Home | Nikon | D70s Digital Camera with 18-70mm Lens | My Flash stop wor...
Nikon D70s Digital Camera with 18-70mm Lens
Problem for Nikon D70s Digital Camera with 18-70mm Lens
My Flash stop working, do i need to replace it?
By Kim1 - usenet poster
Same Problem
Aug 28, 2008
-   I was at a wedding and my camera was working fine then the flash stopped and the rest of my pictures came out dark. flash hasn't worked in 2 weeks. what do i do?-   mrsrich1
Aug 07, 2008
-   Flash just stopped working - the rest of the camera is fine though. How frustrating!!!! -   Guest
Jul 23, 2008
-   same problem, the flasch stopt working, where or jhow can i replace it. -   Guest
Jun 05, 2008
-   My Flash stop working, do i need to replace it?-   Guest
May 24, 2008
-   My flash stopped working. I got it last Christmas. I made sure Flash is always enabled, but this didn't help.-   Guest
Best Solution
posted on Aug 25, 2007
Helpful)
tonycross
Rank: Apprentice
Rating: 83%, 11 votes
I just had the same problem with my D70
Just remove the 2 screws from the front of the popup flash
The rear plastic cover will the clip off.
Inside you will find a small switch on the right side of the flash unit when it pops up the switch should make, if it doesn't try shorting it with a small insulated item the try the camera in low light and see if if flashes.
To fix you need to remove the spring-screw from the other side then gently prise the bracket off, then just pull out the small white sleeve on the right hand side of the popup near the switch,
this sleeve moves in slightly and will not make the switch on the popup flash.
Gently put the flash bracket onto the camera, be very gentle as the wires are very thin. You will see the white plastic bearing has 2 small clips which need to be through the hole on the bracket the pin which activates the switch will then be in the correct position.
It's pretty obvious if you have a go.
Good luck and I hope this fixes your flash problem on D70
BTW I also have a F80 but this does not have the same mech on the internal flash unit
Was this helpful?
Yes
No
Solution #2
posted on Sep 08, 2007
Somewhat Helpful)
proj_man
Rank: Apprentice
Rating: 72%, 14 votes
proj_... indicated that his solution for
COOLPIX L4 Digital... Problem
is valid for all Nikon Digital...
You might have BSS or continuous photos turned on. This is Best Shot Selector, which lets you hold down the button to take up to 10 shots. It then selects the least blurred of them and saves it. Obviously since it fixed blurred shots, it is not intended for use with flash.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #3
posted on Aug 08, 2005
Somewhat Helpful)
Rachel007
Rank: Apprentice
Rating: 0%, 0 votes
1. Check that batteries are fresh.
2. Check that camera hasn't been set for no-flash mode.
3. Give the flash time to charge before pressing shutter.
Was this helpful?
Yes
No
Solution #4
posted on Jul 15, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
This particular camera sems to be a bit of a let down. I bought one and the flash stopped working on mine and apparently it is a common fault. Best solution is to buy a completely different make as Jenoptiks dont seem to be much good.
Solution #5
posted on Jul 02, 2007
Somewhat Helpful)
AzureSkies
Rank: Apprentice
Rating: 59%, 2 votes
Also make sure that the lens is facing forward or else the flash is disabled.
Was this helpful?
Yes
No
Solution #6
posted on Apr 07, 2008
Helpful)
Starrchild
Rank: Apprentice
Rating: 88%, 2 votes
I have had it happen twice.
The first time I had it repaired which cost £80.
Now I am not sure... I may have to get another camera if it costs that much to fix.
If there is a replacement part I'd love to know.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #7
posted on Nov 03, 2007
Somewhat Helpful)
ameesh
Rank: Master
Rating: 66%, 20 votes
try keeping your hand in front of the lense maybe the camera mode would be automatic so when u click photos in a bright the camera would automatically turn off the flash for conforming try clicking a photo in an extremely dark place i hope your flash will work there
Was this helpful?
Yes
No
Solution #8
posted on Mar 25, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had this problem and found out that the flash worked fine, but you cannot have it in burst mode.  It has to be single shot and it will work.  I missed so many snaps for birthdays and holidays due to this problem, but now I know.  They should put that in the manual!!
Solution #9
posted on Dec 21, 2007
Not Rated)
azhelkov
Rank: Apprentice
Rating: 0%, 0 votes
Use solution #2, it worked for me.
Comments:
Dec 21, 2007
- I meant tonycross solution. I did not know their numbering changing, it is #1 now.
Was this helpful?
Yes
No
Popular Solutions for Nikon D70s Digital Camera with
Questions and Unsolved Problems for Nikon D70s Digital Camera with
Do you recommend Nikon D70s Digital Camera with 18-70mm Lens?
Answer
Answer
CHA display were the counter numbers are
Answer
after i take a photo a " job nr" is flashing on the lcd display and it looks like it takes... (More)
Answer
my nikon d70s will not turn off, when i switch it off it remains on, it still functions as if it's... (More)
30 Other Users Have The Same Problem - Continued
Comment by r273, posted on May 14, 2008
Mine flashes when it wants to. Sometimes it does not flash at all. Other times it flashes before or after shutter has clicked making the picture dark. Sometimes after several pictures it will work. Sometimes it flashes very bright and then makes a pop noise. Sometimes it seems to flash twice. Setting the flash mode does nothing. Camera was NOT dropped or abused.
Comment by muletrader, posted on May 04, 2008
My camera is several months old and has not been used that much, yet the flash has stopped working. I can find nothing about it in the manual. Very frustrating. Any suggestions?
Comment by federicoced, posted on May 02, 2008
I have the same issue.. The flash was working one night out then outta nowhere it stopped working the same night and i could not get it to work..
Also could never get the red light to work when taking pictures in low light..
Comment by CAMOMOM, posted on Mar 27, 2008
IT DOESN'T FLASH AND THE PICS ARE DARK
Comment by LinzyBOBenzy, posted on Mar 23, 2008
I just got this camera as an early Birthday Present, and the flash was working fine for a while and then it just stopped working. I replaced the batteries and then I check the manual and there is nothing in there. I have been letting it charge before I take pictures but the flash still wont work...
Comment by JENNFER, posted on Mar 21, 2008
JUST BOUGHT THE CAMERA TODAY 3-20-08 MY FLASH HAS NEVER WORKED WHAT SHOULD I DO?
Comment by Kelli McM, posted on Mar 19, 2008
My fash isn't working!?
Comment by syxx, posted on Mar 04, 2008
my flash wont work i cant change it to flash mode
Comment by emary, posted on Feb 22, 2008
My Digital Pentax *ist DL's flash stopped working. One second it was working the the next nothing. Several camera shops have suggested getting it fixed. What is the chance it is the light bulb? Can I change it myself? What happened. Camera was only a year+ old.
Comment by CharlieDV, posted on Jan 08, 2008
I received a new Bushnell Model 119800 trail camera as a gift. It takes pictures in the daylight but no pictures in the dark. There is no flash and I don't see a way to turn the flash ON/OFF or to replace a "bulb". The instructions barely mention the "Incandescent Flash". Any ideas?
Comment by Guest, posted on Jan 08, 2008
I obtained a new Bushnell Model 119800 Trail Camera as a gift. It takes pictures in daylight but no pictures in the dark. There is no flash and there is no apparent way to turn the flash on/off or to replace a "bulb". Any idea of what the problem is?
cdv@outdrs.net
Comment by sueter, posted on Dec 28, 2007
concord 3045 how do i take it of no flash so it does flash also can i inlock a protected photos done in error i wish to clear my card and it says it is protected and the lock is showing in the right hand top corner cant find how to unlock it in the hand book
sue from exeter
Comment by Duchess53566, posted on Dec 25, 2007
I have a Sony DSC-H2 whose warrenty was up in September I believe, In October the flash quit. I have tried all the settings, fresh batteries everything in book and that I can find on line. Sony wants $180.00 to look at the camera, I think that is very wrong. The red tracking light comes on, but no flash.
Comment by Guest, posted on Dec 25, 2007
how can i turn flash on?
Comment by azhelkov, posted on Dec 21, 2007
Solution #1 worked for me. It's a bit scary to mess with tiny electronics and I was electrocuted couple of times even I removed the battery during repair. It's still a mystery to me how white plastic bearing with two clips for holding it in place got moved so far inside. It is definitely a design flaw. Anyway, so far so good. Thank you tonycross.
Comment by jonverdacs, posted on Dec 10, 2007
yes the same problem with my camera, the flash stop working..what should i do?
Comment by phil_k, posted on Dec 09, 2007
Same as others have reported. No flash in any mode. Flash recharge lite goes thru cycle and comes up green. Everything else in camera seems to work fine. Can the flash be replaced without sending the camera back to the repair shop?
Comment by Guest, posted on Dec 08, 2007
flash does not work
Comment by tony mac, posted on Dec 06, 2007
the flash light is on but wont flash, tried all settings nothing works
Comment by glideride, posted on Dec 02, 2007
same thing flash just stoped working
Comment by mollykaye, posted on Nov 28, 2007
My flash has just completely quit working. I have tried all shutter settings and still nothing. I have had this camera for almost 3 years, is it possible that the flash just needs to be replaced?
Comment by magkeep2, posted on Nov 21, 2007
my flash just stopped working. the only way I can take an indoor picture is to put it on the candlelight mode and sometimes they turn out. HELP,
Comment by Guest, posted on Nov 10, 2007
yes this is my problem
Comment by moosecreek, posted on Nov 05, 2007
flash doesn't seem to be working, though the charging light is working. It is not set on continuous or BSS. And flash is set to auto/flash.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Nikon D70s Digital Camera with...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
