Question about Williams 2509612 Ceramic Mid-Size Heater
A williams wall heater 3509622 not used in 2 years.
Can i just light it or do i have to clean something in it
The Williams manufacturer site is www.williamscomfortprod.com a link to the manual is http://www.wfc-fc.com/pdf/Monterey_Top_Vent_IOM.pdf
Posted on Jan 10, 2009
Williams wall heater 2509622. How do I keep the pilot on? It tends to turn off after it reaches the desired temperature.
WILLIAMS 2509622 OWNER'S MANUAL Pdf Download.
www.manualslib.com > Brands > Williams Manuals > Furnace > 2509622
2509622; 2539622; 2559622; 3509622; 3539622; 3559622; ... WHAT TO DO IF YOU SMELL GAS: ... Williams furnace co. direct-vent wall furnace owner's manual (24 pages) ... Caring for Your Furnace ............24-25 Locating Wall Furnace and Thermostat ........6-7 Learn how to keep your new Williams Furnace operating.
How to light Heater or Furnace Pilot Light Gas Pilot of ...
? 5:01
https://www.youtube.com/watch?v=FZVQmKTYTTg
Oct 25, 2013 - Uploaded by 3p0cHx
How to light a gas pilot for a heater or furnace of the Williamstype. This is a general guide and is not ...
[PDF]Monterey Installation Instruction Manual - Home Depot
Dec 08, 2015 | Williams Heating & Cooling
3509622 model number furnace heats up but does not blow any air out. Neither hot or cold air.
You are describing a Convection heater , they do not have any fans inside.
Nov 08, 2013 | Thermos 3509622 Heater
How do you wire the thermosat on williams wall furnace model 3509622
This heater has 2 type gas valves one valve has the thermostat built into it. No wiring needed for that puppy. Looks like this:
So I am guessing that one ain't you.
Your heater must use a millivolt gas valve with the 2 wire wall thermostat. The pilot generator does 2 things. It holds the pilot on and it produces voltages that operate the solenoid and open and close the valve when the room thermostat makes contacts. So what goes wrong with these? The pilot generator will sometimes hold the pilot flame but whn the 2 wires are touched together or you tun on the wall thermostat the whole thang just dies. That my friend is a weak thermopile generator. The other thang that goes wrong is the solenoid on the gas valve is open and therefore the gas won't come on. Their is also a fuse mounted on there that melts and kills the magnet that the generator holds in for the pilot.
Nov 04, 2011 | Williams 2509612 Ceramic Mid-Size Heater
I have a Williams Ceramic Gas Wall Mounted Panel Heater, the pilot is on but the furnance is not working
Jump the two wires going to the thermostat, if it starts , you have either a bad thermostat or a broken thermostat wire. If it does not fire up, you will need to check for 24 volts AC going to the gas valve from the transformer. If you have voltage, you have a gas valve issue. If no voltage, check for a limit switch that may have overheated with an Ohm meter. If they all test good, replace the transformer.
Jan 22, 2010 | Williams 2509612 Ceramic Mid-Size Heater
The pilot light will not stay lit, I was told
Hi, this heater doesn't have a thermocouple, it uses a pilot generator which is more reliable so I doubt you need to change it out. First thing to check is that you have a clean "sharp" blue pilot, you should be able to hear it quietly roar. If it is yellow and appears "soft", the pilot need to be cleaned. The easiest way is to use a straw or tubing of some sort to blow into the pilot, gently tapping the pilot assembly. That should clean it up and heat the pilot generator properly. Tighten the the screw terminals at the control valve to assure good electrical connections and last but not least turn off the thermostat until you get a standing pilot. Good luck and stay warm.
Jan 13, 2010 | Williams 2509612 Ceramic Mid-Size Heater
Williams heater 3509622
Go to the home depot website, they have pdf files for all the williams heates.
May 29, 2008 | Williams 2509612 Ceramic Mid-Size Heater
Heats up and shuts off
There are 2 things to check. First is the thermostat. Next is the thermal safety switch located up on the heat exchanger. by-pass these one at a time by connecting the wires together. If that solves the problem, change to a new one. If neither one of these items are bad, you need a new gas valve.
Dec 29, 2007 | Williams 2509612 Ceramic Mid-Size Heater
Williams 2509612 Ceramic Mid-Size Heater Logo
571 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
