Question about Microsoft LifeCam VX-3000 Web Camera
It won't let me finish installing the prog.
That's basically it... it says blah blah blah some error occurred and we cannot do this etc.. and it doesn't let me finish the installation either
    President:
  • 8,637 Answers
Normal 0 Disconnectthe Camera from the USB port and reinstall the CD or Downloaded softwareprogram. When the program asks you to connect the camera to theUSB port, do so and it should work.Then to use it on the Web, do this.
Web Camera’s have to besetup on the program they are to be used with. Just installing the cameraon your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order forthe Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Yourfriends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
Hopethis helps. Bud
Posted on Mar 17, 2009
    Genius:
  • 1,061 Answers
Http://www.microsoft.com/products/info/product.aspx?view=22&pcid=c950498b-0ed3-48f1-ad10-99091c72fd76&type=ovr.download currant drivers here.You must uninstall old drivers first.Was this solution helpful? Show your Appreciation by rating it.RICHARDM69
Posted on Dec 14, 2008
MSI Laptop Error- 0xoooooe9 "This error can be caused by unplugging a removeable storage device blah blah blah.... it wont get off the error screen and start windos. What do i do?
Ok, this error has occurred and will continue to occur, because a drive was removed, from the system, before data that was meant to be written/read, to/from the "Drive" was completed.
The only way around this is to reconnect the device so it can Finish what it is doing. If you have been using a USB drive, then you need to reintroduce that back to the system.
Now if you cannot, do this, then I would suggest that you simply perform a system restore. That will hopefully restore you system to where it was BEFORE this all happened.
Before is a a link how to do the system restore.
support.microsoft.com/kb/306084
Aug 25, 2010 | Computers & Internet
Not saving to desktop as ''problem occured Close and try
Let's try to isolate the problem first
1) Try downloading something different from a different website. If you succeed, then there is a problem with the original file or the connection to the original website. If you get the same error message, go to the next step.
2) Check the disk for errors. Run chkdsk c: /r. It will tell you that it cannot lock the disk blah blah blah. Anwser "yes" and restart. It will take quite a while to check the disk, but it will fix all fixable errors. Then, try again. If it doesn't work, go to the next step
3) Do you have a "download accelerator" installed and running (e.g. GetIt, Donaload Accelerator Plus, etc??) Some websites do not work well with download accelerators. Don't ask me why. They just don't. Either disable it or uninstall it and try again.
4) Try a different browser. If you're using Internet Explorer, try using FireFox or Opera
Please, report back to see if any of these helped.
Mar 26, 2010 | Dell Inspiron 1420 Laptop
Xp not install in compaq presario cq50 139wm
In Windows XP, The STOP: 0×0000007B: error often occurs if you move a hard drive that contains Windows XP to another computer or if you have just installed a newmotherboard or drive controller. This error occurs in these cases because your registry does not contain driver entries for the current motherboards drive controller. So in effect, the device driver that Windows XP is loading from the registry will not work with the new drive controller.
Fixing the STOP: 0×0000007B: Error:
The easiest approach to fixing the error is to locate download and install the latest hard drive controller driver for your motherboard. In many cases the driver in question controls a ATA or SATA device.
There are other problems including viruses that can cause this error and information regarding these causes can be found HERE
Jan 01, 2010 | Computers & Internet
I have a problem installing my Vimicro USB PC Camera 305 on my Windows XP. I start to install but still doesn't work. I try to uninstall but I cant do that from CONTROL PANEL pls tell me how to do that....
It is a pain.
Try the following. Re-run install, insert CD and it should start to load?
The exception is it should come up and say do you wish to uninstall Blah blah . Click Yes. When finished it will want to restart.
Before restart, remove usb webcam. restart.
Go to my poota/programs/and look for the camera file/ it may have been removed in that no problem/ if file is still there/right click/remove. Restart.
Complete restart/then setup CD Webcam again. Sit with it click Ok when asked even not a recognized prog, still click continue.
After completion. Reinsert usb of webcam! wait till it loads, asking silly Q, continue. till finish.
If sucessful, find it in programs if you didn't click for desktop icon?
Startup screen should show small white screen, couple of Q's it can't do something, ignore. You will end up with blank white/black square.
Click menu at top, click devices, dropdown click your cam name, should then open to a larger screen. If you need to alter things, click options.
All this of course if it loads.
Best of British.
Nov 14, 2009 | Computers & Internet
I cannot install games on my Nokia 7610. Each time trying to install, gets a notification that - Nokia Application Installer - " The application installer is already running in the Phone. Please finish...
Where have you installed the spiderman? if on the memory card, backup your card data minus the games, format it and restore the card data. See if that solves the problem.
Jul 30, 2009 | Nokia 7610
Setup cannot continue because an unexpected error occured
You need to reinstall the driver again.
1. Disconnect camera from USB port
2. Remove driver by: right click on 'My Computer', 'manage', 'device manager', right click on the VX-1000, 'uninstall'....
3. Reboot/restart
4. Ignore popup 'do you want to blah blah..'
5. Install driver from driver disk or file
6. reboot/restart
7. Connect camera
8. Test using MSN audio/video tuning wizard
Guaranteed fix!
Jun 03, 2009 | Microsoft LifeCam VX-1000 Webcam
Acer Aspire 5920 problem
Your best play is to restore the machine to the factory settings. To do this, power up the machine and immediately press ALT+F10. From there you will enter Acer eRecovery Management which will give you the option of returning the machine to the factory settings.
WARNING:
This will erase everything you had stored on the machine!! ie data files, pictures etc...
Apr 12, 2009 | Computers & Internet
RESTARTING COMPUTER(AMIGOS)
hi powee;
have you recently installed some device driver?
This error usually occurs after the installation of a buggy device driver, system service, or BIOS. To resolve it quickly, restart your computer, and press F8 at the character-mode menu that displays the operating system choices. At the resulting Windows 2000 Advanced Options menu, choose the Last Known Good Configuration option. This option is most effective when only one driver or service is added at a time.
here is the link;
http://www.microsoft.com/technet/prodtechnol/windows2000serv/reskit/w2000Msgs/6077.mspx?mfr=true
hope it resolves your problem
Jun 19, 2008 | HP Pavilion 8860 (P2941A) PC Desktop
ERROR ABOUT DRIVERS
here is web link for all window vista drivers for your laptop COMPAQ V3225AU
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&cc=us&dlc=en&product=3360271&lang=en
download them and run the exe files
I suggest making a folder on desktop called drivers then make individual folders and naming each download specifically as audio driver , video , etc
Hope this was helpful; friend
Best of Luck to you
Nov 14, 2007 | Compaq Presario Notebook
Microsoft LifeCam VX-3000 Web Camera Logo
51 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
