Question about Linksys Wireless-G WRT54G Router
My two front usb ports cant read usb hard drives
Hi, my two front usb ports can read usb hard drives. but its working on usb flash drives and thumb drives. its seems like the power its not enough. can some help me fix this without replacing the case of my cpu. note: the 4 usb ports at the back(the built-in from mobo) are working with usb hard drive.
i have a 120 GB ide usb hard drive.
    Master:
  • 409 Answers
Some external USB drives require external power sources. Typically this is done either with an external power supply that connects to the drive or a second USB cable that connects to the drive and a second usb port on the pc. I have even seen one drive that comes with a Y cable. one end goes to the drive and the 2 usb plugs go to the pc.
Posted on Dec 12, 2008
How do I use a jump drive Hi-Speed 16 GB Stix
You didn't mention the manufacturer on your 16GB stick, but that should not be a problem using it. The price on 16GB USB drives has fallen dramatically in recent weeks, so you will see more of them in use.
If you plug the USB drive into one of your computer's free USB ports, it should be recognized by your computer and assigned a drive letter in Windows. This means if you view the contents of your hard drive using Windows File Explorer, you should see another drive representing the 16GB USB thumb drive in the list of disks.
If you click on that drive you will see its contents (if any). Some drives come with software pre-loaded on them which you may be able to use to encrypt the contents of the thumb drive.
In all other respects, the USB drive will function like any other disk drive, allowing you to move or copy files back and forth between your main hard drive and the USB drive.
Be careful to 'unmount' the USB drive before you remove it from the USB port. Often there will be a flashing LED light on the drive which indicates that data is being written to the USB drive. If you remove the drive while the light is blinking, you may damage the file system on the USB drive and make reading its data impossible.
To eject the drive properly using Windows File Explorer, click on your main hard drive (usually C:) to select it, then RIGHT-CLICK on the drive you want to eject. A menu will come up, and you should click 'Eject' to close out the USB drive. You will get a confirmation message window that it is safe to remove the drive.
Oct 02, 2016 | Electronics - Others
How do i plug in my dane-elec flash drive?
Remove the cap and you will expose a usb plug. Plug that into any usb port on your pc.(perfered a port on the back of your pc cause those would be the most direct and powered ports)
Hope this helps.
Positive Feedback ALWAYS welcome :)
Mar 03, 2011 | Dane-Elec DaneElec 2GB USB External Blue...
When I plug in my flash drive, my computer won't read it. The light on the flash drive does not light up. Is there any way I can fix this?
Try it on another computer. If it works, then your computer's USB port has problem. Check the ports and make sure they are properly connected and are cleaned. Also make sure the USB driver is updated/installed. You can also try it on another USB Port of your computer. If it doesn't work on another computer, then I would say your Flashdrive is bad or gone.
Let me know if you need further help.
If you find this helpful, please take few seconds to rate the solution by hitting the 4 thumbs. If you can spare few minutes, you can even leave a testimonial to express your feelings about the solution.
Good Luck.
Thanks for using FixYa.
Feb 15, 2011 | Dane-Elec DaneElec 2GB USB Drive Red Hard...
I cant format my 2GB Kingston flash disk, when I plug it to the computer it is reading removable disk and when i try to format it it will start formating but failing to be formatted successfully.
that problem is usually caused by a failure of the hardware to properly recognize the USB drive, clean the contacts with WD-40 or with a contact cleaner. Try a different USB port.
Hope this helps
Dec 27, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I bought new HP p6000 Series Desktop computer where the driver is not reading Cruzer or any flash drive. What to do.
look on the back of your computer for a hi speed usb port, or just use any back usb port. some computers like mine dont have a "bus" to the mother board to the front usbs or because they are piggy backed to the front they dont pass through.
Oct 10, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
External hard drive 3,5" few months it was working properly, and it says usb device not recognized and it doesnot show up. please for solution
Hello sir/ma'am, hi, most likely you have cable problems, check and see if you can find another cable. The cable is the USB data cable, that connects from your PC to the external hard drive.
Please also check if your USB port is working fine, just simply plug in a thumb drive to confirm.
If its not the cable, its the external hard drive. Usually, the red light appears or the device is reading the drive continuously with no action. let me know your progress.
Aug 13, 2010 | Verbatim VER95327 USB Hard Drive
I have a lacie 1TB exteranl hard drive and i cant get it 2 read on my dvd player via usb port...any ideas
Dows your DVD player supports reading drives of 1 TB capacity?
Check if the drive works on a computer!
Aug 24, 2009 | LaCie Hard Disk 750GB with Hi-Speed USB2.0...
SanDisk 4GB thumb drive not recognized by my computer
Try any other computer but not open drive only see if they can read it. Also change USB port, sometimes some ports dont accept devices. Also check for latest antivirus software last such case viruses dont let me read any of my USB drives. If driver works to oter PC then you have virus.
Aug 11, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Asus P4P800-X USB Problem
Maybe your USB port on your computer is model 1.0 while the hard drive is a 2.0. That would cause it not to read it. Check your system information and see what model your USB ports are.
Mar 17, 2009 | ASUS P4P800-X Pentium Motherboard
Flash drive ports on teh fron wont work on pc
If your system is USB 1 rather than USB 2 then some flash drives will not work. Not all usb 2 flashdrives are backwards compatible. My kids flasdrives will only work on my usb2 ports & will not work at all on my wife's computer which has the older usb 1 ports.
Dec 19, 2008 | E-Machines etower 500is PC Desktop
Linksys Wireless-G WRT54G Router Logo
340 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
