Question about Casio Exilim EX-Z750 Digital Camera
I forgot to put in SD card when I took pictures. I don't have the USB cable. I am urgently in need to transfer the pictures in the camera memory to the SD card. How do I do that?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
Follow the instructions on page 181 of this manual.
Posted on Jan 15, 2013
SOURCE: Camera Wont turn On: Is it stuck in USB mode? How do i fix it?
I was able to get past this problem by removing and reinserting the battery. This caused, in effect, a hard reset of the camera, which let me power it up fresh and take pictures again. Of course, it's not exactly reassuring that the problem arose in the first place,
Posted on Dec 13, 2007
  • 150 Answers
SOURCE: SD memory cards
Remove the card, slide the lock switch back and forth
several times to clear any dust off the contacts. Unlock
the card, then try it again.
Can the camera read the card? Is there anything on it?
Can the camera re-format/erase it?
Can you plug the memory card into a laptop, either directly,
or by using an adapter for the PCMCIA slot, and test it?
On my laptop, the card mounts as if it were a hard-drive,
with a drive letter. I can then browse through it, using
Windows explorer.
Once (if) the card is detected by the PC, open up MyComputer,
and click on:
This should show you additional columns with hard-drive
1) Check to see how big the memory card is (or detects)
How much room is left ?!
2) How is it formatted: FAT-16, FAT-32, NTFS
3) If the card is NTFS (not likely) make sure you
set the root security settings:
Righ click on the SD memory drive letter:
---> Properties ----> Security ----> Add ---> Everyone
Then set the EVERYONE's access level to FULL CONTROL
If you get an error message, stating that you are not
authorized to view or change the security settings for
this device, go into advanced security settings, and
take ownership of the device. Then exit and try again.
(You need to have an administrator priv's account to do this)
4) Try to browse the memory card, do you see any files ?
5) Try to copy them to your computer ?
6) Was the memory card full ? --> clear it, delete files
7) Can you reformat the memory card ?
Right click ---> format ---> accept any default settings
8) On you icon tray bar, look for a green arrow icon:
Click safely remove drive....
Wait for Windows to properly finalize and the drive
(memory module) and then remove it from the PC
9) If you do not own a laptop, take the card back to the store,
where you bought it, and ask them to try to recover any
pictures or files that may be on it, and then clear and
reformat it.
10) At this point, if the card will not function, it is time to
purchase another one.
11) Flash memory cards will fail after a limited number of
read/write cycles, due to internal degradation
with use. Unlike most other electronics, these chips have
a finite life (erase/write) cycles.
12) Don't overlook an "lock" or protection settings implemented
by the camera, to protect you from you :)
The camera could be simply telling you that there are
forgotten pictures on this stick and you cannot
over-write them unless you unlock the card first.
Password protected?
Encrypted ?
Good luck.
Please rate my answers
Posted on Jul 01, 2008
SOURCE: camera says card locked
1) Try to unlock it by the lock/unlock switch on the side of the memory card.
2) If step 1 does not work replace memory card with new card.
3) If step 1 & 2 do not work the problem is internal (inside the camera). Go to to get a quote for repair. Cost will be anywhere from $39-115 to fix it (if not under warranty). You could even ask if this is a defective camera (lemon) they might even fix it for free? I've seen this issue with the Casio a lot.
Posted on Dec 17, 2008
  • 373 Answers
SOURCE: Casio Exilim Z80 - 8.1 mega pixels
check with best buy and see if they can match one, otherwise check on web site
Posted on Jan 29, 2009
  • 415 Answers
SOURCE: transfer pictures from camera to storage card
Follow the link to
and input your model to veiw the manual.
That should explain how to transfer the pics to the card.
Posted on Feb 18, 2009
Please Help
hmmm you should try the followings:
First insert your SD card and try to make a copy of your pics from camera memory to your SD card. And then use this SD card to your computer.
Or Using Camera manufacturer and model no. search some driver and software for you so that you can transfer the pics to computer.
if still not fix, let me know your manufacturer and model no.
Mar 23, 2008 | Samsung Digimax S630 Digital Camera
Can i transfer the internal memory to an sd card
Put the card in and turn the camera on. Press the MENU button. Select the Setup menu (wrench icon). Select "Copy".
Full details are in the "Copy: Copying Between Memory Card and Internal Memory" section of the manual (page 112 in this edition).
Jan 09, 2012 | Nikon Coolpix L110 Digital Camera
I have a DMC-TZ 10. I have photos in the built-in memory that I want to transfer to my computer. I can't find my USB cable so I was going to copy onto the SD card and on with a card reader. The problem...
Go to the "Menu", then in the green arrow (pointing right) go down to "copy" and then make sure the "IN-->SD is highlighted, and hit the menu again. It'll come up saying "Copy pictures from Built-in Memory to Memory Card? Yes/No...highlight "yes" by hitting the up arrow on the side (above the "menu" button which is in the center, hit the one above the round button there), and it'll say "Please wait, with an hourglass turning as it copies the pics to the card. Then it'll say "pictures copied" and return you to the main listing of pictures. Hope that helps
Aug 05, 2011 | Panasonic Lumix DMC-TZ1 Digital Camera
Cant put pics onto my memory card for my camera help?
You can't transfer pictures from internal memory to a memory card, sorry. You need a USB cable to connect the camera to your computer then you can transfer the pictures to the computer.
Hope this helps.
Jul 21, 2011 | Fuji Cameras
I forgot to put the memory card in, and I took some pictures I would like to upload them to my computer. How can I transfer them to the memory card? Or is there another way I can download them to my...
does your camera have any internal memory ?
if no ? there's no chance of getting those pictures back
if camera has internal memory..just connect your camera to PC using usb cable
May 05, 2011 | Panasonic Lumix DMC F3 Digital Camera
Picture from camera memory to memory card
Page 34 says if you put the SD card in you can put them on the card.Hope this is what you were looking for?
Jan 05, 2010 | Nikon COOLPIX L12 Digital Camera
Transfer from camera memory
there might not be a way of transferring picture within the camera. However the SD card _should_ have resolved the memory full issue. Plug the camera into a computer with its USB cable. Transfer the pictures to the computer and delete them off the internal memory. Assure that your SD memory card is functional by trying it in another camera or in the slot on a computer.
Nov 30, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
My chip fell out, I took some pictures they are saved in the camera how can I transfer them to the chip?
If you're calling the SD memory card a chip, then you need to transfer the images with a USB cable to your computer. Once that's done put the memory card back in the camera and all subsequent photos will record on the card.
Nov 03, 2009 | Nikon COOLPIX S60 Digital Camera
Transfering problem
Your camera has no internal memory so please buy a card reader and transfer your images into your pc and your next memory card
Oct 15, 2007 | Samsung Digimax L60 Digital Camera
Casio Exilim EX-Z750 Digital Camera Logo
46 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
