closed but bell keeps ringing and now the temp. is rising inside. what's...
Can you pull the gasket back slightly (flat screwdriver or dull knife, don`t cut/rip the gasket) from the side of either fridge door and tell me if the cabinet light is on inside ? I need to know if the light is on without opening either door.
I`ll watch for your reply.
macmarkus :)
Feb 04, 2010 | Samsung RF265AA Bottom Freezer French Door...
Temp in fridge side is too warm
Make sure that the air canal that runs from the freezer to the cabinet is not obstructed by ice or debris...
Jan 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigator not cooling properly, freezer works fine
I'll assume you don't have much food/items in the freezer section. Because you have the fridge set on the max cooling setting and the freezer set higher than the mid setting, it could be that you have frozen the cold air passage from the freezer to the fridge.
If you can, 1) remove all contents that would spoil; 2) turn off the fridge 3) open both doors and allow the fridge to manually thaw out completely (this will speed up the opening of the cold air exchange passage between the freezer and fridge, which is likely blocked and frozen solid. Have plenty of towels handy to soak up the water from the defrosting process,
After a FULL day of being left off and doors open to thaw out, check for any further thawing and dripping water inside, if present wait another 8 hours (you really want to get it thawed out the first time!) When that's done, reset BOTH temperature controls to the factory mid-point setting (5?) as marked on your control knobs.
The key to having a refridgerator run properly is to allow for it to run at the factory settings for at least 24 hours BEFORE you adjust the controls higher and/or lower for each section. Adjust it up or down in ONLY 1 setting increments so as to not cause ice build-up and freezing of the internal air exchange passages.
Also, as you've relegated this fridge as a garage "beer & backup" unit, make sure to keep the freezer as full as possible to make it run as efficiently as possible. You can freeze jugs of water and pack it with cheap thrift store bread to help it run correctly. An empty freezer has to work harder to keep just air at freezing temps. As such, it will pass much colder air into the fridge, and cause these types of freeze ups. By the way, turning up the temp controls only makes it worse and just results in a total "freeze up" inside the cabinet panels that you can't easily see or get at to rectify, hence the reason to shut it off and let it fully defrost.
When you're done, you should have your fridge back in action working like it should, but remember, don't rush temperature adjustments, even thou we all want those frosty beverages, it'll take a couple of days to achieve the desired "chill" you're likely used to getting when it was your primary fridge.
Hope this helps and Best Regards! Semper Fi!
Aug 03, 2009 | GE Profile PSW26P Stainless Steel Side by...
There is a communications error between the control board and the display board.  Check the connector located on the top hinge cover.  Remove the hinge cover and check to make sure the connector is tightly secured.
Apr 12, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Err codeF2EO Stuck Key onContol panel touch pad
Hi have a nice day
F2 - E0 Oven temp too high
1. Test operation of door lock on self-clean
2. Test relay contact operation
3. High resistance in oven temperature sensor
Guruood Luck !!!!!!
Feb 16, 2008 | Kitchen Ranges
Refrigerator freezes everything even on the lowest setting
Is everything really frozen or just the top shelf stuff? You may have a thermistor (temp sensor) problem if the compressor just runs and runs and runs all the time. Take a glass of water and place a thermometer in it for about 3 hours then take a temp. reading. That will let you know what the real temps are. See if you can cause the compressor to kick off and on by changing the temp settings (go to real low for about 5 minutes then back up to high). Let us know what happens.
Dec 24, 2006 | Sanyo SR-3620 Compact Refrigerator
Refrigerators Logo
175 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
