Question about AMD eMachines Desktop System w/ 17'' CRT Display, 2.0 GHz Athlon 64 3000+ (W3400)
Emachines computer My computer feeze and it wont let me turn her of ,not even the keyboard works when that happens.I have scan her ,i put her recovery disc and still it keeps freezing.
    Scholar:
  • 113 Answers
Any computer would freeze either due to a hardware conflict or due to some software installed which is taking up all the resources and your PC stops responding. Have you made any changed recently? Installed any new hardware or software?
Posted on Mar 08, 2007
SOURCE:
Turn off safemode
Remove any DVDs or CDs from the optical drives and then unplug all peripheral devices except for the keyboard and mouse.
Click the "Windows" button and then type "eMachines recovery management" into the search box.
Click on "eMachines recovery management" in the results list and then click the "Restore" tab.
Click "Password Settings" and then type a new password into the text box.
Click "OK" and then click "Restore System to Factory Default".
Type the recovery password into the "Password" text box and then click "OK".
Click "Next" To start the recovery process.
Click "Finish" and then wait for your computer to restart.
This procedure could take several minutes.
Once your computer has restarted, you'll be prompted to create a new user account, enter the date and time and set up the internet settings.
or if you are running XP
If you set your machine back to eMachines factory settings, it might help you for a short while but if you don't have effective virus protection your problems will return in short order.
You should get rid of this virus with an effective virus remover.
You can run Bitdefender's free online scan which doesn't need to be downloaded http://www.bitdefender.com/scan8/ie.html
If you know when you got the virus, you can do a system restore to a time before the virus was on your system.
This article tells you how to run it from safe mode http://bertk.mvps.org/html/safemode.html
Your best protection in general is a complete internet security suite such as Bitdefender or Norton internet security 2009.
More information here http://www.ask-the-computer-doc.com/comp...
If you need to totally rebuild your system and you don't have a recovery disk, contact eMachines to get one.
You might also try a Windows repair install if you have the operating system disk.
Follow the directions here for XP http://www.michaelstevenstech.com/XPrepa...
Aug 04, 2013 | E-Machines eMachines Desktop PC
WINDOWS XP PRO CAN`T RUN SHELL32.DLL,CONTRL_RUNDLL WSCUI,CPL
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
you should have no input while chkdsk utility is in progress any input might further damage your computer or
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
or
Use an external memory device such as a DVD, flash drive or external hard drive to back up the data you need to save from your eMachines computer.
Any data that isn't saved to an external source will be erased when the computer is restored to factory settings.
Remove any discs that are in the optical drive and unplug the computer's peripheral devices, such as an Ethernet cable or scanner.
Do not disconnect the keyboard, mouse or monitor.
Click the Windows "Start" menu and choose "All Programs."
Navigate to "eMachines" and choose "eMachines Recovery Management."
Click the "Restore" tab.
Click "Password Settings" if you have not already set a recovery password.
Type a new password in the text box and click "OK." Click "Restore System to Factory Default."
Type the recovery password and click "OK." Click "Next" to wipe the eMachines computer's hard drive and begin the recovery process.
Select "Finish" and wait for the eMachines computer to restart.
Use the series of installation prompts that appear on the screen to create a new user account for your operating system, set the system date and time, and set up your Internet settings.
hope this helps
Oct 14, 2012 | E-Machines W6409 (7234) PC Desktop
Both my keyboard and touchpad are not working. What do I do?
Did you try a system restore to bring the computer back in time before this happened? you mentioned recovery, did you do a full recovery of windows ? "fresh install" If you have a backup disc the hard drive needs to be completely reformated before the backup disc is used, because it looks like a virus got into your system, run a deep or full scan to find out, go to www.download.com Type: Malwarebytes Anti-Malware run a full scan to see what it finds, "free software"
Apr 15, 2012 | Sony VAIO VPCEB42FX/BJ Notebook
My emachine won't recognize my modem. Cox repair man said it was my computer. I even put the recovery dics in and restored my computer clean and it still won't work.
Go to the emachines web site and download the latest drivers. Also check your bios section and see if it the LAN section is enabled. The bios section is available at atart-up by pressing F1 F2 or the delete key when the system is first starting. Use the arrow keys to navigate through the sections. After you finish press f10 on your keyboard to save and exit.
Dec 06, 2010 | E-Machines (T2958) PC Desktop
Out of nowhere my Emachines laptop keyboard has stopped working
Sounds like it's either the motherboard or you may need a new bezel.
Another solution that may be cheaper would be to reinstall the operating system. Or do a factory image recovery and see if it's a software issue. First check the device manager to see if there is an obvious driver issue. If not try reinstalling Windows 7.
If that doesn't work then replace the bezel.
If that doesn't work then replace the motherboard.
Jul 22, 2010 | E-Machines AAFQ50400000K0 Keyboard
I tryed that even in safe mod. did not work i have ben working on this for a mounth or more.i dont have aney money so i gess this will not work thank you for trying.
You have a virus that is blocking your administrator rights. Do a full scan of the computer using this software to rid. After the scan, reboot and all will be good.
(free trial - works great)
http://www.pandasecurity.com/usa/
If you cannot even install programs, last resort is to restor computer to factory settings. This will erase everything you have on computer.
Are you using windows XP or Vista. I can walk you thru the restore if you let me know which Windows you have.
Oct 03, 2009 | E-Machines eMachines Desktop PC
My emachines desktop crashed,wouldn't even let me go into safe mode. when I try to use the recovery dvd that I just bought from emachines, I keep getting error code 4. Where do I go from here?
ok try this. turn on your computer and put the disk in and turn off the computer right away and turn it back on and the recovery screen should pop up and go from there hope this helps
Sep 24, 2009 | E-Machines eMachines Desktop PC
After installing hard drive, monitor, keyboard, mouse not working
Have you tried to enter BIOS? Are you able to enter BIOS?? There may be an option you have to hit to enable SATA, and to select the boot device order, which may be messing things up.
Also, remember that STATIC ELECTRICITY is your enemy! Ground yourself when working inside the case.
Dec 30, 2008 | E-Machines eMachines Desktop PC
Emachines pc help plz
Besides MSN, what else can you not do?
Jul 07, 2008 | E-Machines eMachines Desktop PC
AMD eMachines Desktop System w/ 17'' CRT Display, 2.0 GHz Athlon 64 3000+ (W3400) Logo
76 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Carlo Barzo
Carlo Barzo
pankaj rautela
pankaj rautela
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
