Question about Toshiba 50A60 50" Rear Projection Television
TOSHIBA 50A60,GOING TO REPLACE LENTICULAR SCREEN
When removing the bezel is there anything special that needs to be done,the partsmen said something about screws for the screen,is this a simple task as it looks or am i in over my head??? please help,thanx
  • bioburn3d Jan 13, 2008
    I have the same problem. I cant find a replacement lenticular for mine. If you have found one PLEASE contact me with a supplier. bioburn3d71@aol.com. Thank you. patiently Awaiting your responce.
I found an old tv the same as mine on ebay. I had to buy it and pull the screen to fix mine. best of luck. hope you have the same luck as me. thanx for the responce.
Posted on May 29, 2008
I need a replacement Screen for a 60 Inch Philips TV. PLEASE LET ME KNOW
Dawn
Posted on May 23, 2008
Dawn
    Problem Solver:
  • 6 Answers
It's pretty simple repair.  Pull bezel, unscrew braces around edges and swap screen out.  Where did you find the lenticular at?  I have the same TV and can't find the part online.
Thanks
Posted on Oct 22, 2007
I have Toshiba Theaterview 50A60 projection TV ( built April, 2001 ) with a broken front screen. Anyone know where to find one??
http://www.partstore.com/ give them a call. If they don't have it, the can tell you where to get it or maybe order it special for you. Good luck!
Oct 09, 2010 | Toshiba 50A60 50" Rear Projection...
I got a toshiba tv and cracked the screen on it wer do i get a new screen 4 cheap
pigdigger,
I have bad news for you, the total cost for the three screens you will need will be about $290.00. They can be obtained from http://www.encompass.com . Here are the part #s: Fresnel 23311898 $80.00, Lenticular 23311897 $120.00 and Protector 23311863 $90.00.
Installation is straight forward. Generally you have to remove the back top cover with the mirror attached. Then check under the bezel on the front, below the screen, for several screws. Remove the screen and lay it flat on the floor. Remove the screen hold in screws or clips. Remove the screen.
Assemble the new screens. Make sure they are in the correct order. Protector (on outside), Lenticular in the middle and the Fresnel on the inside. You will need to secure the screens together. Black cloth tape works well around the perimeter. Reinstall the screen into the frame and reassemble the unit. This should complete the job.
Thanks for using FixYa and for the great rating.
hardrocko
Sep 29, 2010 | Toshiba TZ50V51 50" Rear Projection...
My hand went in and smashed the screen on my toshiba need new screen
pigdigger,
hardrocko
Sep 29, 2010 | Toshiba 42H81 42" Rear Projection...
Toshiba 50A60 Projection TV - Black Screen
There is no bulb in that model TV. There are 3 crt type tubes. You'll have to have a TV shop determine the cause. It could be many things like no high voltage present, cathode voltage missing. If the tubes are finished, the cost to replace them is quite high. It is a complicated repair since the tubes have to be properly aimed and converged. The repair cost in this worst case scenario would be greater than buying a flat screen TV with the same screen size.
May 17, 2009 | Toshiba 50A60 50" Rear Projection...
I need to know how to replace screen in toshiba a135-s4427
Pretty simple. There are small screws under little round pads around the outside bezel of the screen. Remove (4 or 6 of them) and gently seperate the screen back cover from the bezel. Once this is done, there are probably 4 or 8 screws olding the screen into the frame. Remove these, unplug the screen from the ribbon cable and the back light power wire. Reverse the procedure to install the new screen.
Walla, you are ready to rock in 20 or 30 minutes.
Thank you for rating this response.
Mar 15, 2009 | Toshiba Satellite A135-S4427 Notebook
Toshiba 50A60
Your best bet, and the cheapist, is to go on craigs list, an look for the same size tv, doesnt matter what brand, get one that doesnt work, probabily can find one free, or verry cheep, then just swop out the screen
Jan 08, 2009 | Toshiba 50A60 50" Rear Projection...
Need to replace a cracked screen
WD-57731 & WD-65731 Front Disassembly
57” & 65” Models Screen Frame
Removal
1) Pull off the Speaker Grill.
2) Remove all the screws (b) from the
upper rear cover (except one at an
upper corner to support the frame).
3) Remove 10 screws (a) from the
front of the screen frame.
4) Remove the remaining ***** (b)
(supporting the frame). Carefully
pull the Screen Frame from the TV
and disconnect the ES and LE
connectors.
57” & 65” Models Screens Removal from Frame
1) From the rear of the Screen Frame remove 20 screws (a) from the top and bottom rails
2) Remove 6 screws (b) from each side rail.
3) Carefully lift the Screen assembly from the Frame.
MODEL: WD-52631 / WD-57731 / WD-65731
Screen Replacement
CAUTION: Wear gloves when handling the Lenticular Screen and Fresnel Lens.
This prevents cuts and finger prints. Do not place Fresnel Lens in the sun.
This may cause fire and heat related injuries.
Lenticular Screen and Fresnel Lens Replacement
1) Apply LENS-TAPE along the rear top edge of the Lenticular Screen.
2) Place the Fresnel Lens on top of the Lenticular Screen, and apply pressure along the top edge.
3) Place the screens in the screen frame and reinstall the cushions, top, bottom and side rails.
NOTE: The Lenticular Screen label must face the front and the Fresnel Lens label face the rear.
4) Reverse the Screen Removal Procedure and insert the screens in the Bezel.
Lenticular Screen and Fresnel Lens Removal
1) Remove the top, bottom and side HOLDER-SCREEN rails and their cushions from the Screen Frame.
2) Lift the screens as a single unit from the frame.
2. Separate the Lenticular Screen and Fresnel Lens.
Note: When separating the Lenticular Screen from the Fresnel Lens, use caution
while prying the Screen and Lens apart. Use a slot type ***** driver, and
remove the pressure sensitive double sided tape.
Mar 11, 2008 | Mitsubishi WD-65731 65" HDTV
Toshiba 50A60 Lenticular cracked.
I don't have a particular source, but if you fail to find one you may try using a similar screen fopr a different model if you're a bit handy. Depending on how the screen is fastened, you might even be able to fit a regular canvas (roller curtain type or similar, user with video projectors)
If it has to ba some kind of specific frame on it you miahgt have to "hack" it, and it might not be that pretty. If it's just a screen fastened inside a frame, kind of like the glass in a picture frame you can get one in the same size, or a bit bigger and cut it down to size yourself.
Nov 26, 2007 | Toshiba 50A60 50" Rear Projection...
Toshiba 50A60 vertical picture adjustment
Try downloading the service manual and go through the calibration excercise. There's also some additional controls behind the right front speaker.
Nov 18, 2007 | Toshiba 50A60 50" Rear Projection...
Toshiba 50a60 cracked screen
i have just experienced the same myself, what you need to do is find a tv the same size, it doesnt have to be the from the same manufacturer, although it helps if you can get the same, as all lenticulars do the same job.
The outer screen is called the Lenticular, and the inner is called the fresnal, depending how bad your lenticular is cracked will determine if your fresnal has gone also, the only real way of knowing is when you take it apart to change it, (Dead Easy).
they are quite close together, but dont be afraid of trying, i have never changed one before, but i did it in about forty minutes and i dont know the first thing about tvs and now it is as new.
to change it, all you have to do is unscrew the front of your tv, from the surrounding screws at the back of it, once you have done this there are four or five small screws that hold the front of it up, take these out and your front will come off complete with lenticular and fresnal.
place it face down on a soft surface, so as that you are looking out of the inside of your screen, and you will see the fresnal.
they are held together with four brackets, one on each side of the screen.
unscrew the brackets, and take the fresnal off, then the lenticular.
put your new lenticular in, then the fresnal on top of that, and then secure it together again by screwing the four brackets back on.
it really is that simple, do not let these TV repairmen, scare you into buying a screen from them and charge you an extortionate amount of money to fit it.
im not sure if plexiglass will work, i was quoted £160+VAT for my screen from Toshiba, so what i did, i went on Ebay and found a full tv that was for spares or repairs, and paid £26 for it, and it is just as it was before.
One thing you must not do when attemting to change it, and that is to be scared of attempting it, because once you have done it, and at a fraction of the cost, you like me will curse the people who make a living out of overcharging people for such an easy job!!!!
Good Luck, and hope this has helped..
Doolb
Aug 26, 2007 | Toshiba 50A60 50" Rear Projection...
Toshiba 50A60 50" Rear Projection Television Logo
664 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
