Question about Jabra BT250 Consumer Headset
Jabra and phone
I am finding that my samsung phone will not let my jabra headset conect as i need a code to put in my phone and cant fined the book
  • Anonymous Jan 09, 2008
    I cannot find the passkey on Jabra? I just have the device and my Blackberry and need to get them paired?
    can you help
0000 passcode
Posted on Mar 25, 2007
Posted on Mar 15, 2007
I have 2630 nokia phone i use my jabra bt 2070 for this one and then i bought a new phone 6120 nokia but i cant use the headset on it every time i search for jabra device my phone cant find it
First turn ON your bluetooth on phone, then hold on/off button to turn ON Jabra headset for 5 SECONDS, then vill light hold ON (NO BLINKING) and then find it on your mobile phone....
Hi from Serbia ;)
Nov 23, 2010 | Jabra BT125 Headset
I need to pair my jabra VBT185Z headset with my samsung intercept. the intercept scans for devices but does not recognize the jabra
It,s possible that the headset isn't in search mode. Get the documentation for the headset to find out how to put it in this mode.
Nov 04, 2010 | Cell Phones
I hav a jabra bluetooth....type ote3 and i lost my directions for connecting it to my phone. i hav a samsung gravity phone i went to settings under bluetooth and turned it on and searched for devices but...
1. Put the headset in pairing mode and make sure that the headset is on. To do this: Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra headset
(Follow your phone’s instruction guide to do this)
3. Once your phone locates the headset, it will ask you for a code to pair with it, the code for jabra headsets is usually 0000
Sep 02, 2010 | Cell Phones
I cannot get my Blackberry Storm to pair with my Jabra BT2070.
You have to first put the Headset into discoverable mode. According to the Jabra website, this is done by pressing and holding the end/mute button until the light comes on steady. Follow the procedure for your phone to pair a bluetooth device to it. The PIN code will be 0000.
Feb 07, 2010 | Jabra Bluetooth Headset with Adjustable...
How to conect?
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Nov 19, 2009 | Jabra BT125 Headset
How do i pair my jabra w/my phone. cant find
hold down the button till the light turns solid blue, then let the phone already in bluetooth mode find the jabra, it will ask for a password, enter 0000
Sep 07, 2009 | Jabra BT125 Headset
Can i pair jabra bt125 with samsung blackjack ??
Mine is a Blackjack II, but i did get it to connect. Hold the clear button down on the Jabra until it lights solid blue, keep holding it with one hand while you use the other hand to operate your Blackjack. I went to Settings, then Connections, then Bluetooth, then "Add new device". As long as my Jabra was lit solid blue, the phone found the headset. Then it will ask you for the pin code, which i found by accident (0000 - four zero's).
Jul 11, 2009 | Jabra BT125 Headset
Charged earpiece doesn't communicate with cell phone
My advice would be to re-pair the two devices. In the Bluetooth menu on you phone find 'paired devices' and delete the headset from the list. Next you will need to put the Bluetooth headset into pairing mode. Make sure it is switched off and then press and hold the power button on the headset and keep pressing it ( some headsets need to also have the up volume button pressed at the same time). What should happen is either a solid blue light of alternate flashing of two colours. (pairing mode varies on different headsets and you made need instructions or call Jabra) At this point on the phone in the Bluetooth menu search new devices. It should find your headset and request pairing code. Code should be '0000' or some headsets use '1234'. This should now set up a fresh pairing and work again. Hope that helps.
Apr 23, 2009 | Cell Phones
Chocolate phone will not discover the Jabra BT150
you use your Jabra BT150, you need to pair it with your mobile phone. 1. Put the headset in pairing2 mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on. 2. Set your Bluetooth phone to ediscoverf the Jabra BT150 Follow your phonefs instruction guide. This usually involves going to a esetup,f econnectf or eBluetoothf menu on your phone and selecting the option to ediscoverf or eaddf a Bluetooth device.* (See example from a typical mobile phone in fig. 4) 3. Your phone will find the Jabra BT150 Your phone then asks if you want to pair with it. Accept by pressing eYesf or eOKf on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing
Oct 07, 2007 | Jabra BT150 Wireless Headset
Jabra BT250 Consumer Headset Logo
76 people viewed this question
Top Jabra Radio Communications Experts
Bobby G
Bobby G
Damen Wong
Damen Wong
Jerry Greenberg
Jerry Greenberg
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
