Question about Rival CZF630 Deep Fryer
Cleaning how do i remove the bottom heating element that the cord plugs into in the back so i can clean it
    Scholar:
  • 135 Answers
From http://www.rivalproducts.com/help.aspx?helpNav=1: How can I clean my fryer? - Unplug from outlet and allow unit to cool. Always turn control to OFF then disconnect plug from wall outlet BEFORE disconnecting BREAK-AWAY CORD. - Clean the outside of the fryer and lid with a damp cloth. CAUTION: Do not use abrasive pads or alcohol to clean the fryer. - Remove basket handle, if one is included. Frying basket can be washed in hot soapy water. - Rinse and towel dry carefully. - Pour out oil and discard properly. - Wipe the inside with paper towels to absorb excess grease. Wash interior of fryer with hot soapy water. Rinse and dry thoroughly. CAUTION: Never immerse the fryer in water or wash in running water. If you own a fryer with a removable bowl or other removable parts, refer to the Owner?s Guide for your specific fryer to determine which parts can be cleaned in the dishwasher.
Posted on Mar 08, 2007
Ge ds4500eboww
Pull off exhaust vent. Clean. Remove back cover. Clean all airways free of lint and debris. Is this electric or gas dryer? If electric, plug back in and run dryer. Is the heating element glow red? Yes, check and make sure that air is now flowing freely out the back of the exhaust vent. No, replace heating element.
Jan 11, 2014 | Dryers
Power indicator lights up but there is no power
Remove exhaust hose. Clean out lint. Remove back of dryer. Clean lint out of air flow system including lint and heat unit(coils). Try dryer. Is heat element glowing red hot? If not, replace heat element. They burn out intermittently and need lots of air flow to have good life. Clogged lint traps shorten life cycles. Definitely a DIY project. See youtube for general process.
Jan 09, 2014 | Whirlpool Dryers
Kenmore stacked laundry unit. when it was plugged in sparks flew and small parts of the heating element fell and the power cord is ow black. can we replace cord and be ok
Heating element must be replacedas well as the cord. Make sure the drum screws were not screwed into anything electrical.
May 18, 2013 | Kenmore Dryers
My dryer make a sizzling sound when not started
sounds like something with the heating element, or the cord on the back of the dryer. unplug dryer and remove back plate and inspect the cord connection, if all is good, then open up dryer and inspect heating element, might as clean all the lint out,also. Hope this helps Tim;
http://www.applianceaid.com/take-apart.html
May 22, 2011 | GE Dryers
How do I replace the bottom oven element in a CDA CD 907 double oven
ISOLATE MAINS POWER BEFORE WORKING ON THIS APPLIANCE
Remove the back of the oven check temp controller before replacing or buying element, as this can often stop any heat being produced. The element is in front of the fan, if this model is fan assisted, remove fan, after removing element inspect to see any small hole in metal, if you see a large hole more than 10mm , this could be a sign that the fan needs cleaning. Clean fan with WD40, do not switch oven on untill fan has dried off. Then replace element, switch oven on low with door open, if you feel slight heat, go for a full test, gradually build up heat, keep on for at least 30 mins, make sure the oven reaches temp, you can expect some smell from a new element, this is protective oil, and considered normal.
May 10, 2011 | Ovens
My maytag neptune dryer doesn't blow any hot air
on top of the heating element on the left side there is a white 2connector part, that is the heater thermal fuse. disconnect the dryer power cord and one wire of the thermal fuse and use a meter to find out if you have continuity to it. if not replace it. also check for burn wires at heating element. also test heating element by disconnecting one wire and using an ohm meter test it at 2 therminals. it shoul measure 10-12 ohms.
Feb 14, 2011 | Maytag Neptune MDE5500AY Electric Dryer
I have a Bosch nextt 500 series dryer and after 2 years of use the problem I have is the heat will shut off and the dryer will keep running and I have to press the reset button on the backside of the dryer
Open the front panel, remove heat exchanger and clean. also clean out lint tray. this might help a little. Now lets check if the thermal sensor or heating element needs to be replaced.
Unplug the dryer. remove the panel in the back of the dryer that covers the heating element. ( the inner panel). On top of the heating element you will see a thermal sensor with a small red button on it. Thats the manual reset button. To test if the heating element is working properly you can disconnect the wires from the sensor and clip the connectors together . Plug the dryer back in and start it. pay attention to the heating element. It should begin to glow shortly. if it doesn't then your heating element is bad and needs to be replaced.
Unplug the dryer. Connect the wires back to the thermal sensor. Plug the dryer back in. Before you start the dryer, press the red button on the thermal sensor. Start the dryer. If the heating element doesn't come on and dryer doesn't heat, then you need to replace that sensor.
Feb 01, 2011 | Bosch Axxis WTL 5410 Electric Dryer
I'd like to know how to change a heating element in my dryer (29' whirlpool) I'd like to know exactly how to take it apart and where to find the element. I'am not sure of the dryer #
first you nead to unplug the dryer,next you nead to remove the vent hose,next you nead to remove the back panal and the power cord cover,on the left side you will see the heater housing,at the bottom you will see the heating element,there are four wires,the two at the bottom are hooked to the element,you nead to pull them off,the other two wires are hooked to the high limit switch,you nead to pull them off,next there are two 1/4"screws,one on each side off the heating element,remove them,now pull out on the bottom of element,with element removed,remove the high limit switch from old element and put it on the new element,take new element and put it back in the heater housing and replace the two 1/4" screws,you will see that the two wires that go to the element are biger than the two going to the high limit switch,put the two wires to the element,now replace the two wires to the high limit switch,replace the back panal and the power cord cover,replace the vent hose,plug power cord in and check element out.
Nov 25, 2009 | Whirlpool LER5636P Electric Dryer
Dryer not heating, vent is clean top and back. Heating element?
You ned to check for 230 volts at where the cord connects. If so, unplug, check thermostats with ohm meter, then ohm element with wires removed from terminals whatever of the last are open replace.
Mar 12, 2009 | Dryers
Oven heat
There is a bottom hidden element that is the main element used for baking and cleaning. If its not heating then the element has gone bad and needs replacing. If you have a volt meter then you can confirm this by checking the voltage between the two terminals sticking out of the rear of the range. There should be 240vac across the two. If you have that then you need a new element if you don't then you need a new control board.
Nov 03, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Rival CZF630 Deep Fryer Logo
294 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Ric Shull
Ric Shull
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
