Question about Dell Dimension E510 PC Desktop
Dell E510 Memory
One day last week when I turn on my computer(dell e510) start making a beep sound and nothing came on the monitor. I search dell site and found beep sequence 1 3 2 or light 3 4 or 1 is somthing wrong with memory. I bought another set of memory tried to start up is does the same beep again. If anyone have solution please e-mail me that you.
  • mathew cheriyan Mar 08, 2007
    I change battery but that did work. Then I unplug all power cables and took the motherbord out from the case and reinstall everything. Now it is working fine. I wonder what was problem? Is it motherbord?
  • Kaganader Dec 12, 2007
    I'm having the same problem with the same model.
    changed the CMOS battery nothing,
    check all wires they are still good,
    power from the power supply is reaching the motherboard hence the LED light is strong green.
    bios is up to date.
    only thing is I didn't do is change the power supply and jump the CLR CMOS pins because I don't know how.
I deal with this sort of thing alot with servers. Easiest thing to try first is reseat the memory.
Posted on Jun 03, 2008
  • 944 Answers
One thing worth trying is taking out the cmos battery (only do this if you are confident you know what you are doing on a motherboard). leave the battery out for at least a couple of minutes and then reinstall the battery (ideally with a new one). restart and you may find you have cured the problem and that your old memory was fine. If this doesn't appear to help (definitely replace the battery even if you think it is fairly new)and jump the CLR CMOS pins. (ask again if you need help on this). second to try is see if you can update the bios drivers from the dell site onto a disk on another machine - use as a boot disk and see what you get. after that i would suspect the power pack, there is no real way to test this without connecting it to another motherboard and seeing if it is fine. alternative would be to just replace it with an equivalent unit, they are not too costly. After this i would suspect major motherboard or bios damage, which may be fixable but is usually cheaper to replace the whole board if you have inserted the wrong type(frequency/size/combination) of memory sets into the board it can often cause this sort of trouble, and often a CMOS clr and reset can solve the problem Please let me know if you need talking through the process - (it is not too complicated, but you can cause damage if you do not know what you are doing) Hope this helps :)
Posted on Mar 08, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Mar 08, 2007
    Sounds like either the CMOS was confused and needed resetting or you had a bad connection between the motherboard and your graphics card - also possible is a bad contact on one of the power connectors.
    Glad it solved it
How do I fix a dimension E510 with a solid amber power light?
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 25, 2014 | Dell Dimension E510 PC Desktop
I have a Dell Dimension E510 and it makes different tone beeps during and after startup. The computer works ok, but the beeps are disruptive. Seems like there are many more beeps during processing steps,...
When you first switch on your computer it checks certain things to make sure everything is OK and sends out multiple Beeps if there is a problem this is call POST. If you are getting multiple beeps then there is a problem, depending what BIOS CHIP you have and how many beeps you are getting should indicate what is at fault. If windiws is starting ok then it will be a minor problem, the first thing I would check if i was you is the memory. If you have more the one stick of memory installed and one is faulty windows will still start but with the beeping error. Start the computer and goto the control panel and click on System and check what memory that is showing and compare with what should be installed. If its the same then the fault is somewhere else and you will have to give more infomation like what is the system bios and how many beeps.
Good luck.
May 29, 2011 | Dell Dimension E510 PC Desktop
My Dell E510 PC Desktop Does not turn on, the front light is green, but isn't blinking and a 3 and 4 show up. It also peeps a couple of times, but does not boot up.
Manual is here: http://support.dell.com/support/edocs/systems/dimE510/index.htm
Look under Diagnostic Lights. 3/4 is a memory issue. Unplug your PC and open it up. If you have more than one memory stick, remove 1 and then try rebooting the computer. If it still fails, try the other stick instead. You may need to replace both sticks or even just reseat them both.
Mar 08, 2010 | Dell Dimension E510 PC Desktop
Dell Dimension E510 - Keyboard compatibility
Hi, to find out if the “Keyboard is compatible with your system?” You can do the following: Shutdown the Computer, connect the Keyboard to your computer. Turn on the computer. If, the “Keyboard have a Power Button?”(Turn on) the keyboard. Go to, Control Panel; click on Device Manager. Click to open Keyboards, in the (Keyboard Properties) Click on Driver (Box), next click to Update Drivers! Click OK. Restart the computer. Check keyboards’ functionality. Thanks paul7of9
Jan 14, 2010 | Dell Dimension™ E510 PC Desktop
I have a Dell E510 that will not boot up. It has power and I get error codes 3 and 4. I have reseated the memory and replaced the memory to new memory and tested them one by one in the first slot. The...
Ok what you might try is get a new hard drive and install windows on there and see what happens. Also if you are able to before you try a new hard drive you should do a system restore and restore it back to the day that windows was installed.
Jun 18, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
My dell dimension E510
If the sound card is built in then go to Dell support site and download the drivers - if that doesn't work it is probable dead
replace it with a PCI card
Aug 28, 2008 | Dell Dimension E510 PC Desktop
Dell Dimension E510 Desktop
Also try to go to support.dell.com,click on drivers and downloads and enter the service tag of your system, then click on the audio driver.
Aug 23, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Dell E510 desktop
Hi Asif,
Did you install there something new on it? Maybe could help to push the F8 key after POST (just after the DELL logo disappeared and before Windows logo would appear) and choose to start with last configuration which worked. If this doesn't help then after F8 choose to start in Safe Mode and uninstall the failing application after you log into Windows.
May 30, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Monitor says no signal
cheak ram u can get power 400 watts highter atx style with 2 rails but might be bad video card or it defulted to other slot
Jan 25, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Dell Dimension E510 PC Desktop Logo
1,182 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
