Question about Denon AVR-2807 Receiver
Denon Receiver keeps changing channels
All of a sudden it started changing channels ... like from tv to video, video to whatever ... just keeps on jumping from one thing to the next. How to stop this?
  • 165 Answers
Hello my friend this is happening cause you have a push in button,disconnect from ac take a near look and push the reset button you must check your remote too saludos
Posted on Dec 12, 2008
Denon avr 2113ci signal not coming in from apple tv
If this is a video problem, try different video connections (i.e. HDMI, Component, Composite, S-Video) to isolate the problem
Dec 16, 2014 | Denon AVR2113CI 7.1-Channel 3D Home...
Denon AVR-786S 7.1 Channels Receiver
First set the DVD player To mono and then see.
Check if the DVD assigned to coaxial input in receiver menu?
Check if the Digital out activated in player menu?
There are quite a few ways to connect cable box, DVD, receiver and TV together. At a minimum---Connections between DVD and a/v receiver: For Audio, either digital coaxial, digital optical or simple RCA (CABLE ONE); If you did not use RCA you need to connect Video with either component or s-video (CABLE TWO). For connection between a/v receiver and TV: either component, s-video or RCA (CABLE THREE) You did not mention how your cable (or sattelite) box is connected. You could use same set-up as between DVD and a/v receiver for another one or two cables depending on set-up used.
Goodluck..
Feb 23, 2008 | Denon AVR-786S Receiver
All 4 hdmi ports stopped working on Denon receiver, how do I fix it
Have you checked to make sure it didn't restart your entire system? If not you'll have to double check everything is connected correctly, turn everything on, and change the channel on the TV back to whatever Composite video or HDMI setting it was plugged into...then make sure the Denon receiver is set to Cable
Aug 22, 2014 | Denon AVR-591P 5.1 Channel A/V Receiver
No Sound from Denon Receiver
Some tvs don't have a return channel for hdmi audio so you will have to go into the setup of the receiver and set it up to only use the internal amp
Dec 21, 2013 | Denon Audio Players & Recorders
RE: Denon AVR 3300 - I cannot get the system setup menu to display on Phillips P50PFP5332D tv screen? All connected components work and sound great, but I cannot see Denon's Setup menu on tv to a
I understand, it's something I've misunderstood on my denon avr-790 as well when connected to a samsung 8000 series led tv.
The answer isn't in the receiver's settings (you can be on whatever source you want on the receiver end when toggling the menu). You need to toggle through the tv's sources to find the menu (usually found on hdmi 1). I've spent towards an hour recently troubleshooting only to find that it was the tv's source that wasn't set properly and I was trying to change the receiver's settings instead of the tv's source.
Hope that helps!
Jan 16, 2012 | Denon AVR-485 Receiver
I have a Denon 1611 hooked up with XBOX, DVD, and CHARTER CABLE BOX to a SAMSUNG UN55C8000. For whatever reason I have no sound coming from my (TV) speakers and no sound at all when I switch to my game...
It would appear that your receiver, from pictures I looked at, has 4 HDMI in and 1 HDMI out. Looking at the specs of the tv, it has 4 HDMI in. I'm guessing that you have your receiver set up with speakers and sometimes you'd rather listen to tv speakers? I didn't download a manual however, usually to get sound from tv speakers you may have to turn off av's speakers or, there may be a way to bypass. If you could give me more info on hookup and what you want to do I could probably be of more assistance.
Mar 11, 2011 | Denon AVR1611 5 Channels Receiver
Denon avr-1804/884, speakers Bose vcs center, Bose acoustimass 5 series 3 speaker system, Bose 201 series 4. All speakers play in test mode, with tuner, dvd, phono, cassette. The left side speakers will...
You don't say how "TV audio" is entering the system.
My guess is you're using analog audio Out from the TV into an analog input on the Denon. One channel failing would probably be the Left Channel cable failing or not seated.
I always recommend bypassing the TV audio entirely if the programming comes from somewhere other than its own antenna, as TV audio electronics add nothing good to the process.
If you're using cable box, sat box, game, whatever, ITS audio is best sent directly to your Denon's specialized audio hardware - digitally, if possible, to preserve multichannel possibilities.
You could also run standard analog audio from the cable box to the TV analog Audio IN if you just want to watch news and weather on TV speakers without the Denon involved.
Jan 11, 2011 | Denon AVR-1804 Receiver
Denon avr-1907 sound from TV stopped working
Help with hooking PS3 to a Denon Receiver. It worked before, but I had to move everything to a different location and when I hooked it back up the PS3 has sound but no picture. I have it hooked directly to the receiver with and HDMI cable (the receiver is hooked up to our cable box which is directly hooked to the tv via HDMI cable).
Jan 03, 2009 | Denon AVR-1907 Receiver
Denon AVR1602
I know the avr 1602 well....What exactly do you mean "I have my TV cable service wired to the Denon".....Do you mean the actual co-ax cable ?....
The denon is only able to switch raw video and audio signals.
What do I mean by that ?....IF you are running your co-ax cable from your cable company directly into the back of the denon, it won't work. The Denon has an AM-FM tuner, but not a video tuner ( channels 1-121)....If this is what you are doing, then you want to run it to your samsung first ( as long as the samsung has a tuner so you can change channels ).
If the samsung operates like an old VCR, whereby you can plug the cable company co-ax cable into the back of it, and change channels with the samsung, then that is what you must do. You would then hook up the OUTPUTS of the samsing to the VCR or DVD inputs on the Denon receiver. ( use DVD inputs on the denon if the samsung has optical audio out, and use an optical cable as well for better sound ).
You would then use the Denon for the sound, and hook up your TV to the Monitor out jack on the back of the Denon.
The Denon is like a big switchbox. You plug your DVD, VCR, Satellite, video game, or what-have-you into the Denon. Then you use the denon to route the signal to your TV for the picture, and the denon takes care of the sound.
Hope this helps, and remember to always follow your owners manual.......Rob
Mar 13, 2008 | Denon AVR-1602 Receiver
Denon 1905/785 - lost color feeding tv
Your Denon 1905 might be setting it under HDMI for video source.You need to correct it by going to menu,as you browse through the setting,you should able to find video select or video output. It is on the manual.
Remember,you need to run a composite video cable from the video output behind your receiver to your TV video input for this step.
solutiondoct
Mar 09, 2008 | Denon AVR-2807 Receiver
Denon AVR-2807 Receiver Logo
118 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
