Question about Palm Vx Handheld
Hot Synch an existing PalmVx data to a replacement palmVx
My Palm Vx pda recently broke and lost all data.
I purchased a used Palm Vx pda which is in good shape.
I now want to synch and transfer my existing palm data on the computer with this replacement pda.
What is the best way to accomplish this?
I have not reinstalled the software to create a synch condition with this replacement pda yet.
Thanks for the reply.
David
  • Palm Expert
  • 346 Answers
HI,
The first thing you want to do is to do a Hard Reset on the used PDA that you bought as a replacement. To do that follow these steps:
1. Hold down the power button and then depress the small hole in the back with the tip of your stylus.
2. Continue to hold them both in until you see the Palm logo.
3. Let go of both of them and then follow the onscreen directions. You will want to answer yes and use the 5 way navigation button on the bottom of your pda and hit up so that is completes the reset. After that you will have to set up your touch screen and go through the tapping the target. After you have gone through all this then do a hotsyncHot Synch an existing PalmVx data to a replacement - 2.gif. It should clear up your problem. Best wishes.
Posted on Sep 29, 2009
  • Joy Shannon
    Joy Shannon Sep 29, 2009
    You will need to do a hard reset of your newly purchased Vx. To do that follow these steps and then do a Hot Sync.
    with the tip of your stylus. Continue to hold them both in until you
    see the Palm logo. Let go of both of them and then follow the onscreen
    you have gone through all this then do a hotsync. It should clear up your problem. Best wishes.
My computer crashed. I have a backup of all my Palm files but am having trouble recovering them. Does anyone have instructions on how to restore backup files on a Palm Tungsten E2?
Hello.
Palm backups are located in the following directory: C:\Program Files\Palm\username>\ED\Backup\
When you HotSync a PDA that has undergone a hard reset, HotSync will compare the two devices. When it sees that the PDA is empty, it will attempt to reload any backup that exists on the PC. Once this data is reloaded, the PDA will ask to do a soft reset. This is simply a restart of the device and doesn't affect any of the newly installed data. This returns the PDA to working order, with all the data and programs functioning as they were before.
Hope this resolves your problem.
Jan 23, 2011 | Palm Tungsten E2 Handheld
Palm Lifedirve will not synch. Since it has not yet performed an initial synch I cannot use wireless or network to get around the usb driver problem
Try connecting it to a higher speed usb port if you have one. You can also purchase higher speed hub connection.
Apr 25, 2009 | Computers & Internet
My Palm desktop program on my laptop lost half of my contacts
Ok, do a hard reset in you pda, in your PC, using you palm d., open you user files, export your adresses and memos; then create a new user and import all this data and do a hotsync
Apr 24, 2009 | Palm Tungsten T2 Handheld
In the market for a PDA-mobile compatible with Mac / Palm Vx
The Iphone3G is smart choice for you. It has tons of great features and the best part is that it runs on MAC mobile. So you will have no compatibility issues what so ever.
Dec 11, 2008 | Apple iPhone Smartphone
I just bought a palm Z22 PDA. I used the AC charger to charge the Z22 but when I attempted to attach the USB synch cable I noticed that the plug is different from the plug on the AC charger. The USB...
I have concluded that the USB synch cable is not the correct one for my Palm Z22 PDA. There is only one point of attachment on the PDA and it is different from the plug on the USB synch chord. This was the last Palm Z22 PDA in the store so I think that the store clerk rounded up leftover parts and components of previous PDA kits and tried to make a complete set out of it. I am going to return the PDA to the store (Staples) in the next day or two.
Thanks for your offer of help. I will contact you again in the future if I need help.
Oct 15, 2008 | Palm Z22 Handheld
Screen orientation
PDAs that use touch screens have a very thin membrane over the screen itself that responds to pressure. If this membrane becomes damaged, which it sounds like what has happened, then you're more than likely going to need to have it replaced. You can try doing it yourself, but it's WAY up on the difficulty factor because of the complexity of the connection to the circuit board on the Vx.
To determine if your unit is, in fact, actually damaged, you should first make sure that you've syncronized the unit (which may not be possible if you don't have it set to automatically activate HotSync when the device is attached) then do a "hard reset" to restore it to the factory default. To do this, hold the reset button while simultaneously holding the power button for, at least, three seconds. You will get a message asking you to press up on the control pad to reset to factory defaults. Once the unit is reset, try the screen again... touching even the outer areas to see if there's any response. If it reacts, or beeps at all, then it may be an issue of recalibrating (using the "Digitizer") once it's fully reset. If not, it will need repair/replacement.
Oct 28, 2007 | Palm Vx Handheld
Retrieving Back-up contacts/phone book
Try Desktop overwrite HH. I've lost everything on my HH a couple of times and had to set the conduits to 'Desktop overwrites HH' in the hotsync manager - Custom settings for the next hot sync. If what you have on desktop isn't what you want, you should copy your saved folder info back over whats in your palm folders (i.e) where you copied it from.. Before you complete this step. Then your old data will be copied to your HH. Note - I assume you "copied" , not "archived" the data.
Sep 11, 2005 | Palm Treo 650 Handheld
Synching treo 650 with 600
In a nutshell, make sure you have a recent synch to your PC of the 600. Install the Treo 650 desktop software Synch to the username of the 600 Your are done. You should rename the Treo 600 or hard reset it (you will get data corruption if you synch two devices with the same username to one PC). If you are paranoid, you can make a backup copy of your c:\program files\palm\ folder to begin with. This contains most of your settings and extra software on the 600. As you are an Outlook user, your personal data is probably in a PST file or it is stored in Exchange.
Palm Vx Handheld Logo
159 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
