Question about Kenmore 24902 Top Load Washer
Water leaking when being filled .
Doesn't seem to leak when in agitation mode but only when filling. leak from under the machine.
  • 373 Answers
Leaking while the washers off is a normal problem.check for corrosion or crack on the outer tub.
check the water supply connections and the drain hose.also make a check for the tube seal and tube bearing.these are the only possibilities for a water leak.
Posted on Dec 12, 2008
michael, try running the wash cycle under different levels eg. normal, delicate etc without a load and see if it agitates.If not, the mechanism has diengaged.
Mar 03, 2014 | Washing Machines
Wwont agitate
In the circuit there is a module that works the agitation of the machine . It is an electronic device that moves the motor back and forth producing the agitation and is not connected to any other operation. Have it checked by a washing machine mechanic for failure.
May 05, 2013 | Washing Machines
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
How to move around brandt wm 550
see this causes and fix it. God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Sep 22, 2012 | Washing Machines
Sears washer dryer commbo model 417.94712400 didn't stop filling with water and water went everywhere
Generally you could have two problems. Number one may be a sticking water solonoid that doesn't want to close after the fill cycle has stopped. Number two, if the machine has not started to agitate the clothes that means the timer has not reached that part of the cycle and is stuck in the fill mode. My guess is number two would be more likley, the timers **** out nowand then. Hope that helps
Sep 06, 2012 | Washing Machines
I have a Maytag Model A412, series 11 washing machine. After the machine fills with water the machine appears to start its cleaning cycle but the agitator doesn't work. The water starts & the...
if this is a two piece agitator,it should behave like a ratchet turn freely clockwise and catch counter clockwise if it doesn't catch the agitator "dogs " are shot this is a verry inexpencive repair
Jun 08, 2011 | Washing Machines
Water overflowing - GE wvsr1060a1ww top loading washer
since the water stops running in and goes to the agitation mode when you blow on the tube, it is more than likely the pressure switch - one thing to check though, put it in the fill cycle [with water running in] and unplug the power cord. the water should stop running in. if it doesn't, the fill valve is sticking open and should be replaced
Aug 16, 2009 | GE Washing Machines
Agitates but won't do anything in spin mode, won't drain
If it has a mechanical timer, that's most likely your problem. Not a hard fix. Most any "Do It Yourself" book can be used to show you how to swap timer. Getting one may be your biggest problem.
If it agitates, it's not the motor. You said the time seems to stop.
Feb 16, 2009 | Maytag PAV2300 Top Load Washer
Magic chef washing machine
Water is leaking all over the floor from the bottom of the machine when it is filling up. Can you tell me how to fix this problem.
Oct 23, 2008 | Washing Machines
Pav2200 model
Sounds like a transmission problem. It's locked in agitation mode. When it is in agitation mode you can't turn the drum or move the agitator. I'd check that out.
Jan 17, 2008 | Maytag PAV2300 Top Load Washer
Kenmore 24902 Top Load Washer Logo
125 people viewed this question
Sal De
 Brian Main
Brian Main
