Question about Katadyn Kata CC-191 Camcorder Shoulder Case
Difference between vga and rgbhv - Katadyn Kata CC-191 Camcorder Shoulder Case
    Scholar:
  • 188 Answers
VGA is a technical standard for computer displays. RGB is an analog video system for TV, high resolution transfers and display purposes. They are not compatible.
Posted on Dec 12, 2008
I need to purchase a rgbhv projector to replace one that has gone bad. Suggestions?
What lumen output? Does it have to be RGBHV? You can use an RGBHV adapter to VGA, etc to be able to use just about any projector. I'd be happy to give you some suggestions if you can tell me screen size, distance from projector to screen, projector lumen rating, 4:3/16:9/16:10 aspect ratio, etc.
Feb 19, 2015 | Office Equipment & Supplies
How do i connect my dvi to vga to my misubishi ws-65313
you can't, DVI is a digital video source and VGA is an analog video source. however there is a VGA to component RGBHV cable that you can use. the Mitsubishi TV is very limited to the resolutions the VGA output can be. only 1080I, 480P or 480I. HD component video input in the menu you must change the source from Y /Pb/ Pr to RGB.
Jun 07, 2014 | Mitsubishi WS-65313 65" Rear Projection...
Hi my laptop went in for repair and they said it cant be fixed as the vga isnt working? what is this and could it be solved
A Video Graphics Array (VGA) connector is a three-row 15-pin DE-15 connector. The 15-pin VGA connector is found on many video cards, computer monitors, and some high definition television sets. On laptop computers or other small devices, a mini-VGA port is sometimes used in place of the full-sized VGA connector.
DE-15 is also conventionally called RGB connector, D-sub 15, mini sub D15, mini D15, DB-15, HDB-15, HD-15 or HD15 (High Density, to distinguish it from the older and less flexible DE-9 connector used on older VGA cards, which has the same shell size but only two rows of pins).
VGA connectors and cables carry analog component RGBHV (red, green, blue, horizontal sync, vertical sync) video signals, and VESA Display Data Channel (VESA DDC) data. In the original version of DE-15 pinout, one pin was keyed and 4 pins carried Monitor ID bits which were rarely used; VESA DDC redefined some of these pins and replaced the key pin with +5 V DC power supply.
the only solution for that is to replace your vga.
May 31, 2011 | Computers & Internet
Can i connect toshiba satellite a205 to tv?
Yes VGA carries RGBHV--RGB and Horizontal and Vertical Sync information along with DDC info where available.
Now is that port on your TV a d-sub 15 pin standard VGA connector?
http://en.wikipedia.org/wiki/VGA_connector
If it is, then yeah you should be able to output VGA from a PC to the TV with a proper cable.
However if the TV has DVI or HDMI connections on it, it's better for you to connect it that way. DVI/HDMI is a digital signal and if it's a digital-based display tech TV, then you're better off using that. Also if the TV does resolution above 1360x768 (i.e. if it does 1080p) you can get higher resolution by going via DVI/HDMI...
Dec 01, 2008 | Toshiba Satellite A205-S4617 Notebook
How to set up hd on this tv
Hi Brien,
You can hook-up your HDTV via the BNC inputs with the right equipment below.
Here is the link to a website that sells video transcoders for projectors and projection televisions. In addition, the link will take you to one particular transcoder that will work for your application.
http://www.curtpalme.com/RTC2200.shtm If you use this transcoder you will have to find a VGA to 5-BNC breakout cable to connect the output of the transcoder to your TV HDTV RGBHV inputs. The extra VGA input on this transcoder will not be used for your application. They sell another product that comes with the cable you need, but I did not see it listed separately. That product is their HDFury Basic Kit at the link below.
http://www.curtpalme.com/HDFury.shtm
Regards,
MyTvGuy
Jan 12, 2008 | Mitsubishi VS-80803 TV
Upgraded DirectTV satelite TO HD
direct tv hd receiver is hdmi or rgb which is a different signal than the rgbhv input on the back of older mitsubishi tv . You can buy a converter that converts the format for about 90 dollars online. It converts rgb or component to vga/rgbhv
Oct 24, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Video Cameras Logo
400 people viewed this question
Top Katadyn Video Cameras Experts
Are you a Katadyn Video Camera Expert? Answer questions, earn points and help others
