Question about Gaggenau VL330-707 Kitchen Hood
Hi I have two old (10yrs or more?) Gaggenau downdraft benchtop exhaust systems in perfect working order (70W) VLT 021-107 and was wondering how much they were worth? They are very greasy, but very quiet, and appear to be working beautifully.
Whirlpool SC8720EDB cooktop stove independent vent switch is not starting downdraft exhaust fan, but the exhaust fan works fine when left side burners were turned on
Can you get to the switch terminals and try jumping them out with a piece of insulated wire? That would tell you if the switch is defective (my suspicion). Please be careful not to touch any live terminals - only the wire insulation you use for the jumper.
Aug 02, 2017 | Whirlpool Cooktops
KitchenAid Retractable Exhaust Fan problem when rising. When button is pushed, unit rises up about an inch. Requires 10 or more presses to extend fully. Otherwise fan and retraction is normal.
Kitchen Ventilation ' Kitchen Hoods and Fans ' KitchenAid
www.kitchenaid.com/major-appliances/hoods-and-vents/
KitchenAidShop and find how our hoods and ventilation systems clear the air in your ...Retractable Downdraft Design ... Telescopic Downdraft System in Stainless Steel.
30" Retractable Downdraft System, 600 CFM (KXD4630YSS ...
www.kitchenaid.com/shop/-[KXD4630YSS].../KXD4630YSS...
KitchenAidLearn about features and specifications for the KitchenAid 30" Retractable ... This 30-inch retractable downdraft vent rises 14 inches to help filter steam from ... 14" Rise. Enhances overall capture above the cooktop for more effective ... Makes it easy to select and adjust fan speed depending on your ventilation requirements.
KitchenAid® 36" Retractable Downdraft System, 600-1200 ...
Jan 10, 2016 | KitchenAid Dishwashers
Large oven doesn't heat up. Heating element gone??
Hi, In a word yes. As for who you can contact, I'd suggest only an authorized b/s/h (bosch/thermador/gaggenau) service provider. I used to be one for over 10yrs. but now work exclusively for sears...I'm not sure if I made a good choice or not yet, lol ! I digress. It is quite possibly not even the element as the gaggenau have cut-outs (they are actual thermal fuses that cannot be reset, they must be replaced) built into the bake circuit that can open often times. This of course unless you're certain the bake element is defective. Check your local directory under appliance service or a vendor who sells that line may be well equiped to direct you for quality service in someone they trust and are proficient. Hope that helps, good luck. macmarkus :)
Nov 10, 2009 | Gaggenau EB294/295 Electric Double Oven
Gaggenau VL 431 downdraft problems
Find the limit switch....cam not touching...
Oct 16, 2009 | Kitchen Ranges
Installing JED8230ADB Cooktop Grill with down-draft exhaust
I can't imagine directing the downdraft vent back up to a traditional hood type system. Why bother, just don't use the downdraft or get a cooktop without a down draft and save money.
In granite, yes for any cooktop as long as someone can cut the correct size hole. Cooktops must be installed so the top is just about flush with the countertop. They all come with a template for cutting the right size hole in the countertop.
Feb 24, 2009 | Jenn-Air JED8430 Electric Cooktop
Downdraft from exhaust fan
you definalty should feels air moving, providing hte unit is ON. when not in use there should be mo draft( minimal at best) if there is still a draft when unit is off, i would check where it exhausts outside, there should be flap tha closes when not inuse
Dec 21, 2008 | Gaggenau 36 in. CI491610 Electric Cooktop
Single oven door latch is broken
hi we sell gaggenau parts but we are in the uk sales@gwhitedist.co.uk
May 04, 2008 | Gaggenau EB 270/271 Electric Single Oven
Exhaust fan not starting
Hi
I have all the diagrams for that model and will gladly send them to you all for free via email. Remenber that the fan will always get gresse and have to be clean, also keep the filter clean.
Let me know were to send the diagrams...Glad to Help!!
Eddie Rentas
Tupper Lake NY
Apr 03, 2008 | Jenn-Air JED8430 Electric Cooktop
Gaggenau VL330-707 Kitchen Hood Logo
73 people viewed this question
Top Gaggenau Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Gaggenau Kitchen Range Expert? Answer questions, earn points and help others
