Question about HP Photosmart C6280 Printer
Cannot print with new ink cartridge
Cannot print. Instructs me to replace empty ink cartridge which I did. Message won't go away. Won't align. Won't clean printheads. Won't print diagnostic page. Won't print test page. Estimated Ink Levels indicate that the new cartridge I just put in is empty. Does this sound like a defective ink cartridge?
  • HP Master
  • 1,113 Answers
Sounds like a non genuine, aftermarket ink that is dodgy.
if not ensure it is indicating the same colour that you replaced
Posted on Dec 12, 2008
Error message "to print in color, install the following cartridges:" continually comes up after installing new cartridge.
on ours the cartridges click twice to be fully seated..there are 4 cartridges in this one.. if one is not all the way down, it will error..in extreme cases if all the cartridges are in place..unplug the unit and reboot it..
Jan 19, 2014 | HP Photosmart C6180 All-In-One InkJet...
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
Disable the empty cartridge indicator
You won't be able to disable the notification. Also, you won't be able to print if one of the cartridges is out of ink. The printer needs all of the cartridges with sufficient ink levels to continue printing - that's to prevent damaging the printhead.
Nov 13, 2012 | Lexmark 90T9005 - Platinum Pro905 Wireless...
My Pinnacle Pro 901 is set to print using black ink only but it keeps telling me I need to replace color cartridges and won't print.
You won't be able to print if one of the cartridges is out of ink. The printer needs all cartridges with sufficient ink levels to prevent damaging the printhead.
Every time a cartridge is replaced, all colors are primed simultaneously thus the need for all cartridges to have ink.
Oct 25, 2012 | Lexmark Pinnacle Pro 901 All-In-One Inkjet...
I have enough black ink to print a few pages in black, but the printer won't print. What do I do?
I had a Epson printer that would not print or even allow me to use the scanner because the colored ink was out. Even though I had full black ink, it still would not let me print until i replaced the colored ink.
Sep 25, 2012 | Lexmark 90T6005 Prospect Pro205 All-in-One...
I installed new b&w & color cartridges and the
in your printer try to press on the restart button and hold it for about 8 to 10 seconds. by the way the ink cartridges that you installed are the genuine ink cartridges, if not then its gonna be normal that it won't detect as new.
Jul 11, 2011 | Dell Office Equipment & Supplies
Hp 6150 won't print clearly --new cartridges are in
Clean the print head if you suspect that the nozzles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
Hope this initial info/idea helps.
May 01, 2009 | HP Photosmart C6180 All-In-One InkJet...
Replaced color ink cartridges
Do a print head alignment. This will tell the printer there's a new cartridge.
Mar 19, 2008 | Brother MFC 210C All-In-One InkJet Printer
HP Photosmart C6280 Printer Logo
453 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
