Question about Canopus ADVC100 (77610072100) Video Capture
No analog signals thru ADVC100
I m having canopus advc100,when i connect the power supply to it both analog in & digital in lights turn on simultaneously.actually one of them should be on at a time,i tried pressing input select but doesnt help.analog signals cannot be routed to the computer.
  • Anonymous Jan 05, 2009
    I have the exact same problem. I'm pretty sure what happened was I had it powered on and ended up restarting the computer and now it's fried. Canopus customer support just wrote me back with the bad news:
    "If all 3 lights are on, then the unit has failed. We no longer
    manufacture or repair ADVC 100's (they are almost 7 years old now). You
    would need to purchase the newer ADVC 110 as a replacement."
Canopus customer support just wrote me back with the bad news: "If all 3 lights are on, then the unit has failed. We no longer
Posted on Jan 05, 2009
Video keeps scrooling horizontal
Are you trying to copy copyrighted video?
Apr 27, 2010 | Canopus ADVC100 (77610072100) Video...
Can I use the Canopus Twin Pact 100 to transfer vider from digital video camera to computer? The firewire port on the camera is no longer working, so I need another way to transfer the video to the...
No, it isn't really the right tool for the job.
The Canopus is for converting analog video signals to digital (like capturing the video from your computer monitor as you move the mouse around).
You already have a digital video source (your digital video camera). So this box won't accept that as input.
If your video camera has other output ports, like component video (see below for a picture), then it might work. The Canopus will accept analog RCA for input.
Mar 12, 2008 | Cameras
My Canopus ADVC-110 has both input light on and I
The problem got no free response so I ordered a new unit.
Jan 02, 2010 | Canopus ADVC-110 (77010150100) Video...
Macbook pro does not find canopus acdv110
How did You connect Canopus? Canopus has 2 Firewire slots - on the back and on the front. If You connect FW cable to a front slot, then, Canopus will not work. Only with external power supply. I´m offering the next proceeding:
1. Connect ADVC with FW cable 6 to 4 to Your macbook via back FW slot. The ADVC lights will now on. On front panel by default light is on mode "digital". If the light don't work - it's a Canopus problem. If light is up and working, then next step.
2. Go to apple menu-about this mac - more info - firewire. You MUST see here Your Canopus a a device. If so, go to the next step.
3. Connect Your VCR to analog inputs, on the front panel of Canopus.
4. Run FCE. If it says "apple firewire device is missing" then is something wrong with Canopus. If not, proceed to next step.
5. On the top of the front panel of Canopus, press button. The light changes from digital to analogue.
6. Press apple+8, then capture settings. Set the firewire device as uncontrollable device. Make sure that in capture window is "vtr ok". Turn the VCR on
7. Press the play button on capture window. In the window appears the screen of Your VCR. Then press play on VCR and then "capture now" on capture panel. Voila! Must to work.
Aug 30, 2009 | Televison & Video
"no device control" blue screen on imovie with ADVC55 connected
Hi - The red light indicates the VHS is Macrovision copy protected, so the ADVC55 is refusing to import it.
There is a sort of "secret" workaround for this that most people who own the old Canopus products know, and which Canopus also knew, supported, and had posted on their forums (unfortunately deleted by the new owner who seems to be unclear on copyright law).
Remember, it is LEGAL to make ONE (but ONLY one) copy of any copyrighted material for your personal use for backup purposes. In other words, if you do this, you can record the movie into your computer and store it there, or burn it to a DVD (after which you must erase the copy on your computer), but that's all! You cannot make another copy for anyone else - not even yourself - without violating copyright law.
That said, here are the two procedures that usually work, easiest first:
1) When you first turn the Canopus on, hold the select button down for roughly twenty seconds. Now the system should ignore any copy protection until you turn the unit off.
2) (if 1 doesn't work:)
1. Put all dip switches OFF (unless you have a PAL system). 2. Hook up the firewire cable from the unit to the PC while ensuring that both units are OFF (this is what the instructions say to do, because you can cause a damaging power surge otherwise).
3. Turn on the power to the DVD player, PC and ADVC-100.
4. Set capture on your PC (your software) to Manual.
5. Start the DVD.
6. The ANALOG IN LCD of the unit will light, and if the DVD is Macrovision protected, the red STATUS light will stay on for about 18 seconds, turn off for about three seconds, and then repeat the process (or may remain red longer on some units).
7. Depress and HOLD the INPUT SELECT silver button. The DIGITAL IN LCD will light up temporarily then turn off. Keep this button depressed until the red STATUS light stays off completely (about 15 seconds).
8. Release the INPUT SELECT BUTTON and press it briefly one more time until the ANALOG IN button lights up.
9. Macrovision is now bypassed!
Again, once you turn the ADVC55 off (which you must - if it stays on for long periods it can overheat and malfunction), you'll have to go through the Macrovision bypass procedure again next time you turn it on.
Good luck, and I hope this works for you as it did for me with my Canopus!
Jul 09, 2009 | Canopus ADVC-55 Video Capture
Analog and Digital selections lit up, status light flashing
Although you are using another 5v cable, please make sure that the AMPS are correct. Look on the back of your Canopus and see if it lists the amps along with voltage. Too liitle or too much a,perage will cause malfunction.
Jun 23, 2009 | Canopus ADVC-110 A/D Converter...
Need adaptor for older Sony analog camcorder - CCD-TRV70 DC 6V
You need to get a Digital to Analogue converter such as the Canopus ADVC110 A/D Converter. (circa $225). There may be cheaper alternatives. (you might also be able to use a digital camcorder that has a built in Analogue to digital converter):
 Canopus 77010150100 ADVC110 Converter
The Canopus comes with a 6-pin firewire cable. Since your Dell Studio has a 4 pin Firewire (actually called iLink) you will also need a 6-pin to 4-pin cable or an adapter:
 Firewire 6-PIN To 4-PIN Cable
 Cables To Go - 27028 - Firewire 6-Pin Female 4-Pin Male Adapter
You hook your Sony up to the A/D converter with audio and video cables (usually supplied with your camcorder) and hook the converter to you Dell with a firewire cable. Then you capture the video using some video capture software. I don't know what comes with windows these days.
Jan 22, 2009 | Sony Handycam CCD-TRV308 Camcorder
Can the Canopus ADVC-110 be reset
May i suggest that if the Canopus is stuck and both lights are on it may well be faulty but try this first.
slowly insert the fire wire into the back of the Canopus slowly does it when one light comes on stop inserting the fire wire and press input select till the lighth moves to the other side in my experiance digital to anolog,this may take a fiew goes and seem primative but it has worked for me and then eventialy the canopus corrects its self if this has been helpful please put a pound in the charity box of your choice and email hayden@hayprofilms.com just to let me know good luck bye.
May 07, 2008 | Canopus ADVC-110 A/D Converter...
Unable to record sound with the ADVC100
S-Video cables carry only video. You still need to connect the red/white RCA plugs for audio.
Jan 13, 2008 | Canopus ADVC100 (77610072100) Video...
ADVC110
I'm guessing that you have it connected via a 6pin firewire on the ADVC100 to a 4pin firewire on your macpro. The device needs to be connected via 6pin to 6pin in order for the device to get power, otherwise you'll have to buy a AC adapter (which is not included). Otherwise it's a great device for DV conversion on multiple platforms!
Mar 23, 2007 | Canopus ADVC-110 (77010150100) Video...
Canopus ADVC100 (77610072100) Video Capture Logo
324 people viewed this question
Top Canopus Televison & Video Experts
Alun Cox
Troy Staley
Troy Staley
Paul Bade
Are you a Canopus Televison and Video Expert? Answer questions, earn points and help others
