Need to clean under-side of scanner glass plate - How?
The underside of my scanner glass plate has developed a film on it that is affecting the quality of any scanned photos. How can I remove the glass so I can clean it? The scanner seems to be molded tight around it.
  • kasieguard_a Dec 16, 2008
    Thank you for your suggestion, dan231. I unplugged and flipped it over. There are no screws to be seen. Perhaps they are under the rubber feet??
    I did finally find a website for Medion (scanner is a Medion 90070) and sent them an email... now waiting for their response.
    As I'm trying to scan 50+ years of photos for my family, I'm hoping to get this resolved. Thanks again for replying.
    Sergeant:
  • 236 Answers
You may need to take the entire cover off.
If you have the manual, there might be some info about doing that in there.
If there are no screws on the top, I would flip it over and check for screws on the bottom. If you post your make and model, I might be able to find specific info for you.
Posted on Dec 16, 2008
How do you clean under the glass of the Canoscan 4200f
I have a Canon 4200F, and you can refer to this one I have already answered:
http://www.fixya.com/support/t19119519-clean_inside_glass
Have a good day
GB
Oct 09, 2012 | Canon CanoScan 4200F Flatbed Scanner
Sharp IR 2016 platine glass dirty
The cover plate is above the glass white surface of the scanner. If this is the same dirty stains will come out on copies.
The glass must be clean.
By feeding the original documents through the ADF, the scanner lamp is no longer the path to scan, the ADF is responsible for passing the original document over the scanner, while it remains still placed on the side under a thin glass is to a large glass side. This also must be clean, otherwise you will be black lines on each point or spot on the glass.
Good luck ...
Feb 28, 2012 | Office Equipment & Supplies
How to clean the underside of the scanner glass on an HP4400C flatbed scanner.
This is acutally easier than it looks. I just had the same problem with a cloudy film starting to form underneath the glass on my older HP 4400C scanner.
First completely remove the hinged top lid by lifting straight up on both long ends of the lid - notice the 2 hinges on the back end of the lid will come straight up and out of the body of the scanner, still attached to the lid.
Next look down inside the 2 hinge holes (on the main body of the scanner where the lid hinges just came out of) and you will see a screw in each hole. Remove both screws using a phillips screwdriver. This will allow the rear end of the scanner to come apart enough so you can now lift it up a few inches to separate it and get your hand inside there to clean the underside of the glass with a soft cloth - BUT JUST REMEMBER THE FRONT END OF THE SCANNER WILL STILL BE CONNECTED, so don't pull it too far apart because it could snap and break something that is still holding the front end together. (I could not figure out how to separate the front end piece, and then I realized I didn't have to).
So on the rear end of the scanner, now carefully pull the light upper colored plastic apart from the lower dark plastic just enough so you can get your hand inside the compartment and use a soft cloth to clean the underside of the glass. I just used a small piece of an old cotton t-shirt with a couple little dabs of water on it and then just kept rubbing the dirty areas on the underside of the glass over and over until all the dust film/streaks disappeared and the glass was once again clean and all clear.
Then gently lower the glass back down and line up the plastic pieces together on the rear end and put the 2 screws back in the hinge holes, and then reinsert the hinges in their slots and lower the lid back on top of the scanner glass and it is ready to go again !!
Hope this works for you like it did for me.
Nov 19, 2010 | HP Scanjet 4400c Flatbed Scanner
LHow to clean under side of glass plater
note where the dirt is located,unplug all wires from back, remove top hinged cover, undo 2 screws at the top, remove cover plate by gently tipping toward top, slide glass with plastic sides up and out, clean with approved cleaner, reverse to reinstall glass (plug in power cord prior to replacing top cover plate to check for any missed fingerprints or dirt on underside of glass), once your happy with cleaning complete the reassembally.
Oct 06, 2010 | Canon CanoScan D1230U Flatbed Scanner
Scanner glass clean
Cleaning the glass is rather simple. Take the 2 screws under the cover out. Now gently lift the top part of the scanner (some force may be needed). Then the scanner is in 2 parts and the glass can be cleaned inside and outside with a wet wipe glass cleaning pad. Dry the glass with a towel and inspect the glass with a lamp, that no cleanser remains are left. Now install the scanner in reverse order.
Jun 21, 2009 | Epson Perfection V100 Flatbed Scanner
Cleaning underside glas plate
Hi, I had to dismantle my HPG55 to clean the glass and found the instructions at the HP website. The link to the site is below. The instructions are very clear, and there are also photos to help you along the way. I hope this helps.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=de&dlc=de&cc=de&docname=c00498704#N216
Sincerely,
Tosty
Feb 23, 2009 | HP OfficeJet G55 All-In-One InkJet Printer
Fog build up on underside of glass plate.
I made contact with cannon and received this reply. I was satisfied with the answer but the question still remained on how to remove the glass should i wish to do so. Also after there answer... would there then be a problem if i did clean the reverse side. Their answer was initialy this...
The foggy haze on the glass is actually an anti-glare treatment that has
been intentionally applied to the underside of the scanner glass.  This
treatment lessens the glare from the lamp under the glass and provides
better image quality.  This haze may not appear uniform because of the
shape of the scanner base and the components under the glass. However,
the anti-glare treatment has been uniformly applied and the haze is as
expected.  The treatment should not affect the scan quality or output of
the 8600F.
Jan 04, 2009 | Canon CanoScan 8600F Flatbed Scanner
Streaks when scanning and the glass needs cleaned how do I get in to clean the glass on the underside
Here's a link to the instructions for opening the top of the scanner:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00553775&dlc=en&product=90809
BG
Oct 04, 2008 | HP PSC 2175 All-In-One InkJet Printer
Lexmark x83 glass clean
  1. Dampen a clean lint-free cloth.
  2. Gently wipe the glass scanner bed.
These steps were taken from the Lexmark X83 User's Guide. You can find the English version here: http://www.lexmark.com/publications/pdfs/x83/engui.pdf
Sep 17, 2008 | Lexmark X83 All-In-One InkJet Printer
Dirty platen
My suggested solution was to become an Elite Expert and to consult myself.
Feb 13, 2008 | Epson Perfection 1670 Flatbed Scanner
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
