Paperjam on fp 1670
When making copies from paper tray it jams under the drum, but using the bypass tray no problem. i've check everything but no result on fp 1670
thanks frikkie
  • 106 Answers
Maybe your printer has dust or dirt inside.... or something that can make your printer jam... try to clean first your printer.... ^^
Posted on Jan 29, 2009
Paper continues to jam
check the paper actuate of the sensor if it o.k check the sensor if its clean
Jun 24, 2014 | Gestetner C7425DN Paper Feed Roller...
I do not know how to remove the drum to fix a paperjam
Brother strongly recommends that customers do not use generic drum unitsand/or toner cartridges, or refill their Brother toner cartridge. Each Brother laser printer is designed to work at pre-set temperatures that are matched exactly to each of our individual toner formulations. Each individual component is designed to work with the other to ensure quality and reliability. Using non-Brother supplies may affect the Verify the message displayed on the LCD.
Warning: If you just used the machine some parts inside the machine are extremely hot.
1. Pull the paper tray completely out of the machine.
2. Pull the jammed paper out of the paper tray opening. If you are unable to remove the jammed paper continue to STEP 3. If you are able toremove the jammed paper continue to STEP 9.
3. Open the front cover. If you cannot open the front cover, do not useextra force. See below for further assistance.
4. Pull out the drum unit and toner cartridge assembly. The jammed papermay be pulled out with the toner cartridge and drum unit assembly, or removing the drum and toner assembly may release the paper so you canpull it out of the paper tray opening.
a. If you are able to remove the drum assembly and jammed paper continueto STEP 5.
b. If you cannot remove the drum unit and toner cartridge assembly easily, do not use extra force. See below for further assistance.
5. Place the drum unit on a drop cloth or large piece of disposable paper to avoid spilling and scattering the toner. Hold down the blue lock lever on the left side of the drum assembly and lift the toner out of the drum unit. Examine the drum carefully for small pieces of paper that may be jammed inside.
6. Reinsert the toner cartridge in the drum unit until it clicks into place. If you put it in properly, the lock lever will lift automatically.
7. Place the drum unit and toner cartridge back into the machine. Use equal pressure on both sides of the drum unit when pushing it back into place. Make sure it clicks into place.
8. Close the front cover. Make sure it clicks into place.
9. Remove any remaining paper in the paper tray and then reload it. The tray can hold up to 250 sheets of 20lb paper. Do not over fill the tray.There is a maximum paper mark located on the top of the right and left paper guide. It looks like a V cut out in the plastic. Fan the stack of paper well to avoid paper jams or misfeeds.
NOTE: If you are using special paper and the machine has problems feeding it from the paper tray, try the paper again using the manual feed slot
10. Put the paper tray firmly back into the machine and unfold the output paper tray support flap before using the machine.
11. Turn the Brother machine around with the back of the machine facing you.
12. Open the back cover.
13. The black plastic inner chute should spring open automatically when the back cover is opened. Note: The inner chute has a diagram on it of a piece of paper being removed from the unit.
14. If there is paper inside the machine carefully remove it.
15. Close the back cover. NOTE: The inner chute will close automaticallywhen the back door is closed.
16. To test, print the Help List:
a. Press the REPORTS key located on the right side of the control panel.
b. Press the up or down arrow key until Help list appears on the display(#2).
c. Press Menu/Set. The report should begin printing.
Thanks an good luck
Nov 27, 2010 | Brother MFC-7220 All-In-One Laser Printer
CLX 2160 - paperjam
There is probably a jam in the paper feed area. Pull the paper tray out and stick your hand in to find and remove any paper stuck there. Then reinstall the paper tray and open and close the front door of the printer. The jam should be cleared.
If it is still showing paper jam, pull the tray out again and look to make sure you didn't miss any paper, then check the other areas of the printer (starting with the exit area) for paper.
Oct 24, 2009 | Samsung CLX-2160N All-In-One Printer
Panasonic FP-7750 will not feed paper through machine correctly
Look where you remove the last jamed piece of paper closest to the fixing unit. Dose it jame when you make one copy? If it dose jam in the same place, I would have to say the problem is in the fixing unit. Look, in the unit for any pieces of paer jamed and remove them. Also, is it only happen with one paper tray and not the other. If so make sure you haze the tray and paper are set correctly.... Really need some more info.
Aug 05, 2008 | Panasonic FP-7750 Black and White Copier
Can not copy from tray/drawer, but get copy from multi-bypass tray
Regular copy paper that I got from the Staples. Same paper in the paper tray/drawer as in the multi-bypass tray. Thanks.
Jun 25, 2008 | Sharp AL 1631 Copier
Jams EVERY TIME
Where is the paper jamming? Out of the paper tray or under the drum or in the fixing unit? Did you make sure you have the paper tray set up to the correct paper size and orantation for the paper in the paper tray and dose it happen at any other time and where is it jamed up at. Need more info.
Mar 14, 2008 | Sharp AL 1631 Copier
Persistent paper jam message
In response to a question by Fixya. I solved it by searching throgh all references to paper jams on Fixya. I found a solution which I have already described. This is a very helpful site.
Feb 27, 2008 | OKI B4100 Laser Printer
Re: paper jam in brother laser printer hl 2040 : paper red ligh continue to flash
Try shutting the printer completely down & unplug power. then plug power back in and while holding down all buttons on the printer control panel, turn it back on. this should put it into a self diagnostic mode that prints out just about everything the printer can do, including a sample page. Also, be sure all rollers are clean & trays are completely closed before restarting. If the printer works when you do this, you should most liely check all settings in the software package (driver) or perhaps reinstall the drivers. If this is necessary, be sure to download the latest drivers from the Brother website.
Feb 10, 2008 | Brother HL 1440 Laser Printer
PAPER JAMMED
You have a stuck sensor.
Open the rear door and make sure there is no paper in there.
Remove your toner from the drum and make sure there are no bits of paper stuck under the toner cartridge.
l
Look inside the drum chamber for the little plastic levers that actuate the sensors. Make sure they move back and fourth freely.
Dec 05, 2007 | Brother IntelliFAX 4100 Laser Fax
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
