Question about Roomba Robotic Floor Bagless Vacuum
Roomba 4108 does not charge
We bought a brand new model of roomba after a few weeks it would not charge called roomba company did not help left the unit for over a year thought to try it again bought a new battery replaced the old one charged 1 time and went dead in 15 minutes and smae problem recurred when plugged into a charger (for days now) continues to show blinking red light?
  • 7 more comments
  • Anonymous Dec 31, 2008
    when i plug the roomba the light is flickering red. it seems that it is not taking charge at all.
  • fryan1415 Jan 04, 2009
    My roomba 560 does the same thing -- won't charge even when left on the charger for more than 24 hours. I've sent 3 messages to roomba tech support without an answer from them.
  • Anonymous Jan 05, 2009
    Used it only once. Wouldn't recharge after 2 days of charging.
    Shows blinking red light.
  • ownrental Jan 13, 2009
    My Roomba Discovery also will not charge even with a brand new battery. Talked to i-robot customer support and they say that my internal charging system isn't working. They suggest buying a new roomba. Does anyone know how to fix this. I have tried to reset many times. I borrowed another roomba and tried my battery and charger with that roomba and then put the charged battery in my roomba. It worked fine, but after running the battery down my roomba again would not charge it.
  • beck00 Feb 26, 2009
    I am having the same problem with a Roomba 550 which is out of warranty. I replaced the battery and the new battery worked ok the first few times that I used it, now when I put it in the dock, or directly connect the charger to it I get a flashing red light with a ! next to it flashing once every few seconds (bad battery code) I have checked the contacts, tried resetting the unit -nothing works, I guess the battery could be bad but I just doubt that since so many others have the same problem. If its the charging circuit, how do you fix that?
  • martinb981 Apr 03, 2009
    I also have a 560 which flashes red and flashes the exclamation point whenever I try to charge it. Brand new battery. Did ALL the steps and then more...still, flashing red light.
    The last thing I need to do right now is buy a new Roomba; this thing is less than 19 months old. We liked it a lot when it worked but I've had toys for the kids with a lot more engineering and design that have lasted longer than this thing.
    I sent an email to iRobot so let's see how they respond. Meanwhile, I've just ordered a new Roomba for my sister and if I don't get a proper response from iRobot, I will cancel that order.
    And I will do everything I can to warn people NOT to buy Roomba. I've come across dozens of online posts from people who have the same issues with the red flashing light.
  • Anonymous Apr 14, 2009
    Same problem as everyone else...I had the Roomba Scheduler and it worked wonderfully for about a year. Then, one day, it just stopped holding a charge very long and now, not at all. So, my mother-in-law gave me her new Roomba, since she didn't use it much, and the same thing happened with the new one. I've tried re-setting the battery, but nothing works...:(
  • fryan1415 May 11, 2010
    When the battery is removed, the power button doesn't do anything. Is this really the correct sequence of steps?
  • Anonymous Mar 23, 2014
    Brand new Roomba 780 robotic vacuum. First run around my living room and a red light appeared that is shaped sort of like a trashcan. My DVD says to look in the owners manual, but there is no owners manual. I bought two units and neither one has one.
    Problem Solver:
  • 17 Answers
Try resetting your Roomba by removing the battery, unplug the charging connector, hold down the Power button for 30 seconds. This will reset the charging system, replace your battery, connect your charger and see what happens. By the way do you also have a homebase ? If so try that too
Posted on Jan 10, 2009
  • lisaannvicto Nov 13, 2010
    Resetting the battery worked great! This was my first true problem... I actually have owned 2 successful roombas and have been very happy with both. The batteries themselves are only designed to last a year or two... that is the downfall of the product. Going into the purchase knowing that fact, I still love the product.
Firstly the fastest killer of a battery, any battery, is over-charging. Charge per manufacturers instructions and then don't leave your item on the charger after it's charged. This goes for any device such as cel phones etc.
Second, clean the battery contacts. Our second hand Roomba was so dirty when we got it that the battery wasn't even making contact. Remove the brushes, clean them, clean off all the hair etc and use alcohol to wipe clean the two contact points under the brushes as well. It should take a charge after that.
Posted on Jan 11, 2009
I smell a class action suit coming.
Posted on Feb 18, 2010
    New Friend:
I was having a similar issue, in that the battery did not seem to be charging, even though we bought a brand new battery. My husband realized that the battery wasn't staying locked in tight, therefore it wasn't engaging the charging ports. We found that if we pushed up on the battery, the charging light would come back on, but if the unit got bumped at all, it would disengage and stop charging again. So, we actually plugged directly in to the charging port on the side of the robot and got the battery charged, but then had more issues whenever it turned on to clean, it would vibrate and the battery would come loose and it would shut down. I tried securing the battery in place by wedging some cardboard down the side, which so far is technically working, although it did shut down once already when it ran in to a wall and must have shook the battery loose again. I may try adding another layer of cardboard to get it really snug and see how it goes.
Posted on Feb 15, 2013
I just recieved a 4108 Roomba from a friend and it charges, or at least I think it did. The red light quit blinking and was red non-flashing, but when I push the clean button all it does is beep! What causes that=any help would be wonderful....
Posted on Aug 20, 2010
We were just given an unused but old model 4108 (leftover from couple who used to sell them) and the battery stays charged for maybe 10 minutes...
And to iRowner's comment above about NOT leaving the unit charging constantly; a NEW Roomba we bought has specific instructions to LEAVE it charging all the time, ready for use. Of course if we have a cynical outlook one might say that this advice is given so that the battery actually WON'T last very long thus forcing the purchase of a new one.... but surely a manufacturer wouldn't ever suggest that, would they?! :(
Posted on May 06, 2010
Roomba 595 no lights - not charging
Just a idea but have you tried replacing the battery? Here is a link to a forum on this topic.
http://www.robotreviews.com/chat/viewtopic.php?t=2901
Dec 29, 2015 | iRobot Roomba 560 Robotic Vacuum
Roomba 630 dead or other issue?
On your operators manual there is a number u can call for cust support. If not then take back for swap out.
Dec 12, 2014 | Roomba iRobot 630 Vacuum Cleaning Robot
New Roomba Battery Not Holding Charge - charged once then died
It is possible for the charging system inside the roomba to call it quits. What I did to remedy this, since my roomba was out of warranty and I did not want to scrap it, was to buy a charging base on ebay. This charging base accepts different types of roomba batteries and even the scooba battery. The inconvenience is if you have a newer model roomba that has the battery inside, then you will need to remove the screws on the bottom plate to remove the battery. Hope this helps.
new-roomba-battery-not-holding-charge#solution-section-qgwpio3es2ee0iuiltq5rfxr-1-0.jpg
Jan 23, 2014 | Roomba Robotic Floor Bagless Vacuum
I noticed my run time was getting shorter and shorter, within the first 6 months. I checked my charger and base with a V.O.M. okay. About 4.4 volts on the base about 14 volts on the direct line. I bought...
To extend Roomba's battery life and keep Roomba cleaning at peak performance: • Always keep Roomba plugged in when not in use. • Recharge Roomba as soon as possible. Waiting several days to recharge Roomba can damage the battery. • For storage off the charger, remove the battery from Roomba and store in a cool, dry place. • Blue or black batteries should be stored after Roomba has been used. • Yellow batteries should be stored after being fully charged.
16-Hour Refresh Charge If Roomba has been left off the charger for an extended period, Roomba will initiate a special 16-hour charge cycle. This extensive charge refreshes Roomba's battery and extends the battery life. While charging, Roomba's "Clean" button will pulse quickly. Note: For best results, do not interrupt this Refresh Charge.
Happy Holidays The FixYa Team
Dec 18, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
Seems to charge but then wont come on
Sounds like you bought a defective battery
You can test for this by removing the battery and holding the power button for 15 seconds. This will restart the charging cycle as if the battery were new. If it still goes red get a refund and a new one.
Mar 07, 2010 | iRobot Roomba 4105 Bagless Robotic Vacuum
Charging error 5 - battery not workiafter 4 calls and 4 different
Generic works fine, and that charger does too. If your charge light and dock light are on then you'll be okay.
Save cash, go generic!
Mar 03, 2010 | iRobot Roomba 560 Robotic Vacuum
Roomba Battery (existing and brand new one) Not holding a charge.
The Charging circuit on the main board is dead. Either replace the main board or repair it if you have the skills and equipment.
Jan 06, 2010 | iRobot Roomba Discovery SE Bagless Robotic...
Stopped working a few weeks ago - bought and installed new battery seemed to be working OK - now after about a week, it goes for about 15 minutes then stops...
It may need a longer charging period to bring the battery up to full charge. If you have a voltmeter, measure the battery voltage while it is being charged--it should read several volts above the rated battery voltage. If nearly equal, the charge unit may need repair or replacement. Good luck!
Jan 04, 2010 | iRobot 4150 Roomba Vacuum
Help
Same thing happened to me, I called the company, and they told me to remove the battery, press the on button for 5 seconds, which clears the system, replace the battery and do a long charge 12 hours. I'm in the process of doing that now.
Dec 14, 2007 | iRobot Roomba Red 4100 Bagless Robotic...
Roomba 4200 Scheduler
The best for the battery if (NiMH). Discharge completly, than charge full (charge more even the charger indicates full charge)
Clean every part, maybe a hair slow down the wheels and thats why need more power.
Here some tip from the web:
With proper care, one iRobot Roomba battery can last for hundreds of cleaning cycles before you need to replace it. Here are some things you can do to extend Roomba's battery life and keep Roomba cleaning at peak performance:
Use your Roomba frequently. Your Roomba is powered by a rechargeable nickel metal hydride (NiMH) battery, which lasts the longest when you use it regularly.
Keep the brushes clean. If the brushes and brush axles get clogged with hair and other debris, your Roomba will strain to spin them, using more battery power than normal. In extreme cases, the battery can even be damaged. See How to remove and clean Roomba's brushes
Keep your Roomba plugged in when not in use. If you have a Home Base®, keep your Roomba docked in the Home Base and plugged into the charging brick. If you don’t have a Home Base, keep your Roomba plugged into the APS Fast Charger.
Make sure you are charging your Roomba correctly. When your Roomba is plugged in correctly, the solid green light should be illuminated on the charger or on the Home Base.
Plug your Roomba in as soon as possible after using Max Mode. Leaving your Roomba unplugged for more than 24 hours can damage the battery.
Place your Roomba and the Home Base on a smooth, hard surface when yourRoomba is plugged in. Make sure your Roomba and the Home Base have plenty of space for ventilation. Do not charge your Roomba on a carpet or rug.
Charge and store your Roomba in a cool, dry place. Keep your Roomba out of direct sunlight and away from sources of heat such as windows, radiators, heating vents, and large appliances.
Remove the battery when not using your Roomba for a long period of time. If you will not be using your Roomba for more than a few weeks, fully charge the battery, remove it, and store it in a cool, dry place. When you want to use your Roomba again, insert the battery and fully charge it. Leaving your Roomba plugged in for weeks when it is not being used can damage the battery.
You can purchase a second battery or replacement online at the iRobot Store.
Nov 11, 2007 | iRobot Roomba 4210 Bagless Robotic Vacuum
Roomba Robotic Floor Bagless Vacuum Logo
5,641 people viewed this question
Top Roomba Vacuums Experts
Lonnie Arks
D. E. Hev
Are you a Roomba Vacuum Expert? Answer questions, earn points and help others
