Question about Primavera Project Planner P3 (PRIMAVERAP3) for PC
Weightage How to assign weightage to resources in P3 R3.1 ?
  • Joshua Durham
    Joshua Durham May 11, 2010
    What your asking for doesn't make sense. Can you explain what it is that your trying to accomplish?
I need to do an assignment on gender and culture and the divide between people
Searching assignment help by professional writers? Contact Assignment Helpers, quality assignment writing services in UK. We provide top notch papers to students and also do your assignments. Online Assignment Help UK Assignment Writing Services
Sep 18, 2013 | CTG Modem gender changer
Hi,I will like to have ? list of various websites that can Actually help with Answers to assignment
Website perform several functions. For example, website provide recognition of business establishments where amongs several data that is provided on site are resources contributing towards establishment operations. Websites may provide resources referencing where for example microsoft device sites provide technical support requirements. Alternatively, websites may have live features where for example, exchange of resources are achievable. Several websites perform various functionalities amongs which assignement resources are contributed towards. For example, school website provide shared resources also possible are assignement resources exploration features. However, websites could be designed to suit specifications explained briefly. If i was asked to design a website to help answer assignments, the following requirement would achieve the process.
First, The course subject would be required to determine assistance type. For example, math classes require calculator websites either as resource formular pages or formular establisment sites. if i was required to design a math class website, the formale sheet would be required to be key coded. Asking a computer programmer to create a web site would require the following lists.
1. The type of website, an example of which is assignment answering resources center.
2. Second, the programmer requires examples of what the website would perform to the requestor. For example, a simple assigments website in maths would have a separate page for calculator functionalities. Alternatively, maths websites may require from the requestor the trype of questions of assigments as module of construction. For example, i want a webpage to calculate by adding numbers. Programmers should be provided with 1+1 =2 where 1+2=3 as programmers visual guide to designing and coding the website. keep in mind that the type of request from the programmer would determine what would be produced.
Jan 11, 2011 | Computers & Internet
I just wanna know the weightage of each topic in maths,physics,chem for 2011 iit entrance test
You may refer this useful website -- www.askiitians.com
Hope the same would help in answering your query. Thanks.
Nov 19, 2010 | Cell Phones
Casio QT-6600: How to assign PLU to menu key ?
This is done in P3 and if it needs to be put in a menu it will have to be done in the pulldown groups.
Mar 30, 2010 | Casio Parts Cash Register PC Desktop
HI, TRANSCEND EXTERNAL HARD DISK FOLDERS NOT OPENING
try to format the HD using disk management. right click computer select manage then disk manager. look for your external HD and click format.
Mar 26, 2010 | Computers & Internet
How to be solve banker algorithm?example
I m providing you this from my college notes
Banker's Algorithm
* multiple instances of resource types IMPLIES cannot use resource-allocation graph
* banks do not allocate cash unless they can satisfy customer needs when a new process enters the system
* declare in advance maximum need for each resource type
* cannot exceed the total resources of that type
* later, processes make actual request for some resources
* if the the allocation leaves system in safe state grant the resources
* otherwise, suspend process until other processes release enough resources
Banker: Data Structures define MAXN 10 /* maximum number of processes */
#define MAXM 10 /* maximum number of resource types */
int Available[MAXM]; /* Available[j] = current # of unused resource j */
int Max[MAXN][MAXM]; /* Max[i][j] = max demand of i for resource j */
int Allocation[MAXN][MAXM]; /* Allocation[i][j] = i's current allocation of j*/
int Need[MAXN][MAXM]; /* Need[i][j] = i's potential for more j */
/* Need[i][j] = Max[i][j] - Allocation[i][j] */
Notation:
X <= Y iff X[i] <= Y[i] for all i
(0,3,2,1) is less than (1,7,3,2)
(1,7,3,2) is NOT less than (0,8,2,1)
Each row of Allocation and Need are vectors: Allocation_i and Need_i
Banker: Example
Initially:
Available
A B C
10 5 7
Later Snapshot:
Max - Allocation = Need Available
A B C A B C A B C A B C
P0 7 5 3 0 1 0 7 4 3 3 3 2
P1 3 2 2 2 0 0 1 2 2
P2 9 0 2 3 0 2 6 0 0
P3 2 2 2 2 1 1 0 1 1
P4 4 3 3 0 0 2 4 3 1
Banker: Safety Algorithm
* consider some sequence of processes
* if the first process has Need less than Available
* it can run until done
* then release all of its allocated resources
* allocation is increased for next process
* if the second process has Need less than Available
* then all of the processes will be able to run eventually
* IMPLIES system is in a safe state
STEP 1: initialize
Work := Available;
for i = 1,2,...,n
Finish[i] = false
STEP 2: find i such that both
a. Finish[i] is false
b. Need_i <= Work
if no such i, goto STEP 4
STEP 3:
Work := Work + Allocation_i
Finish[i] = true
goto STEP 2
STEP 4:
if Finish[i] = true for all i, system is in safe state
Banker: Safety Example
Using the previous example, P1,P3,P4,P2,P0 satisfies criteria.
Max - Allocation = Need <= Work Available
P1 3 2 2 2 0 0 1 2 2 3 3 2 3 3 2
P3 2 2 2 2 1 1 0 1 1 5 3 2
P4 4 3 3 0 0 2 4 3 1 7 4 3
P2 9 0 2 3 0 2 6 0 0 7 4 5
P0 7 5 3 0 1 0 7 4 3 10 4 7
10 5 7<<< initial system
Banker: Resource-Request Algorithm
STEP 0: P_i makes Request_i for resources, say (1,0,2)
STEP 1: if Request_i <= Need_i
goto STEP 2
else ERROR
STEP 2: if Request_i <= Available
goto STEP 3
else suspend P_i
STEP 3: pretend to allocate requested resources
Available := Available - Request_i
Allocation_i := Allocation_i + Request_i;
Need_i := Need_i - Request_i
STEP 4: if pretend state is SAFE
then do a real allocation and P_i proceeds
else
restore the original state and suspend P_i
Banker: Resource-Request Algorithm [129]
Say P1 requests (1,0,2)
Compare to Need_1: (1,0,2) <= (1,2,2)
Compare to Available: (1,0,2) <= (3 3 2)
Pretend to allocate resources:
P0 7 5 3 0 1 0 7 4 3 2 3 0<<<
P1 3 2 2 3 0 2<<< 0 2 0<<<
Is this safe? Yes: P1, P3, P4, P0, P2
Can P4 get (3,3,0)? No, (3,3,0) > (2,3,0) Available
Can P0 get (0,2,0)? (0,2,0) < (2,3,0) Available
Pretend: Available goes to (2,1,0)
Thanks And Regards
May 13, 2009 | Microsoft Windows XP Professional
Intel pro nic no i/o resources
Its simple try this card on some other if u get the same error replace the card
Feb 05, 2009 | Compaq Armada M700 Notebook
AFW-1430 fire wire card can't find enough resources on my laptop apparently to work
couple of things you want to try:
0. what operating system are you using? 9x may require for you to manually install and assign resources, 2000/xp should take care of resource asignment automatically
0.1. check if the bios version you have is the latest one, if not try to get an update and install... (backup your data first and make sure you get the right update or you may mess your bios for good)
1. check resource assigning in your bios, make sure your irq's are avaliable to be usuable by your operating system to used in order to assign them to the fire wire card.
2. it may take some time but you way want to check through the properties on each of the devices in device manager and look in the resource tab for any conflicts or
3. go to start > run > msinfo32 and look for hardware>share/conflicts
Sep 25, 2008 | NEC Computers & Internet
Upgrading hard disk
yes of course it will handle a 40gb hard drive..your P3 will handle a hard disk up to 60gb...coz i have a friend, his using a P3-700MHz,512mb, 64mb video card and barracuda 80gb hard disk=.)..to make it sure..bring your P3 to the computer shop so you can also know if your P3 is handle a 40-60gb hard drive..thanks..
Feb 20, 2008 | Dell OPTIPLEX GX1 PIII-550MHz 128MB 10GB...
Computers & Internet Logo
87 people viewed this question
Top Primavera Computers & Internet Experts
Tom Chichester
JEfromCanada
john smith
Are you a Primavera Computer and Internet Expert? Answer questions, earn points and help others
