Question about Gateway GT4010 (RBGT4010) PC Desktop
My pc will power on but not go into the bios to start the bootup
When I push the power button, the hard drive light will come on for about 4 sec. and then blink out and the machine will not enter into the bios to start the boot up process. I checked the power supply and it is good.
  • Gary Luis
    Gary Luis May 11, 2010
    Try unplugging the hard drive and see if you can enter the bios. If you can, it could be your hard drive, the controller, or the cable. Not all cables are notched. Make sure the side with the stripe is facing the power connector of the hard drive and that the other end of the stripe is facing pin1 most boards are labeled with a "1" and some just show a highlight.
  • 135 Answers
The above assumes IDE drives...
POST ( Power On Self Test ) will take place even with a faulty drive.. it will (should) warn that either no drives detected or drive is faulty.
Rather unplug all deviced not needed and leave only screen and keyboard.
Inside the machine unplug everything except you hard drive, unpleg DVD,CD,Stiffy drives.
Also if you have an onboard graphics on your motherboard then remove the grpahics card you have as well.
Also remove all but 1 of the RAM modules.
If the PC boots now gr8.. you may just have had a bad connection. Now reinsert the RAM modules you have removed. Then start the PC again.
If your PC doesnt boot you may have a faulty/damaged Power supply, motherboard or CPU
Keep plugging back all the components one by one untill they either all are back in and everything works ( bad connec5ion the cause then) or until you get to a point where you attach/plug something in and it doesnt boot...that component is your culprit. And remember it can be anything, from RAM to your mouse..
Posted on Dec 12, 2008
Boot sequence
Power off the machine. Pres the power button and immediately start tapping F2 until the machine goes into the BIOS menu.
Apr 26, 2014 | HP ENVY 700-215xt Desktop with Windows 7...
Push power button, cd drive starts as normal but nothing else. ac light, power light, batt light on. no hard drive light, no monitor
this is a very common problem.
intercept all of cables of your PC case and even power cable of your monitor.
evolve battery of bios then wait for 20 minutes then connect all of cables and try turning on your pc:
1- with battrey of bios
2- without battery of bios
it should work.
(this works cause the motherboard reset it's bios and start correctly again).
Jan 09, 2011 | Computers & Internet
Computer freezes after bios screen on every restart.
One thing you could check is what order your computer is booting from. CD drive hard drive then other. Should be hard drive first. Go into the bios to do that. If you hold the power button down for 5 to 10 seconds the machine should physically shut down rather than unplugg. The unplug thing sounds like its in the power settings. But I've never heard of power settings being connected to bootup except for a password. Anyway a wild guess is check the bios bootup order.
Dec 31, 2009 | Toshiba Satellite® A215-S4807 PC Notebook
Loaded two patches from HP. One to deal with a printer timeout issue and second to ???Screen went to geo pattern. Forced shutdown. Now tries to reboot, blue lights flash go out and flash again every 3 secs...
Remove the battery and disconnect from power source.
Disconnect any USB or external devices.
Remove the hard drive and memory. Disconnect the CMOS battery in the memory compartment.
Flip unit over and hold power button for 30 seconds.
Re-install memory and hard drive.
re-connect your CMOS battery.
Power up unit without battery installed.
Boot into safe mode.
Go to a command prompt.( start, programs . Acc. , dos prompt or command prompt.)
and type chkdsk /f
You will get a message that says can't run know but would you like to run a next bootup ? Say yes.and and type exit.
Next, reboot unit.
Hope this works for you.
Oct 05, 2009 | HP Pavilion dv9700t Notebook PC
Will not turn on
You have a bios falier,you can buy a new computer or just call the company who manufactured it to give you a new motherboard
Sep 21, 2009 | Compaq Presario CQ50-215NR Notebook
I have a Gateway GT4010. When I push the power button, the hard drive light will come on for about 4 sec. and then blink out and the machine will not enter into the bios to start the boot up process. I...
try taking the side off and near your checksum battery (looks like a coin) there should be 3 peices of metal sticking up with a peice of plastic over two of them take the plastic off and change it to the other side this will reset your checksum then put it back and reboot
Dec 12, 2008 | Gateway GT4010 (RBGT4010) PC Desktop
Dell e510 won't make it to post
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
If this has worked you have proven that it's not the power supply (it turned on). If you purchased a non dell power supply, you might try this with the original one installed.
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Now, close case, plug in all usb/monitor/internet/etc. Power up computer. You'll get an internal floppy drive error. Push F2 (maybe F1) to get into the BIOS settings and go to "drives" and turn off the internal floppy. Save and exit. The computer should boot properly now.
This seems to be a big problem with the e510, my theory is that this one small battery is the root of most of these failures (as these computers usually fail after 1-2 years), not the power supply or the motherboard (heck, when you replace the motherboard it comes with a new one of these batteries...a several hundred dollar piece of hardware, with a $5 battery that will actually fix it).
Nov 09, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
If I press POWER all the lights are ON only for 2 secs and then OFF again
I would remove all attached items. memories, hard drive, battery.
unlpug the AC. push and hold the pwer button for 20 sec. (discharge the PC).
plug in the AC and turm it on. (BIOS) only. if that is good, then install other devices.
Oct 29, 2008 | Computers & Internet
My laptop will not boot up.
Try to put your harddrive, check on the screen if it can detect the harddrive. If it says there that ntldr is missing or if it is looking for an operating system try to install a new operating system. It like reformatting your PC.
Apr 12, 2008 | Toshiba Satellite A135-S2266 Notebook
Power ON/ nothing on screen-
enter the bios setup, if you can boot the computer/laptop. Usually F2 on bootup, it will say entering Setup.
Then scroll through the pages to see if your hard-drive is recognised by the system.
Mike @ Compurepair.
Feb 24, 2008 | Acer Aspire 5100-5022 Notebook
Gateway GT4010 (RBGT4010) PC Desktop Logo
93 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
