Fan moter for ac dont work
There is a fuse I would check first if you haven't tried that yet. They had problems with the switches in some of those vehicles. If you could take the control out and unpug then reattach the plug it may start working meaning the switch is bad.
You may have a bad fan motor. Do you have a test light to check for voltage at the motor itself?
Lastly, there is a resistor set that changes from low to high that may have one or more resistors burned out.
Dale
under the right side below the glove box, mine was a loose connection. it is easily hit by a passengers foot
