Kenmore laundry center wont spin model number 417.90862990
I replaced the timer about a year ago and today replaced a burned out lid switch. The agitator wont spin in either the spin cycle or wash mode and i nticed that the motor was getting hot. Just want to know what kind of troubleshooting I can do to verify that my motor is burnt out. When I had the cover out I also observed that the motor is not spinning.
    President:
  • 373 Answers
* Test the lid switch
* Inspect the motor coupler
* Inspect the drive belt (belt drive only)
* Inspect under the washer for soot (clutch)
* Test the motor
* Inspect the pulley
* Test the transmission
* Inspect the agitator
* Inspect the pump coupling
* Test the water level switch
For more information regarding this check out this link that describes more about washer troubleshooting...
http://acmehowto.com/howto/appliance/washer/diagwasher.php
Posted on Dec 12, 2008
How do you test to see if your transmission is good or bad?
Posted on Feb 23, 2010
My model GLET1041AS2 Frigidaire Laundry Center fills/agitates, but does not pump or spin. The timer would make a slight buzzing/timer sound when it hits the spin cycle, but nothing else.
The circuit board has a Cycle generator and sequencer that accepts commands when you manually do a setting. When the sequence enters the spin phase a block occurs and discontinues further action. It is not the timer, but the command center on the circuit board. Because the board has many functions, it is like a set of Christmas Tree lights in series, and when one bulb fails, so goes the set. You will no doubt need a new command board for that model.
Mar 12, 2014 | Frigidaire Genuine Washer Timer 134049600
KenmorenLaunry center not draining or advancing cycles
Hi David if the timer is not cycling the tub will not drain ,the washer will not complete cycles, second check the lock switch on the door. this can stop the timer and the tub from draining. when not cycling the timer is at fault , this could be two problems, 1st when everything stops check the door safety switch , 2nd listen for the timer, if it stops running. good luck ,geodaws
Dec 09, 2013 | Kenmore Washing Machines
My Kenmore washer drains after the rinse cycle but won't spin at the end of it's cycle. If I manually set it to the spin cycle, it spins just fine. Desperate!!! The lid switch was just replaced about
Possible there is problem with the timer controller unit. It seems that the stepper motor is not moving to the next cycle until you manually move it to the spin. You can use some contact cleaners on the switch and also carefully try to see if the timer moves within , replacement is a costly issue and must be debated
Nov 20, 2013 | Washing Machines
Kenmore 27 in. laundry center won't spin out
The lid may not be mechanically closing the switch even though the switch was replaced
Apr 11, 2013 | Washing Machines
Kenmore washer wont agitate
i would look at your lid switch this could be faulty
Feb 23, 2010 | Kenmore 22422 Top Load Washer
Kenmore 80 series washer wont spin
Sounds to me like you may have a lid switch bad. If you close the lid and don't hear that click then you can be sure that you have a bad lid switch. If it is bad your machine is thinking that your lid is up and so it won't do any washing or spinning. Replace the lid switch.
Apr 11, 2009 | Washing Machines
Kenmore 80 Series - machine won't rinse or spin
Manually move the timer to the SPIN mode and turn it on.
If nothing happens, replace the lid switch.
With a model number I could be more specific.
Feb 27, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Model 80 get stuck after agitate and will not spin out
I have seen this on the same model recently, try lifting the lid during the neutral drain and reclose, if it engages spin then. then most likely your timer is bad too. The timer after two minutes of "neutral drain" will stop the motor (same effect as lid sw) then restart after a pause with spin/drain. this pause shifts the transmission to its next cycle which is spin. I found burned contacts in timer. Your timer list price is over $100 but easy to replace
Nov 24, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Intermittent spin cycle on Kenmore 90 Series washer
You may try the speed selection switch.....Ive had problems with these.
Jan 23, 2008 | Washing Machines
Kenmore agitates doenst spin
blaker, check the lid switch, no spin, no drain, usually a broken lid switch...Catriver...post back.
Sep 15, 2006 | Kenmore 23012 Top Load Washer
Washing Machines Logo
517 people viewed this question
Top Washing Machines Experts
