Question about Sony KP-53S65 53" Rear Projection Television
Multiple problems, hoping for one solution
Dear Professionals, Several symptoms and hoping that they have a common cure? 1) When TV is turned on, I have a fuzzy picture, as I change channel, the screen turns blue with diagonal lite blue lines and very faint images of recieved channel in background. Turning the TV off and back on clears the blue screen and returns the picture, but only until I attempt to change channel. 2) The viewable TV picture looks blurry with minor light fluctuations and a blue hue outlined around all dark colors. 3) As I attempted to align colors, the red aligned fine, however, the blue is so blurry that I cannot exactly tell where it needs to be set. A things I noticed: as I covered the all but the red crt, no light fluctuation and picture seemed fairly ledgable. as I covered all but the blue crt, the picture was very blurry (non-ledgable), but no light fluctuation was observed. as I covered all but the green crt, I had light flucuations on the channel I was watching. It there are any test or if there is more information I can provide please let me know. As this TV is 10 years old, I do not want to dump too much money into it and any help you can provide would be greatly appreciated. Although I am a novice to TV repair, my electronics knowledge is above average. Regards, monty
  • monty mooring Mar 08, 2007
    Nog,
    thanks, for your thoughts. I gave it the ole school boy try, but no suerte.
    thanks again
  • 944 Answers
Sounds like it is probably worth trying to degauss check this excellent site; http://woil.ws/fixmonitor/ for details of how to try this on the cheap - it works If it doesnt solve your problem, the fact that you are getting different quality from different crt s suggests that they could be the root cause - see if you can get the part number, and get a price you may find it is cheap enough to be worth trying - check also the power supply - poor voltage output can sometimes cause these type of symptoms. Hope this helps, if not post again - some of the other guys know tvs much better than me :)
Posted on Mar 08, 2007
2 Suggested Answers
vcrdr1
  • 53 Answers
SOURCE: KP-53s65 multipule problems, hoping for single solution?
sounds like 2 different problems here. first problem sounds tuner related. second sounds convergence related. third issue (cost effective to repair ?) at this point i would replace the set. i hope this helps
Posted on Mar 12, 2007
My Sanyo DS24424 has weak sound even when I turn it up all the way on the front of the set. Any solution?
Hi vfg1575,
This symptoms is commonly caused by mis-aligned sound IF transformer. Due to aging, frequency produced by the IF transformer vary and will affect the performance of the sound output. Sometimes the re-alignment will cure the symptoms just within a minute. You must have an IF alignment tools to perform the alignment procedure. You must turn it counterclockwise/clockwise (little turn only) while the tv is on to hear the sound output produced. You will notice that the sound strength will vary as you turn the IF. The IF transformer is labelled in the board as SIF. Here's the sample picture of it.
If the symptoms didn't cure by the IF alignment the fault came from the sound output circuitry which is caused by faulty coupling sound input electrolytic capacitor, poor solder joints, faulty sound output IC.
If you don't have necessary tools and test instrument and can't troubleshoot the symptoms yourself, I would advice you to look for an experienced technician to isolate the problem.
Note : If you are going to DIY, you must know safety precaution because any little mistake may hurt you and/or resulted in further damaged.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
May 01, 2011 | Sanyo DS24424 24" TV
Mirror or Misconvergance?
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2010 | Panasonic PT-47WX42 47" Rear Projection...
The tv picture is coming in shadowy
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Apr 03, 2010 | Hitachi 43FDX20B 43" Rear Projection...
My akia 54 inch tv has a halo around images
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Apr 01, 2010 | Akai PT5492S 54" Rear Projection...
Toshiba rear projection tv has red and blue on the tv
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
Mar 24, 2010 | Toshiba 42H81 42" Rear Projection...
Convergence issue
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Symptoms
Example Photo:
Mar 05, 2010 | Mitsubishi WS-55807 TV
Bowing convergence lines , projection tv
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Symptoms
Example Photo:
Feb 04, 2010 | Mitsubishi VS-80803 TV
Tv turns on then right back off
Does if make a chirp sound? If so see below...
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Red/Orange looking video
You can see some examples and find a fix here...
Jan 04, 2010 | Philips 46PP9302 46" Rear Projection...
Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Symptoms
Example Photo:
Mar 13, 2008 | Philips 55PP9352 55" Projection Television
Mar 12, 2007 | Sony KP-53S65 53" Rear Projection...
Sony KP-53S65 53" Rear Projection Television Logo
85 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
